TW-acustic lanserer jubileumsmodell - Raven Anniversary
Platespilleren Raven Anniversary markerer TW-acustic sitt 10 års jubileum nå i mars og vil for første gang bli vist frem under High-End messen i München i mai.
Plinten er basert på den til Raven AC, mens tallerkenen er lik den til toppmodellen Raven Black Night. Anniversary-modellen er tilgodesett med et nytt armbrett som strekker seg langs hele den høyre siden av plinten. Alle tonearmer på markedet er støttet og armbrettet har innebygget justering fra 210-310 mm i trinn på 1 mm.
Her er TW-acustic's egen pressemelding:
For ten years now TW Acustic has been making a lasting impression on the turntable market. With our first model – the original Raven – perfect build quality became the standard. Not only that, back then we broke new ground and were the first manufacturer to use a custom-developed synthetic compound based on Delrin. Due to its perfect damping properties, it is almost impossible nowadays to think of a better choice of material than this for modern turntable construction. Also, the use of high-torque motors and sophisticated controllers allowed us to set a new benchmark. Thanks to our developments, music-lovers worldwide are able to indulge their audiophile passions with full satisfaction, and to enjoy their fascination with turntables on an impressive level.
To celebrate TW Acustic’s tenth birthday in March 2013 we present the "Raven AC Anniversary". The Anniversary represents a new statement in turntable manufacture. It is based on the Raven AC chassis, machined from our well-known proprietary custom compound with a screwed-in stainless-steel plate. The Anniversary’s platter is a composite construction consisting of 40mm thick copper fixed to a 20mm thick slice of our proprietary compound. Consequently, the platter is basically equal to that of the Black Night.
Our anniversary model has a very solid armboard machined from 30mm thick aluminium. We can provide the relevant adaptors for every tonearm. To achieve the correct mounting distance, the position of the adaptor for your particular tonearm can be adjusted steplessly in the slot in 1mm increments. To facilitate this we have etched a scale on the armboard showing 210–310mm. Should you wish to install more tonearms, extra swivel bases can be installed as before with the original Raven AC. From an acoustic point of view, the Anniversary offers the same advantages as the Raven AC, but thanks to the modifications keeps a firm eye on its bigger brother the Raven Black Night. Similar to the Black Night, the Anniversary lets the music flow, yet remains composed and pairs dynamics with incomparable transparency.
It is rare in this class to experience such resolution and dynamics in music. With the Raven AC Anniversary we bring you a big step closer to the ideal of real high fidelity musical reproduction.
Produktside: Raven Anniversary
Gjallarhorn Audio
Gjallarhorn Audio sine annonser
Prisøkning fra ProAc den 1. mai
For de som for tiden vurderer å gå til innkjøp av høyttalere fra ProAc, så kan det være nyttig å vite at ProAc øker prisene med 7,5% den 1. mai (2025). Fra og med denne prisendringen, så vil for...
Takk for besøket på OHFS 2025!
  • 1
En stor takk til alle som var innom vårt rom (108). Det var en jevn strøm av besøkende under hele messen, så kanskje ble det en ny besøksrekord for Oslo HiFi Show i år? Vi må også få takke Stefan...
Clearaudio kommer til Oslo HiFi Show
Stefan Kmuch fra Clearaudio kommer til Oslo HiFi Show for å delta på norgespremieren av deres Master Jubilee platespiller som ble utviklet i forbindelse med deres 45 års jubileum. Clearaudio's...
Norgespremiere av SPEC's nye flaggskipsmodell på Oslo HiFi Show
RSA-EX1000 er japanske SPEC's nye toppmodell innen kategorien integrerte forsterkere. Denne kan høres for første gang i Norge på Harbeth's nye Monitor 40.5 XD2 høyttalere på rom 108 under hi-fi...
Harbeth's nye XD2-serie får sin norgespremiere på Oslo HiFi Show
Harbeth's nye XD2-serie er her! Første modell ut er Monitor 40.5 XD2 som vil bli demonstrert under Oslo HiFi Show den 22.-23. mars. Velkommen! Veiledende pris for M40.5 XD2 starter på kr. 223...
Gjallarhorn Audio velger AnalogLAB
Alle platespillere levert av Gjallarhorn Audio vil nå bli satt opp av AnalogLAB i Asker med mindre du har glede av å gjøre jobben selv eller at du ikke kan hente platespilleren hos oss og...
