Spennende Nyheter fra EMT kommer til Endpoint Audio
  • EMT er riktignok et firma som har rundet 85 år, men er på ingen måte utdatert og gammeldags. Under de siste årene har Micha Huber sørget for å modernisere og finpusse kunnskapen som er etablert gjennom alle disse årene og sist ut nå er et par gledelige overraskelser som vi ser veldig frem til å få i hus.
    1. New EMT tonearm technology
    The legendary EMT tonearms 929 and 997 (Banana) have been manufactured for decades
    and remained unchanged until the production was discontinued in 2018. Since then, the EMT
    team has been working on the design of a tonearm series with advanced technology, and we
    are glad to introduce this amazing product to the public in 2022.
    EMT 912 og EMT 912HI
    We are particularly proud on the fact that we were able to combine most modern bearing- and
    manufacturing-technology with the traditional EMT design. Thus, the sound properties are improved
    significantly, while at the same time the long history of this product-line is respected.
    EMT 909 og 909HI
    The new tonearms are available as 9 inch and 12 inch version. They come either with fixed
    headshell (HI version) or with EMT connection for the Tondose.
    All tonearm models feature a magnetic antiskating device and a ring for VTA adjustment.
    A tonearm-lift is included with the product and can be removed if the tonearm is used on old EMT turntables with built-in lifting device.
    The tracking geometry was optimized according to the latest knowledge, but all mounting properties remain unchanged.
    For both, horizontal and vertical bearing axis, the EMT tonearms feature a unique ball-bearing technology.
    The highly integrated and rigid mechanism is made of hardened and polished steel parts, combined with customized
    rubber components. This reliable EMT technology compensates for any geometric deviation along the bearing axis, caused by
    positional tolerance, tightening torque and environmental influences such as temperature and humidity.
    Therefore, the bearings remain free of tension and run with lowest friction values during their entire life cycle.
    The counterweight is connected to the armtube by two decoupling PTFE bushings. It features a spring-loaded mechanism to allow
    backlash-free positioning along the adjustment range. An engraved scale can be turned to zero position when the tonearm is in neutral
    balance. This allows precise setting of the vertical tracking force, even if you don’t have a tonearm scale at hand.
    Each EMT tonearm consist of 150 individual parts. All structure parts are machined from solid material in highest precision.
    We use stainless steel for the base-parts and aluminium-alloy for all movable parts. A specific alloy called “German silver” is used for all parts
    that are exposed to mechanical abrasion, such as the rear shaft or the connection for the Tondose.
    We have invested into elaborate tooling to lift the preciseness of machining and assembling the arm-tube-components to a new level.
    So, without false modesty, we can claim to offer the most precise tonearms with curved arm-tubes available on the world market.
    Prisene på de forskjellige tonearmene er:
    EMT 912HI med 5 pins DIN - 83990,-
    EMT 909HI med 5 pins DIN - 69990,-
    EMT 912 for EMT eller Ortofon o.l (valgfritt) med 5 pins DIN - 63990,-
    EMT 909 for EMT eller Ortofon o.l (valgfritt) med 5 pins DIN - 54990,-
    Tom Egil
    tomegil@endpointaudio.no
    47832922
Endpoint Audio
Endpoint Audio sine annonser
Canor Virtus A3
Canor Virtus A3
  • 1
Canors nye kreasjon Virtus A3 begynner å få flotte tester i hifi verdenen. LP International har tatt A3 under lupen og sett på hva som befinner seg under lokket. Dette er en alt i ett forsterker...
Flott test av den nye Canor A3 i Hifi Pig!
  • 2
Canor, en slovakisk produsent med 30 års erfaring i å lage høykvalitets HiFi-komponenter, har markert seg som en aktør å regne med i lydverdenen. Deres nyeste kreasjon, Canor Virtus A3, er en...
Acoustical Systems - Endpoint Audio
  • 3
Endpoint Audio gjenopptar agenturet for Acoustical Systems i Norge Jeg er stolt over å kunngjøre at Endpoint igjen er den offisielle distributøren av Acoustical Systems’ høykvalitetsprodukter i...
Nyhet fra Canor - Canor Virtus A3, alt i ett forsterker.
  • 2
Canor har endelig lansert sin nye alt i ett enhet. Klasse A/AB, 6 digitale innganger, 4 analoge innganger, 1 phono MM/MC inngang. I tillegg har den hodetelefonutganger i fronten - balansert og...
Black weeks hos Endpoint Audio - 15-20%
Jeg kjører tilbud på en rekke merker ut november. Horns - 20%. EMT og Thales - 15%. Canor 15%. Norma - 20%. Ring eller send mail for tilbud om det er noe du ønsker...
Lagertømming av Lumin. - 40%
Jeg har noen få Lumin U2 mini igjen på lager, og selger ut disse med ca. 40% avslag. Nå 18000,- https://perfect-sense.se/varumarken/lumin
