Symposium med emne uten betydning?
ymir
14th International Symposium on Sound Engineering and Tonmeistering
The 14th International Symposium on Sound Engineering and Tonmeistering will
be held on May 19-21, 2011, in Wrocław. The Symposium is organized by the Chair
of Acoustics, Institute of Telecommunications, Teleinformatics and Acoustics, Wrocław
University of Technology, under auspicious of the Polish Section of the Audio Engineering
Society. The organizers cordially invite sound engineers, music producers, acousticians,
and specialists in sound reinforcement, scientists who deal with sound engineering,
sound recording and related areas, students, and employees of the audio industry to participate
in the Symposium. The Symposium programme will include lecture sessions and
workshop presentations.
http://acoustics.ippt.gov.pl/index.php/aa/article/viewFile/191/180
Blandt deltagerne
http://pe.org.pl/articles/2011/9a/61.pdf
Legger ved denne også siden den omtaler litt av det samme
https://tspace.library.utoronto.ca/bitstream/1807/11348/1/MQ28872.pdf
. 1 . 4 Applications for the O C C products
For instance, extremely fine wires and thin plates with a diameter and thickness
of 10 microns or 20 microns and no intemal defects have become necessary, such as
lead frames and bonding wires for use in ICs and LSls [
3, 5, 6 1.
Recently, in order to keep Pace with the progress made in such advanced
technology, there have been sophisticated demands for materials having no crystal
grain boundaries, which in the past was inconceivable, such as copper wire for use in
acoustic applications [12
Mye arbeid som er lagt ned i forskning,men allikevel til ingen nytte i audiobransjen,vistnok.
Kule-Trygve
Properties similar to those of LGC and LCC copper are
possessed by OCC copper obtained according to Ohno
Continuous Casting Technology, the main purpose of which
is the decrease of the amount of crystals in the conductor.
In highly specialized applications, such as electron
technology (elements of particle accelerators, cryogenics),
6N grade copper with a purity of 99.99997 % is used. The
highest grade of purity for copper obtained industrially is
currently 8N grade purity (99.999999 %). High quality
cables are often made from copper with a purity grade of 6-
7N.
Jaså, kanskje ikke CERN er storkunde på Biltema likevel..
Ting er litt annerledes hvis ledningene enten skal fungere ved -270 grader, i høyt vakuum, eller skal være noen få nanometer tykke. Sist jeg så etter var ingen av de forholdene til stede bak anlegget hos meg. Det opererer i romtemperatur ved atmosfærisk trykk og med generøse ledningstverrsnitt, og da er dette uten betydning, ja.
Edit: Hvis dere leser programmet for symposiet vil dere se at dette er tre forskere i materialteknikk som skal snakke om hvordan superrent kobber fremstilles. De nevner at slikt materiale benyttes i partikkelakseleratorer, i ultra-tynne ledere på integrerte kretser og i audiokabler. Det er forsåvidt et korrekt utsagn. Riktignok er det bare i de to første applikasjonene dette har noen som helst betydning, men enkelte kabelprodusenter hevder ihvertfall at de bruker sånt materiale i kreasjonene sine. Legg også merke til at det ikke står noe om anvendelsen av materialet i artikkelen. Artikkelen fokuserer bare på fremstilling og bearbeiding av slikt materiale, og sier ingen ting om eventuelle lydmessige egenskaper. Personlig skjønner jeg ikke hva et slikt foredrag har i dette symposiet om lydteknikk å gjøre.
