Diverse No topic, anything goes-tråden
  • Z
    Zomby_Woof
    Jeg tror jeg har latexallergi. Hver gang jeg tar på meg latexhansker begynner det å klø i ansiktet. :-\
    tkr
    Nede i fjæresteinene
    ottone skrev:
    Gubra skrev:
    I tilfelle du har problemer med tung snø.............
    Slapp av, problemene er over :)
    Begynner nesten å svette, koks-ovnen har ikke brent ut ennå.
    Det er faktisk så mildt ute at 2 transistorforsterkere er nok til å holde lunken i stua.
    ottone
    Nesten klassiker
    Har rør-monoblokker på loftet. ;D
    Klestørken går unna på få timer.
    tkr
    Mine står i stua. Sparer mye ved med det.
    Heldigvis er den ene defekt akkurat nå, så jeg måtte kople opp transistor-reserven. ;D
    noen
    Gammelt nytt, "databladet" for dd's z-serie:
    http://ddaudio.com/caraudio/Woofers/Z/Specs.aspx
    The Z series represent the pinochle of transducer archeology. The unique design dates back to the precocious era of unequivocal magnetism and the vector planar research of underwater acoustic proliferation. The open archeology concentrates flux lines in the magnetic gap while side lobbing interference cancels stray flux from entering the atmosphere. The result is increased efficiency over the entire bandwidth of collaborating bass frequencies. This allows the Z Series woofers to play amazingly loud with little wasted energy being dissipated as unwarranted heat, this means they get on it and don't get real hot.
    The Z Series breaks new ground in rare earth magnetics, using newly discovered material, neo-demetrious iron proton (Ned), incalculably more strenuous than the other discovered rare earth magnet material. Ned is highly unstable and very difficult to modulate, yet alone saturate, so its use is mainly limited to noncommercial phase generators used in anti-matter plasma generation. Digital Designs has acquired the rights to use Ned magnetics in non-military acoustic weaponry and the peaceful development of humanistic cohesion through harmonizing wave generation. The unstable Ned blocks are held in symmetry by the side lobe interference which allows the use of the catchy monolithic block shapes from that cool 2001 space movie. These are spatially arrayed to over saturate the Permendur top plate imported from Switzerland, from one of those really beautiful, lake filled mountain valleys, giving huge magnetic energy to drive the voice coils.
    The moving parts of the Z Series have undergone a minute amount of scrutiny also, the cones feature newly contrived composite materials to handle the extra load lines emulating from the motor, the voice coils are spiral wound in reversing layer directions for optimum efficiency and the voice coil former is really strong. The combined technological oeuvre nearly eliminates all chance of spurious effluvium from occuring. The spiders also feature new technology never found on arachnid based suspensions, silkaleneotton. Genetically altered spiders produce a chemical blended thread of silk, polyethylene and cotton. This synthetic blend is superior to our other synthetic blend. The new synthetic blend is stronger than standard arachnid fiber, more flexible than polyunsaturated polyethylene, lighter than water (it actually floats) and yet so soft and comfortable. This material can stretch to 1.7 times its weight, allowing for un-presidential travel.
    The new Z Series woofers have more Watts than any speakers we have ever built, so many Watts they got, that we thought of using a new slogan, Got Watts?, but that's lame so we didn't. We tried to measure the exact amount of Watts a Z Series put out, but all we got was dBs.
    I tilegg til at elementene deres har enormt med watt har de mulighet for å spesiallage membran etter kundens ønske:
    The DD Customs page is dedicated to showing the possibilities a customer has when ordering a custom built speaker. Digital Designs is the last of vertically integrated American manufacturers of precision built speakers This allows us to build just about anything we want, or that you want. We have new composite cone molds which expand our offerings from the 1508 woofers to the upcoming 9922. Composites can be ordered for all 1500, 2500, 3500, 9500 and Z Series woofers. The 1500 and 2500 Series are ideal when high performance is needed along with lower system weight goals.
    Composite cones are vacuum molded and baked for 24 hours. Custom colors can be applied on the front of the cones with a supplied automotive paint code number. It is possible to have the cone fronts match the paint on your ride.
    We can also offer custom printing directly onto the composite materials. This opens up many graphic possibilities to be laid onto the front of the cones, jersey numbers, album covers etc.. Anything that can be graphically created becomes possible to lay up.
    We have the capability to lay up wood veneers directly onto the sandwich construction. We can also lay up virtually any composite material that can be found.
    ottone
    Nesten klassiker
    De jævlige nyhetene fra Japan får meg til å krympe innvendig og fryse tvers gjennom.
    Så jeg må starte kull-fyrings-sesongen igjen. Grøss.
    -og på toppen av alt snør det kjerringer, og jeg kommer på at det er vinter i Nord-Japan også.
    coolbiz
    Sydvestlandet
    Brazilian Spider Bite May Become the Next Viagra
    Araknofile i alle land, foren dere.
    "Researchers at the Medical College of Georgia say venom from a spider native to Central and South America gives people four-hour erections, and could possibly cure some of the worst cases of impotence – cases not even Viagra could adequately treat."
