SACD med 192/24 PCM ut?
OivindJ
Her er det snakk om å plukke opp et ferdig konvertert signal, Bx.
Man skrev:
Ja, finner en ikke PCM-signalet noe sted på printet i en SACD-spiller?
K
knutinh
Neppe.
SACD må dekrypteres og kodes om til PCM før det kan sendes ut over en tradisjonell digitalutgang.
http://www.dvdupgrades.ch/product/M...t/Six_channel_S_P_DIF_output_board/24308.html
"The board does not circumvent any copy protection; all signals we do pickup are unprotected. Even the SACD signal is unencrypted but it has to be converted to PCM for compatibility. That's where around 90% of our 1.5 manyears of engineering went...
Men disse konverterer altså til PCM før transmisjon.
http://en.wikipedia.org/wiki/Super_Audio_CD
"There is currently no way to pass an unencrypted stream of DSD out of an SACD player. There are currently a small number of players that offer a Firewire DSD output but the content is encrypted. HDMI 1.2, standardised in 2005, can also carry encrypted DSD, but as of October 2006, there are very few A/V processors that support this (such as the Marantz SR7001), and no SACD players."
En mulighet hadde altså vært å generere en firewire/HDMI DSD-strøm, men ukryptert. Dette hadde sannsynligvis blitt et større ASIC-prosjekt, og gevinsten er vanskelig å se. Kanskje hadde det blitt litt enklere å rippe for pirater men:
"If you intend to copy the signal using our card: Don't mind, rip it directly. In the DVD player you will find a clock line and a data line for every channel pair. Each clock cycle means one bit of audio data. You can easily sample this using a digital sampling card and using some minor documentation and programming skills you can reacreate a WAV file"
Knut
K
knutinh
Nei, siden en SACD-spiller benytter DSD i stedetfor PCM så finnes ikke PCM-signaler noe sted.
Knut
Bx
Knut
Jeg har hørt flere positive rapporter på den løsningen der.
Tror ikke denne løsningen hadde overlevd det amerikanske retssystemet, så vi skal kanskje være glad for at det fortsatt finnes noen "annerledesland".
PPCM-ripper softwaren som var ute for en stund siden tappet ukryptert DVD-Audio når det ble avspilt over Win-DVD. Den løsningen forsvant fort fra nettet når advokatene begynte å rasle med mobiltelefonene.
K
knutinh
Men neppe ut fra P2P ;-)
-k
