K
Dette høres ut som et alt for dødt rom etter min intuitive mening. Symmetri om midtaksen, ja. Ikke-paralelle vegger, tak og gulv, ja. Men jeg ville prøvd å gå for et rom med mer diffusjon og mindre demping.• The ceiling and floor would be heavily absorptive, with thick carpeting and underliner underfoot, and efficient acoustical panels above. The walls, too, would be heavily absorptive, with deadening material covering 100% of the wall surface in the listening half, and 50% of the wall surface at the loudspeaker end.
(This is the most common recommendation; other authorities recommend having the 100% at the speaker end and the 50% at the listening end. I prefer the room to be completely deadened, with the addition of an electronic reverb device like the Benchmark ARU to add acoustical space to the listening area. Play the absorption game by ear. An excess of deadening is generally better than a deficiency, but any error is easily reversible if you don't glue things in place.)
Boken är intressant som uppslagsverk men i mitt tycke fokuseras det för mycket på absorption och dämpning och för lite på diffusion.Zomby_Woof skrev:Ahhh... Link til omtale av denne?
Edit: Funnet selv hos amazon.co.uk og lagt i ønskeliste.
