Produkter fra MBL!!!
Odder
http://www.mbl-germany.de/english/start.html
Dette er noe av det råeste jeg har sett!!! Ser ut til at det er mulig å få til et temmelig rått anlegg med disse produktene....
CD-drivverk og DAC'en har en pris på 42.500 USD...... Er det noen som selger dette i Norge??
Eller hva med Einstein Audio???
http://www.einstein-audio.de/netscape_version/index.htm
NB! det er kun den tyske "deutch" sia som funker!!
Jeg er imponert over hva tyskerne kan!! Har selv ASR forsterker og er meget godt fornøyd!!!
Vel, vel..... det er lov til å drømme videre. Har som mål at drømmer skal bli virkelig!!!! HALLELUJA!!!! ;D
wizard
Lyden er også imponerende iflg. siste TAS.
Fra Editor's Choice Awards
MBL 9011
MONOBLOCKS
$74,000
Driven by the MBL 6010 D preamp,
the massive, super-powerful,
ultra-expensive MBL 9011
monoblocks are superior by a
wide margin to any other solidstate
and, frankly, to any other
tube amps JV has auditioned
past or present.
The ne plus ultra of front-to-back transparency,
low-level resolution,
large- and small-scale dynamics, low-end extension, detail, authority (unbelievable!), and
treble speed, detail, and punch, the 9011s are also blessed with gorgeous tone color and a
top-to-bottom liquidity that JV
has never before experienced
with transistors.
The first amplifiers JV has heard that
fully combine the signal virtues
of solid-state amps (extension, resolution, speed, sock) with those of triode tube amps (liquidity,
rich timbres, and very low-level harmonic and dynamic
detail), giving you nearly the whole note of any instrument, from starting transient to (and
this is a first with solid-state) lingering decay.
MBL 6010 D
$18,920
In many ways, the MBL 6010 D is not just the best solid-state preamp, it is the best preamp JV has
auditioned. Its noise floor is so incredibly low that it consistently resolves fine harmonic and
dynamic details that simply aren’t audible on other very fine preamps.
At the same time its transient speed and authority are
beyond compare. (The thing is in a class of its own when it comes to the bottom octaves—and the
top ones.)
To ice the cake, it has absolutely gorgeous tone color,
the same liquidity and transparency that so distinguish MBL’s 9010 amps, excellent imaging and
soundstaging (though JV has heard its superior in stage width), nonpareil ambience retrieval, and
the kind of living presence that can make instruments and vocalists sound “there.”
There was a time when JV thought tubes
owned low-level resolution, particularly
with instrumental decays.
The 6010 D has shown him that
that time has come and gone.
MBL 1621 A CD TRANSPORT AND
1611 E DIGITAL-TO-ANALOG CONVERTER
$42,510 ($21,010 and $21,500)
If you’re heavily invested in Red Book CD, you may not know how good it can get until you audition
this pricey-but-worth-it transport and DAC from MBL.
If there is better CD playback, JV hasn’t heard
it—and he’s heard and reviewed some mighty fine CD and SACD players.
It isn’t just the magical level of musical detail—much of it
previously unheard—that this combo is capable of eliciting from silver disc, nor its unusually lifelike
timbres, nor the unparalleled extension, definition, and slam of its bass.
It is the MBLs’ overall gestalt—the analog-like taste of
dimensionality and solidity that it adds to virtually every CD—that truly astonishes.
No, the 1621/1611 isn’t a Walker turntable; it is darker, less delicately detailed, airy, bloomy, and
3-D than great analog playback.
That said, it comes as close to LP’s virtues as any CD player JV has had in his system, with the bonuses of CD’s superior bass, sea-swell large-scale dynamics,
lightning transients, and often astonishing clarity.
MBL 101E
$46,900
MBL’s stunning-looking, four-way, omnidirectional adialstrahler References simply do it all: a treble
like Maggie’s ribbons, a midrange like SoundLab’s ’stats,
bass like Nearfield’s eight 18" subwoofers, soundstaging and coherence like Kharma’s RM 3.2s,
dynamics like Avantgarde’s Trios, and a “disappearing act” second to none.
To top all this off, the 101 Es have more lifelike presence
than any speaker JV has heard in several decades—actually sounding “fool-you” real at select moments on select cuts— and are more convincingly stereophonic
listened to off-axis than anything else around.
Like the 111 Es, the 101 Es require careful room setup and treatment and, unlike the 111s, they are a bear
to drive.
For the ultimate in sonics (the best, overall, JV has heard in his home), you will also need the MBL 6010 D preamp and 9011 monoblock amplifiers—making for
a very expensive system.
That said, the 101 Es also fare quite well with much more affordable Edge, Pass, Joule, and Kharma
amplification.
JV’s new reference.
wizard
Dette settet fra Krell er like bra som MBL iflg. tyske bladet Audio.
MBL 9011 og Krell Evolution får samme poengsum 130.
Kobles Evolution settet sammen med Cast kabler, skal lyden bli bedre iflg. Audio og poengene går opp til 135.
soundscape
Nordre Follo
MBL ser veldig spennende ut, skulle vært artig å hørt referanse-høyttalerene deres.
wizard
Stor strømforsyning i hver 9011!
