Nyhet Accustic Arts
Miles
Fredrikstad
Accustic Arts PLAYER ES
PLAYER ES highlightsPremium CD player and high quality D/A converter in one unit
High precision 24 bit/192 kHz upsampling technology
High end tray loading CD drive mechanism (vibration de-coupled), which has exclusively been designed for audio applications
Damped, high quality drawer made of aluminium-ABS-compound guided with two metal bearings
Separate D/A conversion function with 2 digital inputs: 1 x coaxial (RCA) and 1 x USB 2.0
Easy playback of different audio formats (WAV, FLAC, MP3 etc.) from PC or laptop via USB interface ("Plug and Play")
4 separate, generously dimensioned power supply units for laser control, digital signal processing, display control and D/A converter section
Very high power supply capacity (more than 70,000 µF in total)
Spatial separation of analog and digital section within the D/A converter for best possible signal-to-noise ratio
Resonance minimising metal housing
Front panel made of finely brushed aluminium; tray cover made of massive and chromed brass
ACCUSTIC ARTS® system remote control SRC II
ACCUSTIC ARTS® PLAYER ES is "Handmade in Germany"
Miles
Fredrikstad
Accustic Arts Power ES
POWER ES highlights
Audiophile integrated stereo power amplifier with high output performance
4 selected MOS-FET output transistors of highest quality
330 VA toroidal core transformer of premium quality for high output reserves; separate windings for preamp section, for power amp section and for right and left channel
Very good smoothing thanks to more than 50,000 µF power supply capacity
High damping factor for perfect speaker control
Integrated protective circuit switches ascents off when clipping,
HF oscillations or too high DC offset occurs
Constant low operating temperature due to generously dimensioned heat sink
4 x unbalanced high level inputs (RCA)
1 x unbalanced input (RCA) configured as "SURROUND-BYPASS"
Premium quality relays and premium quality rotary switch with gold-plated silver contacts for the input selection
Encapsulated high grade volume potentiometer including remote-control
Full metal housing for optimum shielding
Front panel made of brushed aluminium; turning knobs made of massive and chromed brass
Optional high quality phono stage (MC/MM); RIAA precision: +/- 0,15 dB
ACCUSTIC ARTS® POWER ES is "Handmade in Germany"
Miles
Fredrikstad
Nyheter : Accustic Arts
Den nye TUBE-PREAMP II i fra Accustic Arts.
ACCUSTIC ARTS TUBE-PREAMP II
Audiophile reference preamplifier with a so called "tube hybrid"? concept and 4 military tubes (2 tubes per channel)
Fully balanced circuit design from input to output
Advantages of this "tube hybrid" technology:
- very high bandwidth
- very low distortion factors and a "good-natured" distortion spectrum
- "analog" and very precise sound performance
- 4 separated amplification paths, which are not influencing each other
Easy change of tubes without any adjustments just "plug and play"
Professional Class A output stage using technology derived from studio engineering
All used components are of outstanding quality (e.g. Burr Brown® OPA 627) and additionally selected; all relays have high quality gold-plated contacts
4 high precision military tubes; 4-times selected
Premium quality rotary switch with gold-plated contacts for input selection
4-channel volume potentiometer for best crosstalk
2 magnetically shielded, encapsulated 75 VA toroidal core transformer ("Made in Germany") of premium quality for high output reserves
3 x fully balanced high level inputs (XLR) and 2 x unbalanced high level inputs (RCA)
2 x fully balanced outputs (XLR) e.g. for Bi-Amping configurations and 1 x unbalanced output (RCA) e.g for a separate active subwoofer or an unbalanced working power amplifier
Front panel, top cover and remote control made of massive and solid aluminium; turning knobs made of massive and chromed brass
The ACCUSTIC ARTS® TUBE-PREAMP II is "Handmade in Germany"
Miles
Fredrikstad
Siste tester av Accustic Arts :
USA:
Soundstage reviewed the DRIVE II and TUBE-DAC II SE combo and awarded them with the SELECT COMPONENT award:
The full review may be found here:
http://www.ultraaudio.com:80/index.php?option=com_content&view=article&id=57
Germany:
Germany's number one high end magazine STEREO reviewed the TUBE-PREAMP II in their latest edition, awarding it with an incredible 100% rating
The TUBE-PREAMP II and the AMP II - MK 2 are now the best preamplifier/amplifier combo in the reference class in the whole testing history of STEREO.
