Fra hjemmesidene til Musical Fidelity:
"The X-DACv8's technical performance is right out with the very best available at any price. When compared to a kW25, apart from a different noise ratio, the X-DACv8 equals it in almost every department.
Sonically the X-DACv8 is virtually indistinguishable from the kW25. Only in the finest, most exotic, most expensive and most powerful system will the differences between the X-DACv8 and the kW25 become apparent.
When the technical performance and sound quality are coupled to its competitve price and multiple inputs including USB and X-DACv8 offers extraordinary value-for-money."
Yahoo! ;D
X-DACv8 Specs:
DAC circuit 24 bit Delta-Sigma (Bit stream) dual differential 8X over sampling
Up sampling 192kHz
Total correlated jitter <135 pS
Linearity <0.1dB down to -96dB
Output digital 0dB level 2.18VRMS at 1kHz nominal
Analogue output impedance 47 Ohms
Frequency response 10Hz to 20kHz -0.2dB max
Channel separation >105dB 20Hz to 20 kHz
Signal/noise ratio >117dB 'A' weighted
Total harmonic distortion <0.003% 10Hz to 20 kHz
Connections
Digital inputs 1 USB 1.1 [32, 44.1, 48 kHz sample rates] connection for computer only
3 S/PDIF (RCA connector)
Digital outputs 1 S/PDIF (RCA connector)
Line level analogue outputs: 1 pair RCA
Power requirement:
100 / 115 / 230Volts AC 50/60Hz (factory pre-set),
16 W no devices connected, idle
26 W all devices connected, idle
30 W maximum
O.
