8x12_TOM
Hvordan havner dette elementet ut på en simulering. Dette er de elementene jeg bruker.
Peerless 830952
Electrical Data
Nominal impedance Zn 4 ohm
Minimum impedance Zmin 3 ohm
Maximum impedance Zo 65.7 ohm
DC resistance Re 2.6 ohm
Voice coil inductance Le 1.6 mH
Capacitor in series with x ohm Cc -- uF
T-S Parameters
Resonance Frequency fs 19.1 Hz
Mechanical Q factor Qms 9.29
Electrical Q factor Qes 0.38
Total Q factor Qts 0.37
Force factor Bl 10.3 Tm
Mechanical resistance Rms 1.69 Kg/s
Moving mass Mms 130.6 g
Suspension compliance Cms 0.53 mm/N
Effective cone diameter D 24.4 cm
Effective piston area Sd 466 cm
Equivalent volume Vas 159 ltrs
Sensitivity (2.83V/1m) 91.2 dB
Peerless 830952
Electrical Data
T-S Parameters
