Tenker at denne har større interesse enn kun DIY seksjonen av forumet.
Bruce Rozenblit er nå ute med en ny bok som omtaler teori, prosjekter og annet relatert til rørforsterkere. Mannen har mange OTL konstruksjoner bak seg og det er dette som har hovedfokus for prosjektene dekket.
Jeg la inn bestilling på denne i dag, så den burde nok komme om noen uker.
Tubes and Circuits by Bruce Rozenblit
- Basic Circuit Science: Essential physics required to understand circuits.
- Electricity: Explains in detail what electricity is and how it works.
- DC circuits: Shows how current flows and behaves through resistive elements.
- AC circuits. Detailed information on AC circuit theory, reactive elements, and how they affect signals.
- Inductance: What it is and how it is created.
- Networks: How components are used to create networks and interact with each other— includes transformer theory.
- Feedback Theory: Shows how feedback works and how best to use it.
- Vacuum Tube Construction and Chemistry: Reveals in detail the chemical and physical processes of how vacuum tubes function, generate current, age, and deteriorate.
- Vacuum Tube Fields and Function: Shows how the electric fields inside vacuum tubes cause them to work.
- Tube Characteristics: Demonstrates what tube constants are and how to use them. Shows how to use tube characteristic charts to derive the tube constants used in design equations. Explains load lines and their application.
- Tubes Circuits: Detailed operation and all design equations for virtually all of the tube circuits used in high-end audio. Includes single-ended and push-pull transformer coupled output stages.
- Power Supplies. Basic information on power supply design and function.