I mono yter den 1100 watt i 4 ohm med en dempings faktor på ca 1000; bra kontroll på høytaleren har 9011.
Par den med f.eks Tidal sine mastodont høytalere (enda flere tyskere), Accuphase C-2800 Kontrollforsterker og f.eks Accuphase sin nye sacd spiller DP-78 = megalyd.
Rudi
MBL, har i en årrekke laget herlige "fly"-end produkter. MBL har bla alltid hatt enorme mono blokker, dette for og drive sine egne meget effekt sultne høytalere, mener og huske at de store har en effektivitet på 82 db, men tåler "allt" så man kan spille brakende høyt bare man har et effkt trinn som leverer en kilowatt eller to........... og det gjør de digre mono monsterne til MBL glatt.
MBL og Burmester knivet tidligere alltid om og ha det aller "værste" på messene rundt omkring, men nå de siste par-tre årene har Burmester inntatt en noe mere "folkelig" tone enn det MBL har etter min mening, MBL kjører fremdeles hardt på "the ultimate" linjen.
For de som var på siste CES så husker vel de fleste det perverse anlegget MBL brukte der. (hadde jeg skjønt noe av hvordan man la ut bilder her på forumet skulle dere fått sett hva jeg mener). Men nå er det snart CES igjen så det er bare og ta en Januar tur og ta en titt, jeg er ganske sikker på et MBL stiller ut igjen.
LuckyLuke
Lillehammer
Hørte på MBL værsting demo på messa i Berlin, det låt bra det kan man trygt si...
Tom
LuckyLuke
Lillehammer
Men man må være "venn" med elkraft leverandøren, for MBL krever utrolig mye "strøm"... ;-)
Odder
Er det noen som har sett eller hørt CD-spillerne/driverkene og dacene til MBL??? Blir nok litt i overkant med noen av de monotrinnene, men en CD-spiller skal vel ikke gjøre en konkurs i forhold til strøm.......?
LMC
Drøbak
MBL prisene i USA er LATTERLIGE!
men de har lagt seg på linjen:
"if you have to ask,you probabaly can´t afford it!"
sammen med en del andre har de funnet ut at de med MYE penger ikke finner noen glede i å handle om de ikke "kjenner det litt"! STATUS BØR SVI? ???
Husket jeg vurderte MBL 101 D radialstrahler da jeg kjøpte mine seneste Wilson,men etter å ha sjekket litt rundt(bl.a. med Ken Kessler) valgte jeg Wilson.
tror det var i 98
da kostet 101d tilsv. 70.000 på export.
derfra til US $ 47.000,- er en LAAAANG vei.
IMO
Leif
Rudi
Lotto ??? ØY feiging !!!!! slå deg på brøstkassa nå og pantsett huset over skorsteinen og trå til med noen alvorlige rørselder og noen grosse MBL'er og inngå deretter en spesial avtale med din lokale kraftleverandør om halve produktionen dem's  ;D
Hmmmmmmmmm kanskje vi gutta skulle lage vår's noen T-skjorter med påskriften "jeg har tatt en heeeeelt ut"  ;D og på baksiden: "livet er bare rør mit ein rundsthraler"  ;)
Audiophile-Arve
1. Lotto ??? ØY feiging !!!!! slå deg på brøstkassa nå og pantsett huset over skorsteinen og trå til
2. Hmmmmmmmmm kanskje vi gutta skulle lage vår's noen T-skjorter med påskriften "jeg har tatt en heeeeelt ut"  ;D og på baksiden: "livet er bare rør mit ein rundsthraler"  ;)
1. Er alt gjort........
2. Har alt T-skjorte (som eg fekk i posten) med statusmotiv (Popquiz)
Trane
Perler for svin i Berlin
Siden jeg første gang for flere år siden så bilder av og leste om radialstrahler'ne har jeg vært fascinert av dem...både konseptet og det visuelle uttrykket som man bare ikke kan forholde seg nøytral til....over the top, men likevel så funksjonalistisk.
Likevel klarte jeg ikke helt å la meg begeistre da jeg første gang så dem i Berlin for er par år siden. Det legendariske kjøpesenteret KaDeWe hadde full range fra MBL utstilt i sin elektronikkavdeling. Midt i det hele tronet full pakke med det råeste av det råe...det dyreste av det dyre...de enorme monoblokkene, lyn gordon-høyttalerne, top-loader cd-spinner...alt i deres typiske blanke sorte og blinkende gull......minst et halvt tonn svindyr hemningsløs high-end lekkerier....og totalt porno! For mye er nå engang for mye.....selv high-end porno som dette.... det minnet mest om en 500 kilo stor skinnende sort kjempeståpikk med enorme gulllenker drapert rundt omkring...
...det aller mest nedtrykkende var imidlertid hvor jeg fant det.....elektronikkavdelingen på KaDeWe er omtrent som et svært Elkjøp med større prislapper...midt i dette enorme ingenting av et utstillingslokale stod altså totalt pornofisert potensiell godlyd verdt 1 mill ++...til ingen nytte selvsagt...såkalt "silent display"? hva skal man gjøre ? Jeg klarte hverken gråte eller le...men lusket ut en hifi-illusjon mindre.
....men jeg har fortsatt fantasier om et par radialstrahler'e....
