Alternativene til MiniDsp er ikke så altfor mange. Enten blir det svært dyrt eller man må se på Prosegmentet eller PC varianter.
Her er et nytt engelsk firma CoLinear Acoustics som har lansert noe som ser ut som et meget godt alternativ. 2 inn 8 kanaler ut. Og prisen er til å betale. Svært god spec ser det ut som.
DSP 8C heter boksen
CoLinear Acoustics | Engineers of Pioneering Hi-Fi
Omtalt i AudioXpress ; CoLinear Acoustics Debuts with DSP-8C Audio Processor and Preamplifier | audioXpress
SPECIFICATION
Input / output channels
2 / 8
Total harmonic distortion + noise
Up to -127 dB1 / 0.000045%, unweighted
Dynamic range
131 dB, A-weighted
Output impedance
95 Ω (single-ended)
190 Ω (balanced)
Full scale voltage output
2.00 V to 2.50 V in 0.05 V steps (single-ended)
4.00 V to 5.00 V in 0.10 V steps (balanced)
Frequency response
20 Hz – 20 kHz ±0.2 dB
Processing resolution
up to 24 bit / 192 kHz
Processor
1 GHz 32-bit floating point SHARC+ architecture with inbuilt FIR and IIR accelerators
Digital-to-analogue conversion
8-channel ES9039SPRO DAC with HyperStream IV architecture
Inputs
all at up to 24 bit / 192 kHz
1 x USB audio (UAC2)
1 x S/PDIF coaxial
1 x S/PDIF optical
Outputs
8 x RCA, single-ended
8 x XLR, balanced
IIR filters
Input channels: up to 60 biquads, combined
Output channels: up to 288 biquads, combined
FIR filters
at 96 kHz
Input channels: up to 16,384 taps, combined
Output channels: up to 32,768 taps, combined. Max 4,096 per channel.
at 192 kHz
Input channels: up to 8,192 taps, combined
Output channels: up to 18,432 taps, combined. Max 4,096 per channel.
Software control
DSPconfig
Windows/macOS/Linux
Dimensions
330 x 180 x 70 mm (W x D x H, overall)
Weight
1.55 kg (net), 2.2 kg (gross)
Accessories
1 x infrared remote control
1 x 22.5 W universal AC adapter
1 x 1.5 m USB-A to USB-B cable
DSP 8C heter boksen
SPECIFICATION
2 / 8
Dynamic range
131 dB, A-weighted
Output impedance
95 Ω (single-ended)
190 Ω (balanced)
Frequency response
Processor
Inputs
1 x S/PDIF coaxial
1 x S/PDIF optical
Outputs
8 x XLR, balanced
IIR filters
FIR filters
at 96 kHz
at 192 kHz
Software control
DSPconfig
Windows/macOS/Linux
Dimensions
Weight
Accessories
