SoundSmith hos Norsk Audio Teknikk AS
  • Vi har nå begynt å forhandle SoundSmith Pickupper.
    Har stort sett Otello, Carmen og Boheme på lager. Leveringstid på andre SoundSmith produkter ca 2-3 dager.
    Ullevålsveien 13
    0165 Oslo.
    Tlf: 22200095
    mail: morten@norskaudioteknikk.no
    Link prisliste: http://norskaudioteknikk.no/Priser/soundsmith-priser.pdf
    Soundsmith
    High output pickupper
    Otello
    Stylus: Elliptical Titanium Bonded, 0.20mm Round
    Radius of curvature: 6 x 17 µm
    Cantilever: Aluminum Alloy
    Recommended Tracking Force: 1.2 gm (Max)
    Effective tip mass: 0.50 mg
    Compliance: 28 µm/mN (high)
    Frequency Response: 20-20,000 Hz (±2.5 dB)
    Channel Separation: 1000 Hz: >24 dB 50-15,000 >20 dB
    Channel Difference: <1.8 dB
    Output Voltage: 2.2 mV
    Weight: 6.8 Gms
    Impedance: >/= 47 kOhms
    Capacitance: 100-200pF
    Carmen
    Stylus: Nude Elliptical, 0.120mm SQ
    Recommended Tracking Force: 1.4 gm
    Effective tip mass: 0.35 mg
    Compliance: 22 µm/mN
    Channel Separation:
    1000 Hz: >26 dB
    50-15,000 >20 dB
    Channel Difference: <1.6 dB
    Weight: 6.8 Gms
    Load:
    Resistance: >/= 47 kohms
    Boheme
    Stylus: Contact Line Nude, 0.120mm SQ
    Radius of curvature: Contact Line
    Cantilever: Ruby
    Recommended Tracking Force: 1.3 gm
    Effective tip mass: 0.32 mg
    Channel Separation:
    1000 Hz: >28 dB
    50-15,000 >20 dB
    Channel Difference: <1.4 dB
    Weight: 6.8 Gms
    Load:
    Zephyr
    Stylus: True Nude Elliptical, 0.120mm SQ
    Recommended Tracking Force: 1.8-2.2 gm
    Compliance: 10 µm/mN
    Body material: Corian and Brass
    Frequency Response: 15-45,000 Hz (±2.5 dB)
    Channel Separation:
    1000 Hz: >38 dB
    50-15,000 >25 dB
    Channel Difference: <0.5 dB
    Output Voltage: 2.4 mV
    Weight: 10.27 Gms
    Load:
    Aida
    Anmeldelse af Soundsmith Aida fra Audio Ideas her
    Stylus: Contact Line NUDE, 0.100mm SQ
    Radius of curvature: Optimized Contact Lin
    Cantilever: Ruby
    Recommended Tracking Force: 10mN / 1.0 gm
    Compliance: 22 m/mN
    Channel Separation:
    1000 Hz: >30 dB
    50-15,000 Hz: >20 dB
    Channel Difference: <1.0 dB
    Weight: 6.8 Gms
    Load:
    Capacitance: >/= 400 pF
    The Voice
    Stylus: Contact Line Nude, 0.100mm SQ
    Radius of curvature: Optimized Contour Contact Line
    Cantilever: Ruby
    Recommended Tracking Force: 1.3 Gm
    Effective tip mass: 0.30 mg
    Frequency Response: 20-20,000 Hz (±1.0 dB)
    Channel Separation:
    1000 Hz: >30 dB
    50-15,000 >22 dB
    Weight: 6.8 Gms
    Load:
    Resistance >/= 47 kohms
    Capacitance: 100 - 200 pF
    Low output pickupper
    Paua
    StylusContact Line Nude, 0.100mm SQ
    Radius of curvature Nude Contact Line SELECTED
    CantileverTelescoping Aluminum Alloy
    Recommended Tracking force:1.7 to 1.9 Grams
    Effective tip mass 0.30 mgCompliance10µm/mN (low compliance)
    Frequency response 20-20,000 Hz ± 1.0 dB
    Channel Separation (stereo only)
    1000 Hz >34 dB
    50-15,000 >25 dB
    Channel difference
    <0.5 dB (Stereo)
    <1.0 dB (Mono)
    Output @5 cm/sec0.3 mV
    Cartridge weight 10.25 Grams
    Loading:470 Ohm model Standard
    Loading range 300-800 Ohms recommended load
    Sussero
    Radius of curvature: Optimized Contour Contact Line SELECTED
    Cantilever: Ruby
    Channel Separation:
    1000 Hz: >34 dB
    50-15,000 >25 dB
    Output Voltage: >0.3 mV
    Weight: 8.79 Gms
    Load: >470 ohms, 1k-2kOhms recommended
    Hyperion
    Radius of curvature Selected Diamond shapes: CL or Optimized (OCL)
    CantileverHand formed/treated selected Cactus "Spine"
    Recommended Tracking force:1.8 to 2.2 Grams
    Compliance
    (LT) 12µm/mN vertical/7µm/mN horizontal
    1000 Hz >36 dB (LT: > 34dB)
    50-15,000 >25 dB
    Channel difference
    <0.5 dB (Stereo)
    <1.0 dB (Mono)
    Output voltage: 5 cm/sec. Lat. RMS0.3 mV
    Load:470 Ohm model now available
nat
nat sine annonser
Et vell fortjent «BEST BUY» utmerkelse til den første testen av PMC sin nye Prophecy-serie.
The ear magasinet er først ute med test av Prophecy 5 og her er litt av hva dem skriver: “It’s the musical result that counts of course and that is spot on, the sound being just as crisp, relaxed...
Norsk Audio Teknikk Oslo HiFi Show.
Norsk Audio Teknikk med spennende gjester og nyheter på Oslo HiFi Show!
  • 1
Vi gleder oss til å delta, og vil ha to rom på messen i år. Du finner oss på rom 158 og 159, som er innerst i gangen. Toppfolk fra PMC og Bladelius På lørdag får vi besøk av kapasiteten Elliott...
NYHET. PMC Prophecy 7 på plass i demorommet.
  • 2
Forrige uke fikk jeg inn den nest største modellen i PMC sin nye Prophecy-serien. Nærmere bestemt Prophecy 7 som er den minste 3 veis modellen. Nå har jeg fått spilt på den noen dager og jeg er...
PMC sin nye Prophecy 1 og 5 er klare for demo!
  • 4
Da har de to minste modellen 1 og 5 i PMC sin nye Prophecy-serie fått spilt seg inn og er klare for "kritisk" lytting! De største modellen 7 og 9 kommer inn i starten av mars. Dette lover MEGET...
NYHET! Da er de to første PMC Prophecy modellene på plass i demorommet!
  • 23
Norsk Audio Teknikk og @Gjallarhorn Audio er de første som har fått inn de to minste modellene av det nye PMC Prophecy-serien. Det er Prophecy 1 og 5 som har kommet inn. Prophecy 7, 9 og C kommer...
