Pickup-Nyhet fra Acoustical Systems. The Fideles
Spennende saker i en helt annen prisklasse enn det som normalt kommer fra denne produsenten.
Alt som hittils har kommet fra Acoustical Systems har imponert meg stort! Dette er Tysk superkvalitet på sitt aller beste. Her er info fra produsenten.
We herewith proudly introduce the fideles - an all-new high-end phono cartridge.
„fideles“ derivates from Latin / German and stands for „faithful as well as agile and lively“.
Unusual in this price class, the fideles features a solid advanced Titanium Timet 1100 body of unparalleled energy transfer ability and unique combination of strength and light weight.
The generator system is a double-magnet - focused field - moving ferrum pipe - principle which gives a healthy high output of 5.5 mV.
Very easy handle for any phono stage and no need for a high-gain / moving coil phono input.
Any phono input with 35 to 50 dB gain and 47k to 100k impedance is fine.
The fideles’ Titanium body further features 3 rows of threads to allow perfect overhang in any headshell / tonearm.
The fideles produces a very dynamic, live-like, colorful, open, transparent and natural sound and performs solidly several steps above it’s price range.
It features very high trackability - above 90 µm! - and is very easy to align.
It’s relatively low body mass allows perfect synergy with a very wide selection of low to medium-high mass tonearms.
The fideles was designed to set a new standard in the US$ 1000-price range of phono cartridges - in terms of technical input, value for money and performance alike
the Fideles - technical specifications:
frequency response:
18 Hz – 25 kHz +/- 2 dB
channel balance:
within 0.8dB @ 1kHz
channel separation:
better than 25dB @ 1kHz
output voltage:
5.5 mV, 1kHz @ 5 cm/sec
static compliance:
35 mm/N
dynamic compliance @ 9-10 Hz:
17 mm/N
vertical tracking angle: 22°
Stylus: true elliptical 7µ x 2.5µ - factory replaceable
-Recommended load resistance:47 -100 kΩ
-Recommended load capacitance:
Phono cable + 0-max 200pF
-Cartridge body mass 9.5 g
-recommended tracking force
17 mN to 18 mN
The fideles is ready for order starting mid-September.
It will be introduced first at Hong Kong and Taipei Audio shows in early and mid August.
Prisen på denne vil være i underkant av 10.000,-
Tom Egil
Må være en skrivefeil - en så flott reklameplakat betinger sikkert i underkant av 100.000,- :cool:
Endpoint Audio
Tønsberg
Gull til gråsteinpris. Spitzenklasse!
Jeg er veldig spent på denne og har bestilt inn noen av de.
Kan være "referansekunde" :cool:
J
Jim I Hendriksen 2nd Edt.
Jeg trodde at alle kunder var "referansekunder"...?
Endpoint Audio
Endpoint Audio sine annonser
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
10/10 For Lumin T3
10/10 For Lumin T3
  • 1
High End streaming blir stadig bedre, og Lumin leder an med superb lydkvalitet og brukervennlighet. Alltid blant de første til å implementere nyheter - og de første som fikk på plass Tidal MAX...
