Har en forespørsel inne nå på en Jelco TK-950S men hvis jeg velger også gå for nytt driv da er jeg litt på tynn is ( vinyl entusiaster mobiliser gode forslag er nå kjærkommende )
S p e c i f i c a t i o n s :
model
TK-950S
Bearing System
Knife Edge
Effective length (from the tonearm pivot to stylus point)
232 mm
Distance of the tonearm pivot to spindle
214 mm
Overhang (spindle to stylus point)
18 mm
Offset angle
23.75°
Tracking error angle
+1.96° -1.03°
Horizontal sensitivity (first action, inner wire free)
30 mg
Vertical sensitivity (first action, inner wire free)
30 mg
Suitable cartridge weight with head shell
17~35 gr
Effective mass
13.4 gr
Range of height adjustment (distance between the arm base bottom and center of the arm pipe)
38~60 mm
model
TK-950S
Bearing System
Knife Edge
232 mm
214 mm
18 mm
Offset angle
23.75°
+1.96° -1.03°
30 mg
30 mg
17~35 gr
Effective mass
13.4 gr
38~60 mm
