Nyhet! YBA Design Line YM302 Streamer DAC
Da kan vi meddele om at YBA sin YM302 Streamer/Dac fra deres Design Line serie er klar for markedet:)(y)
Pris 40.900.-
Introtilbud ut juli 35.800.-
Sound of Heaven
Tlf:+47 464 29 861
E-mail: kontakt@soundofheaven.as
Hjemmeside: www.soundofheaven.as
New Generation of Smooth Streaming
YM302 is the first device featuring our newly developed Linux streaming platform, optimized for simplified and faster controls, putting higher emphasis on the remote operations thanks to the full integration of Tidal Connect, Qobuz Connect, Apple Music* (Limited Support) and ROON Ready Certification.
USB port and SSD slot are prepared for gapless local playback of all types of Hi-Res files, with the Eddict Controller app for Android / iOS / iPad acting as the playback controller. And the industry standard support of DLNA and AirPlay 2 will take care of any other playback scenarios.
Built-in High-Fidelity DAC
Designed as a Multifunctional Music Source, YM302 comes with its own DAC and can be used directly with a power amplifier or active speakers for an excellent simplified setup. Utilizing the latest generation of Japanese AKM DACs, adapting the recently released AKM AK4497S DAC, a perfect choice for both YBA tuning and highly accurate sound reproduction. Paired with dedicated 45.1584/49.152 MHz oscillator clocks for the most accurate signal processing with reduced jitter and with full support of Hi-Res Audio playback up to PCM 768kHz and DSD512.
Extra Large Screen, Same Compact Size
The front of YM302 features our biggest 8.8-Inch touchscreen, providing crystal clear information on current playback and serving for quick on-device access to playback controls and a range of basic settings. Yet fitted into the same robust CNC-machined aluminium body as our other Design models, reducing needed space and making YM302 ideal for desktop rigs or any dimension-limited Hi-fi racks.
The Most Versatile Audio Component
Packing a range of features and options to make it a versatile partner for the widest range of audio setups:
External CD Drive support for Playback and Ripping; Line-Out or Pre-Out mode for matching with pre-amplifiers or pure power amplifiers; HDMI ARC for integration into home cinema; Range of digital outputs for connecting to external DACs; LAN and premium quality SFP wired internet connection.
Product typeStreamer Transport
Dimensions320 x 260 x 88mm
Weight5.9kg
SystemLinux-based, In-House developed
Screen8.8-Inch Touchscreen, 480 * 1920
Streaming ServicesTidal Connect, QOBUZ Connect, Roon Ready, Apple Music
(Apple Music Limited to 44.1/48kHz Playback)
USB Drive PlaybackOne USB Port on rear, up to 2TB drives
SSD SlotBottom of device, M.2 NVMe Compatible (SSD Not Included)
Hi-Res file supportDSD (“.iso”, “.dsf”, “.dff”)*
ISO/DXD/APE/FLAC/WAV/AIFF/AIF/DTS/MP3/WMA/AAC/OGG/ALAC/MP2/M4A/AC3/M3U/M3U8/OPUS
*DST not supported
Internet ConnectionWi-Fi, LAN Ethernet Port & SFP Port
Additional StreamingDLNA, Airplay 2, NAS
CD PlaybackWith External USB CD Drive (Not Included)
Supports Playback & Streaming
Playback ControlsTouch Screen, Eddict Controller app
D/A ConverterAKM AK4497S
Analog OutputsRCA & XLR Balanced (Pre-Out or Line-Out)
Digital InputHDMI ARC
Digital OutputsOptical, Coaxial, AES/EBU – PCM 24/192 kHz and DSD64 DoP/D2P
USB-A & I2S – PCM 768 kHz & DSD512 Native
Output LevelLine-Out – RCA – 2.64V // XLR – 5.27V
Pre-Out – RCA – 2.24V // XLR – 4.48V
SNRRCA – 121dB // XLR – 125dB
Channel SeparationRCA – 120dB // XLR – 122dB
Dynamic RangeRCA – 121dB // XLR – 125dB
NoiseRCA – 113dB // XLR – 110dB
THD+N0.00035%
Frequency Response20 Hz – 40 kHz (-0.5dB)
Power Supply48VA Iron-Core Transformer made in Germany
sound of heaven
sound of heaven sine annonser
Opera Prima V2 - Secrets of Home Theater and High Fidelity
Strålende test av Opera Prima V2 fra deres nye Classica Line serie (y) Noen utdrag: Opera’s Classica Prima v2 Loudspeakers play easily to high volumes without harshness. With a massive sound...
Nytt merke hos Sound of Heaven - SHANLING
  • 1
Sound of Heaven gjenintroduserer Shanling på det Norske markedet med deres splitter nye modeller CT90 og SM90. Når det kommer til ytelse, pris og kvalitet så mener vi at Shanling har satt en helt...
Indian Line Utah serie
  • 1
Indian Line sin nye serie Utah med modellene Utah 5 og Utah 8 står nå ferdig innspilt og klare for demo i våres show rom (y) Tilbakemelding fra fornøyd kunde:) Hei Jess! Ja dette var herlige...
Franco Serblin Accordo Unica - test i Hi-Fi Plus
Strålende test av Franco Serblin sin nye topp modell Accordo Unica i Hi-Fi Plus :) Noen utdrag: This is a loudspeaker that treats music with ` generosity ` . That sounds quite abstract, but a...
Introduksjonstilbud - Takumi
Introduksjonstilbud på Takumi platespiller og pick up ut mars mnd. Vi vil nå tilby en ferdigsydd pakke fra Takumi bestående av dere kritikerroste TT 2.1 DC platespiller med deres Kuro mc pick...
Takumi Moving Coil Cartridge Series - priser klare
Takumi Moving Coil Cartridge Series The Takumi range of moving-coil cartridges is designed and hand-assembled with one clear purpose: to extract music from the groove with precision, stability...
