Micromega med mange nyheter!
  • Micromega med NY DAC, RIAA og HODETLF.FORST.
    Micromega har lang erfaring med produksjon av Hifi produkter og har i tillegg til sine klassiske hifi produkter lansert My Range : et knippe produkter som er svært så rimelige men likevel gir ekstrem ytelse !
    Den rimelige DAC'en MyDac har allerede høstet awards som : 2012 Product of the Year(The Absolute Sound), 2013 Editors Choice(The Absolute Sound), 2012/2013 Hifi Choice Recommended, 2012 Diapason D'or osv osv.
    Fås i sort og hvit utførelse i en liten og hendig størrelse. Kan plasseres overalt. Valgstyring i front mellom innganger.
    Driver er svært enkel å innstallere.
    Og prisen ? KUN kr. 2995,- ink mva. MyDac har utklasset langt dyrere produkter, så man bør ikke la seg lure av den rimelige prisen.
    Technical characteristics
    USB Input working in asynchronous mode up to 24bits/192kHz and accepting USB audio class 1.0 and USB audio class 2.0 modes without any driver implementation for Mac and a custom Micromega driver for PC.
    Insignificant jitter in USB asynchronous mode thanks to two very low jitter master clocks ( 22.5792 MHz for multiple of 44.1kHz and 24.5760 MHz for multiple of 48kHz), with dedicated low noise power supplies.
    SPDIF 75Ω Coaxial input accepting levels as low as 0.2V p-p
    SPDIF Toslink Optical input
    Extremely low jitter in SPDIF mode (<50ps)
    2V rms full scale Analog output with low impedance driver
    Integrated universal power supply 85-265 Vac / 50-60Hz.
    Unique design, extremely fast, ultra low noise audio power supply
    No electrolytic capacitors in the audio section, neither in the audio low noise power supply, nor in the audio path.
    4 positions horizontal rotary switch with anodized aluminium wheel profile. Allows selection between STBY – USB – COAX – OPTO
    Elegant textured ABS housing available in 2 colors: White or Black
    Extremely low power consumption in standby mode ( <500mW) as well as in operation (< 2.5W).
    Product meet all the most stringent energy saving regulations.
    Hodetelefon forsterkeren MyZic kom like etter MyDac og har som MyDac startet med innhøsting av awards.
    Til KUN kr. 1995,- får man en fantastisk god hodetelefon forsterker som er enkel i bruk.
    Med føler på inngangen vil produktet stå i standby så lenge det ikke er tilkoblet hodetelefon.
    Har man hodetelefon, er MyZic den hodetelefon forsterker man bør bruke !
    Technical characteristics:
    1MΩ analog input to prevent loading source output stage.
    Analog output duplicating analog input to avoid the need for a Y connection.
    MyZIC matches with every headphone impedance and sensitivity.
    Log horizontal rotary control for a precise listening level adjustment.Minimal level detection putting MyZIC in standby mode.
    Out of standby delay to avoid any turn on thump.
    Professional Neutrik headphone 1/4” socket with headphone presence detection. When no headphone is connected, MyZIC will remain in standby mode.
    LED status indicator : Red when MyZIC is in standby and White in operation.
    85 - 265 Vac / 50 – 60 Hz switch mode power supply, designed by Micromega
    for exceptional sonics.
    Headphone minimal impedance ≥16Ω.
    Gain : 12 dB.
    Very low full bandwidth distortion ≤ 0,005% (20 Hz – 20 kHz).
    Very low IMD SMPTE distortion ≤ 0,002%.
    Full power bandwidth : 10 Hz – 100 kHz ± 0,5 dB.
    Signal to noise ratio > 115 dB A weighted.
    Textured ABS enclosure.
    Available in two colors : White and Black.
    Very low standby consumption ( <150 mW).
    Unit complies with most stringent power regulations.
    Det siste produktet så langt i My Range er det helt nye phonotrinnet/riaa : MyGroove !
    Et ubegripelig bra produkt i forhold til pris ! Tilpasser seg den enkelte pickup. Veksling mellom MM og MC i front som er spesielt kjekt for dem som bruker flere pickuper og veksler mellom MM og MC. Når man veksler mellom MM og MC går MyGroove i Mute, slik at man unngår høye lyder i høyttalerne.
    MyGroove koster KUN kr. 1995,- ink mva. Fås i sort og hvit.
    Technical characteristics :
    Differential analog input structure to avoid current injection into the cartridge.
    MyGROOV adapts to all type of cartridges despite of their impedance and sensitivity.
    Four positions horizontal rotary switch with anodized aluminum wheel.
    To select between STBY – MM – MUTE – MC
    Out of standby delay to avoid any thump at turn on and when switching
    between MM, Mute and MC.
    LED status indicator : Red when MyGROOV is in standby and White in operation.
    Integrated in house designed universal power supply 85-265 Vac / 50-60Hz.
    Unique design, extremely fast, ultra low noise audio power supply.
    No electrolytic capacitors in the audio section, neither in the low noise power supply, nor in the audio path.
    Cartridge load impedance : MM - 47 kΩ / MC - 100 Ω.
    Gain : MM - 40 dB / MC – 60 dB.
    Very Low THD (1 kHz) ≤ 0,001% MM, ≤ 0,005% MC.
    RIAA deviation < ± 1 dB (20 Hz – 20 kHz).
    Frequency response : 20 Hz – 20 kHz.
    Signal to noise ratio > MM - 88 dB ( A weighted) / MC – 76 dB (A weighted)
    Very low standby consumption ( <200 mW)
    For mer informasjon kontakt oss på epost med navn, adresse og tlf nummer på : informasjon@hifistasjonen.no
    Forhandlere kan kontakte oss på : forhandler@hifistasjonen.no
    WEB : Hifi Stasjonen - Main site
    Produsentens websider : Micromega-Hifi
    HoJ
    En glad amatør.
    Jeg har hatt MyGroov siden juni -14, og kan ikke si noe annet en at jeg er strålende fornøyd med dette produktet. Finnes det flere her ute med MyGroov?
Hifi Stasjonen
Hifi Stasjonen sine annonser
Monk Audio
Monk Audio
  • 26
Monk Audio Phono preamplifier : Et utrolig utvalg justeringsmuligheter. 3 innganger med valg MM eller MC. Separat strømforsyning. Det er også blitt utviklet en ekstremversjon av strømforsyningen...
Goldring Moving Coil Pickuper!
Goldring har produsert pickuper i over 100 år til svært rimelige priser. Goldring er rimeligere å kjøpe gjennom norsk forhandler enn privatimport, man sparer faktisk flere tusen kroner på enkelte...
Goldring 2000 Serien !
Goldring har produsert pickuper til platespillere i over 100 år og fremdeles håndlages pickuper på samme fabrikk i England. De senere årene har Goldring laget nye modeller i tillegg til...
Goldring med oppdatert informasjon!
  • 1
Goldring oppdatert sine websider ! Goldring har gått igjennom alle sine modeller og har oppdatert informasjonen på alle sine pickuper. Dette gjør det enklere å finne passende modell ved å lese...
Ny utstilling og ny Goldring demo
  • 3
Når det nå settes opp ny utstilling, vil det bli demo av flere pickuper! Alle Goldring pickuper som Hifi Stasjonen lagerfører vil være mulig å få demonstrert i begge showrooms. Det vil selvsagt...
Hifi Stasjonens nye utstilling begynner å komme på plass.
  • 4
Her er noen foreløpige og kjapt knipsede bilder med mobilkamera. Den nye utstillingen begynner å komme på plass, selv om mye mer skal på plass. Her er noen biter av det ene systemet som blir å se...
