Sitater om ekteskap......
OMF
Hei!
Skal holde tale i et bryllup om ikke så lenge, og tenkte jeg kunne krydre talen med noen morsomme sitater underveis....så hvis noen har lyst til å hjelpe så hadde jeg satt pris på det.... (Vil gjerne ha med referansen også...)....
OMF
Spiralis
Vet ikke om den passer men,.... ::)
To veninner diskuterte den enes nylig forestående giftemål.
Den vordende brud sa at hun ønsket et storslått kirkebryllup med et par hundre gjester,
men brudgommen ønsket noe mindre hos byfogden med bare de den nærmeste familien.
Da konkluderte venninen:
Da blir det hos byfogden. Du må huske at man alltid skal respektere en manns siste ønske! ;D
Paal_Iksom
Den gamle romantikeren Kant satte kanskje best ord på det, her i engelsk språkdrakt:
"THE SCIENCE OF RIGHT
by Immanuel Kant
translated by W. Hastie (modified by A. R. Pruss)
The Rights of the Family as a Domestic Society
Title I. Conjugal Right. (Husband and Wife)
24. The Natural Basis of Marriage.
Sexual intercommunity (commercium sexuale) is the use of the other's sexual members and faculties. This use is either natural, by which human beings may reproduce their own kind, or unnatural, which, again, refers either to a person of the same sex or to an animal of another species than man. These transgressions of all law, as crimina carnis contra naturam [crimes of the flesh against nature], are even "not to be named"; and, as wrongs against all humanity in the person, they cannot be saved, by any limitation or exception whatever, from entire reprobation.
This natural union of the sexes proceeds according to the mere animal nature (vaga libido [unsettled lust], venus vulgivaga [roving sexuality], fornicatio [fornication]), or according to the law. The latter is marriage (matrimonium), which is the union of two persons of different sex for life-long reciprocal possession of their sexual faculties. The end of producing and educating children may be regarded as always the end of nature in implanting mutual desire and inclination in the sexes; but it is not necessary for the rightfulness of marriage that those who marry should set this before themselves as the end of their union, otherwise the marriage would be dissolved of itself when the production of children ceased.
And even assuming that enjoyment in the reciprocal use of the sexual endowments is an end of marriage, yet the contract of marriage is not on that account a matter of arbitrary will, but is a contract necessary in its nature by the law of humanity. In other words, if a man and a woman have the will to enter on reciprocal enjoyment in accordance with their sexual nature, they must necessarily marry each other; and this necessity is in accordance with the juridical laws of pure reason."
*snufs*
Det var fest. Alle deltakerne var gift eller skilt eller hadde barn og var sånn omtrent 40.
En mannlig festdeltaker som virkelig var på høgbenet den kvelden (hans kone var bortreist) pratet opp og danset opp og drinket opp den vakreste av aftenens kvinner, og mente etterhvert at snøret var i bånn og at retrett med selskap i sengen var sikret. Da ble han prikket vennlig på skulderen av en mannlig festdeltaker:
-Tack för att ni har kåtat upp min fru. Nu skal vi hem.
Johny_Bravo
til OMF
Jeg har vært toastmaster i bryllup og ved flere anledninger. Hvis du vil ha mange morsomme sitater, kan du evt kjøpe deg en toastmaster bok, der får du mange råd på kjøpet også. På www.ordtak.no er det også mange sitater.
Et om ekteskap: Lucky Luke - ensom cowboy - som, jeg husker ikke helt i hvilken anledning, sier
noe i retning av:
"Ekteskapet er en forunderlig institusjon, det gjør at to mennesker sammen kan løse
problemer som aldri ville oppstått hvis de hadde latt være å gifte seg..."
Mest sannsynlig i heftet "Miss Jenny"; original: "La fianceé de Lucky Luke".
impulse
Hølen
Denne passer vel neppe i et bryllup med mindre brudeparet er tilhengere av litt svartere humor, but here goes. "En kone har man bare så lenge man er gift. En ekskone derimot, har man resten av livet." Akk, så sant. Og i enda større grad om man har barn sammen.
K
KindOfBlue
Ekteskapets lenker er så tunge å bære at det noen ganger kreves tre til oppgaven.
(Alexandre Dumas d.e.)
For å holde seg til tema:
Polyandri kalles det når en kvinne har mange ektemenn.
Vi kaller det Polygami når en mann har mange koner.
Har en mann bare to koner, så heter det bigami.
Og har han bare én, er det best å beskrive det som monotoni.
K
KindOfBlue
Skjønner vi har noe å snakke om når vi skal ha en lyttekveld! ;D
BT
Her er en som kansakje er litt for treffende til at den egner seg:
Hva er grunnen til at så få forhold varer livet ut?
Når en dame gifter seg forventer hun at mannen skal forandre seg. Men det gjør han ikke.
Når en mann gifter seg forventer han at kona ikke skal forandre seg. Men det gjør hun.
impulse
Hølen
Det tror jeg du har helt rett i, KoB....
På tide, forresten! Sender deg en PM.
coolbiz
Sydvestlandet
"I hele mitt liv har jeg elsket én og samme kvinne. Og den dagen min kone får vite dét, blir det et helvete."
;D
impulse
Hølen
;D
Glimrende! Den legges på minnet... ;)
OMF
Takker for inspill.....keep em coming.....
OMF
BT
;D
Denne må det nesten ha vært prins Charles som kom med... :eek:
Komponenten
En ektefelle er den fellen man går i når man gifter seg.
BT
-Hva vil det si å være forlovet, spurte lille Per sin far.
-Det er nesten som hvis du får ny sykkel i julegave, men ikke får lov til sykle på den før til våren, gutten min.
-Hmmm, men jeg får vel lov å ringe litt i bjella?
Spiralis
Psychonaut skrev:
Begynn med; Eg kondolerer ;D ;D
Eller du kan si:
Kjære brudgom. Nå er du gift, og hvorfor skulle nå du ha det bedre enn oss andre?
Denne har jeg vel tatt tidligere:
En skål til våre hustruer og kjærester. Måtte de aldri møtes! ;D
miata
Jeg har en T skjorte som passer for anledningen :)
