TTs tråd
  • helarn
    Bodø
    Husker at det var om kvelden for jeg hadde lagt meg og faren min kom inn på rommet mitt og fortalte om mordet.
    HasseBasse
    Hjortshøj, Danmark.
    Nå er jeg jo faen SÅ mye eldre :devilish: :devilish: :devilish: enn dere, såååååhhhhh
    NESTEN korrekt 😂😂
    Det rette svaret er 16 2/3 rpm eller 16,666 (det halve av 33.333).
    Det var hovedsakelig Frankrike, (i hvert fall de, som holdt lengst) som i en periode holdt på med dette for å få Long, longplay på en plateside.
    Men akkurat som med R2R, som hadde hastighetene 4,75, 9,5, 19 & 38cm/sek, fandt man ut av, at det var veldig lite "Fidelity"
    på den langsomme hastigheten. at dette fort stoppet av seg selv.
    Fra Wikipedia:
    Evolutionary steps[edit]
    Manufacturing vinyl records in 1959
    Technology used in making recordings also developed and prospered. There were ten major evolutionary steps that improved LP production and quality during a period of approximately forty years.
    1. Electrical transcriptions and 78s were first used as sources to master LP lacquer–aluminium cuts in 1948. This was before magnetic tape was commonly employed for mastering. Variable pitch groove spacing helped enable greater recorded dynamic levels. The heated stylus improved the cutting of high frequencies. Gold sputtering in vacuo became increasingly used to make high quality matrices from the cuts to stamp vinyl records.
    2. Decca in Britain used high-quality wide range condenser microphones for the Full Frequency Range Recording (FFRR) system c. 1949. Wax mastering was employed to produce Decca/London LPs. This created considerable interest in the United States, and served to raise the customer's overall expectations of quality in microgroove records.
    3. Tape recording with condenser microphones became a long used standard operating procedure in mastering lacquer–aluminium cuts. This improved the overall pickup of high quality sound and enabled tape editing. Over the years there were variations in the kinds of tape recorders used, such as the width and number of tracks employed, including 35 mm magnetic film technology.
    4. Production of stereo tape masters and the stereo LP in 1958 brought significant improvements in recording technology.
    5. Limitations in the disc cutting part of the process later generated the idea that half-speed mastering would improve quality (in which the source tape is played at half-speed and the lacquer–aluminium disc cut at 16+2⁄3 rpm rather than 33+1⁄3 rpm).
    6. Some 12 inch LPs were cut at 45 rpm claiming better quality sound, but this practice was short-lived.
    7. Efforts were made in the 1970s to record as many as four audio channels on an LP (quadraphonic) by means of matrix and modulated carrier methods. This development was neither a widespread success nor long lasting.
    8. Efforts were also made to simplify the chain of equipment in the recording process and return to live recording directly to the disc master.
    9. Noise reduction systems were also used in tape mastering of some LPs, as well as in the LP itself.
    10. As video recorder technology improved it became possible to modify them and use analogue to digital converters (codecs) for digital sound recording. This brought greater dynamic range to tape mastering, combined with low noise and distortion, and freedom from drop outs as well as pre- and post-echo. The digital recording was played back providing a high quality analogue signal to master the lacquer–aluminium cut.
    https://www.capsnews.org/apn2010-3.htm
    motoren
    Flekkefjord
    NESTEN korrekt 😂😂
    Fra Wikipedia:
    Vis vedlegget 794107
    Du er en klok herre mann Hassebasse :)
    P
    parafinoksen
    NESTEN korrekt 😂😂
    Fra Wikipedia:
    Det var litt av et eksempel på 16 RPM-plate du hadde valgt!
    TT.
    Vel, god formiddag alle!
    starter dagen med tur og deretter snømåking.Har hørt at det er lurt å få opp pulsen litt før man gyver løs på snøen. Ikke mye som kom, men nok til at det må tas. Her er presidenten av Hurrahølet i gang, med capsen bak fram. Sjekk spesielt den elegante beinføringen og ditto swung over det hele!
    Mickey hjalp også til etter beste evne
    kaffe og musikk og en rolig dag, står nå på programmet. Ha en aktiv dag!
    TT.
    En elefant glemmer aldri sies det, ei heller jeg. Derfor kan jeg med stolthet fremvise bilder av en fordums stolthet og sikkert en konkurrent til Garrard dengang da... Philips GA2230
    og beviset for at den spiller også 16 2/3 rpm
    ToreP
    Musikkinteressert
    Den Philipsen var utrolig fin, og sikkert sjelden,TT. Den må du ta godt vare på!☺
    Tore
    Reaksjoner: TT.
    TT.
    Tore
    Ja da, den skal ingen steder. Ser den trenger en ny reim, da den ligger som smeltet lakris under tallerken. Jeg har noen reimer, så jeg kan få den opp og gå allerede. Jeg vet ikke om denne kan kalles for en mellomhjulsspiller, men noen gummihjul er det. Har
    Forøvrig notert både nr på spiller og funnet ut hva pu og stift heter og det er fortsatt mulig å oppdrive original stift.
    TT.
    Fanken heller. Å bestille noe og så blir det sendt med med PostHvor er en mare, hver gang! Ingen vet noen ting og det har ikke vært bevegelse siden 18/2. Hvorfor skjønner ikke snart firmaer ar de ikke skal bruke dette drittselskapet som ikke aner noen ting og bruker innleide speditører i hvite varetaxier som er mer opptatte av å smugle øl, sprit og sigaretter fra tidligere østblokkland, enn å sette sin ære i å levere et godt produkt for oppdragsgiver.
    ToreP
    Musikkinteressert
    Flott lenke, TT.😍 Artig med bilder og tekst - da skjønner man lettere hva det snakkes om!
    Du sitter på "en perle" av en spiller!
    Tore(som har et par-tre gamle platespillere fra Philips, hvor 212 er "øyenstenen")