    Spennende, men... "people"?? Får også damer 4-timers ereksjoner av giften?
    G
    Gjestemedlem
    Jag var på besøk på Rekstensamlingene i går. Du milde måne for en samling av tepper de har der. Det er virkelig helt sinnssykt. Det er tepper på veggene og gulvene(!) der med samlede verdier til flere hundre millioner kroner. Dette er en av de flotteste samlingene av slike tepper utenfor den arabiske verden. Og høyst sannsynlig den eneste plass i verden der man får lov til å gå på dem, ta på dem og ikke bare se på dem bak en glassvegg på 10 meters avstand mens olme soldater med maskinpistoler følger en med argusøyne. Denne samlingen er helt åpen for publikum så det er bare å ringe å gjøre en avtale hvis man har interesse av slikt. Det er virkelig en ubeskrivelig følelse å håndtere disse skattene.
    Et par dårlige mobilkamerabilder yter ingen rettferdighet:
    Z
    Zomby_Woof
    Synes dere er feige som legger dere om kvelden. Tenk på at jeg har nattevakt. Ta litt hensyn. Avisdeskene sover også, og jeg har lest ut internett!
    Jaerbu
    Hm.. Slike tepper i heimen ville gjort enhver sårtrengt oppussing overflødig. Ingen tungt bevæpnede vakter sier du? Uten beskyttende og/ eller armert glass forran? Og så i ett mer eller mindre grisegrendt strøk bare for å toppe hele kaka.
    Jeg er riktig nok full nå, men jeg kan glatt se for meg att en høy nok samtale med de rette tilhørerne, som kanskje tilogmed var fra balkan eller deromkringom, ville synes att denne "pengebingen" burde besøkes...
    Konspirasjonsteorier, ankepunkter, samt mer eller mindre gjennomtenkte planer for "overtakelser" av disse teppene kan gjerne postes under her. ;D
    Z
    Zomby_Woof
    Pussig opplevelse på 37-bussen i dag.
    Ikke smart å stå ved stemplingsautomaten når det er billettkontroll, gitt. Har aldri før hatt en så sterk følelse av å stå så jævlig i veien for så jævlig mange mennesker på en gang....
    tweakMan
    Go on Chewie, his arms...now!! NO!!! Wait... wait... he needs them to sign the papers, first...
    ottone
    Nesten klassiker
    Et høylydt hjertesukk dagen derpå:
    Jeg irriterer meg mørkegrønn på folk som gjør sitt beste for å ødelegge hele 1.april med å avsløre aprilsøker fortest mulig i full offentlighet. Noen begynner til og med tidlig på morgenen å ødelegge for folk.
    Aprilspøker er laget for å lure folk, og da skal man jo for svarte s... ikke fortest mulig rope ut at man tror man er så javla lur fordi man ikke lot seg lure!
    Enten får man holde kjeft eller så få får man være med på spøken og støtte opp.
    Hobbyødeleggere!
    :mad:
    Spiralis
    Hobbyødeleggere!
    :mad:
    Au !! Det gjorde vondt i ørene. Men jeg er helt enig.
    ottone
    Nesten klassiker
    Jeg blir så forbanna! Men ikke lenge. Og selvfølgelig ikke på viktige ting.
    Lurer på om det nærmer seg russetid kanskje?
    Hørte på et foredrag nylig, av en gammel luring, der det var snakk om å kontrollere sin irritasjon.
    "Hvis jeg noen gang skal få det godt, må de andre skjerpe seg! "
    Jeg var sikker på at den var til meg. ;D
    Hvem var det som fant opp 1.april egentlig? Han fortjener en blomst.
    noen
    En hyllest til mennesket og "våre" litt fjollete prestasjoner.
    Gubra
    Og for ikke lenge siden nevnte du den episoden med nakne russejenter?
    Hmmmmm, det begynner å danne seg et mønster...........
    ;D
    baluba
    Kopervik og Bergen
    ;D
    Jeg er ikke alene om den tanken altså... :-\
    Kjell_Kranzberg
    Brand new bestseller!
    "Mens guide to understand the opposite sex"
    ottone
    Nesten klassiker
    Noen sier at idag er årets mørkeste dag, andre sier at sola har snudd.
    Andre igjen minner meg på at det er jorda som har snudd.
    Mange måter å se det på. Påskudd til feiring er det i alle fall ;D
    ottone
    Nesten klassiker
    Man må ikke absolutt ha alkohol i julegløggen.
    Men du verden så mye bedre den blir med brun rom i :)
    ottone
    Nesten klassiker
    DER forsvant juletreet. Trist som faen.
    Lyden ble dårligere og.
    G
    Gjestemedlem
    Du kan jo hugge et nytt da, og pynte det med hjerter, påskaharer og drinkparaplyer. Så lenge det klassifiseres som et lydtweak er det ikke mer outrert med januargran i stuen enn mye av den andre audiofile juletrepynten som er å få kjøpt.
    Spiralis
    Nå Deph ??
    Er du på vei ut av skapet og erkjenner at du er en "TVILER" !! ?? !! :eek:
