Flytte et flygel
pengelek
Imorgen skal jeg hente et flygel. Det er 1,70 langt og jeg ville gjette på at det er ca. 1,55 i bredden. Da burde det veie rundt 300 kg etter litt research (?). Jeg tenkte rett å slett å frakte det i en skap-henger. Beinene bør vel skrues av før man begynner å flytte på det ettersom det ikke vil gå igjennom en dør med beina på. Lurer da på om det er OK å la det ligge vannrett i hengeren uten bein på? Er det noe spesiellt jeg bør tenke på? Tenkte at vi skulle være 4 voksene mannfolk. Noen synspunkter?
oddgeir
Pianos routinely make movers annual list of items that are most frequently damaged. Grand pianos are especially problematic. Practicing the following procedures for disassembling, padding and loading grand pianos will prevent damage, lower claims expense, and improve customer satisfaction.
At least three people are needed to handle a baby grand piano. If the baby grand piano needs to go up or down stairs or if a full or concert grand piano needs to be transported, a minimum of four people are needed.
Always complete a thorough and accurate inventory. It may be necessary or preferable to use a visual inventory to adequately describe and show pre-existing damage.
As various parts are disassembled, please place all hardware in a properly labeled parts bag and then place the parts bag in a "Parts Box".
Remove the music rack (lyre) from its track by pulling it toward the keyboard. Wrap it in a clean furniture pad.
Disconnect the lid by removing the hinge pins. Have one person wiggle the lid, holding it opposite the hinge, while a second person works the pin loose. Please be careful not to damage the wood with the pliers or with the pin itself. If necessary, cover the jaws of the pliers with a small cloth to help prevent damage to the wood. Wrap the lid in a clean furniture pad.
Remove the prop that holds the lid open and wrap it in a clean furniture pad. The prop has a hinge pin and is in two pieces.
Remove the pedal assembly and wrap it in a clean furniture pad. The braces at the rear of the assembly rest in slots at each end. When removing the screws, please be careful not to drop the braces. In addition, please be especially careful with the pushrods so that they will not get bent. As you face the piano, number the pushrods from left to right as "1", "2", and "3", by placing a piece of masking tape with the appropriate number on each rod. Note: If masking tape is unavailable, please use correctly labeled parts bags for this purpose. When reassembling at destination, please be sure to put the rods in the correct order so that the pedals will work properly.
Pad the piano by placing a clean rolled furniture pad (stretchwrap the pad to prevent it from unrolling) on the cover of the keyboard to prevent it from flopping open while you handle the piano. Cover the top of the piano with two clean furniture pads, neatly folded around the keyboard. Use rubber bands to secure the pads. Note: Please ensure that the surface of the piano is dust-free before padding it. Padding a highly polished surface that is dusty may cause fine scratches, especially on a black lacquer finish.
Position a piano board and attach the straps so that it is ready to receive the piano. The raised brace on the piano board should be at the keyboard end of the piano.
Remove the left front leg by positioning one person underneath the piano at the left end of the keyboard. The other two people should support the left front corner. The person underneath the piano must turn the retaining block so that the long end points away from the leg. The screws, if there are any, should then be removed. The "underneath" person should then get out from under the piano before actually removing the leg. Be sure to have two people lifting the corner of the piano while the third person removes the leg. Note: Please be sure to note which legs were removed from which positions since some pianos have legs that are not interchangeable.
Place the piano on the piano board by lowering the "leg-less" end onto the board. Please be sure to lift the entire piano slightly while completing this maneuver to prevent undue pressure on the remaining, attached legs as the piano tips. Lift the piano to an upright position on the board. Note: Please ensure that the soundboard is secure before lifting. Be sure that the piano is centered snugly against the brace at the end of the piano board. Note: Never leave the piano unattended. Always have at least one person holding the piano steady at all times.
Remove the two remaining legs and wrap them in clean furniture pads. These legs are held in place by a "key and slot" arrangement. To remove the leg, slide it inward toward the center of the piano until it comes out of the slot.
Secure the piano to the piano board by bringing the ends of the straps together and fastening them. Place folded burlap pads over the furniture pads but under the straps to provide additional protection to the edges of the piano. To prevent the strap near the narrow end of the piano from slipping off, tie the loose ends of the two straps together.
To move the piano over a flat, level surface, tilt the piano and piano board and place a four-wheel dolly under the center of the piano board.
To move the piano up or down stairs, use the piano board as a skid. After sufficiently padding the stairs for protection against residence damage, place the keyboard end of the piano toward the bottom of the stairs. Attach a hump strap to the top end of the piano board to prevent the piano from slipping.
To load the piano, leave it on the piano board and place it in a tier as the first base item with the keyboard towards the wall or the preceding tier. The best place to load the padded lid is between the piano and the preceding tier or between the piano and the wall.
Although grand pianos represent a significant challenge, they can be moved without damage by using common sense and practicing the procedures listed above. Best wishes for much success.
http://www.avatar-moving.com/gh_showarticle.asp?hid=59
Lykke til.
pengelek
Takk skal du ha, men det var litt mange "fag" uttrykk på engelsk der, noen som med raske stikkord kan si hva jeg bør gjøre før jeg begynner å flytte på det, evt under transport? :)
gubben
Flygel skal legges på høykant på en båre,ta av bein, lokk og lyre. Dette er expert tips fra junior , han er i faget...
Flygelet skal selvfølgelig stroppes i båren og embaleres.
Pass ryggen , du kødder ikke med tunge ting ;D
pengelek
Takk skal du ha:) Du vet ikke om det spiller noen rolle om det ligger vannrett eller på høykant under transport?
oddgeir
Her er oppskriften.
[video]z9Ucq7S476s[/video]
pengelek
oddgeir skrev:
Her er oppskriften.
Det der så fryktelig enkelt å greit ut på film, men har en følelse av at det er litt mer svette og tårer i morgen ;)
oddgeir
Lykke til. Husk at musikkinstrumenter skal behandles med den største respekt. :)
pengelek
Takk skal du ha :)
Kommer med en oppdatering her når det er vel, og trygt hjemme i stuen ;)
gismo
Væssia i Grue.
Skal det spilles på etter flytting, så flytt det på høykant.
Om ikke, kjør det vannrett ;)
gismo
Trane
....kiropraktorakutten på Lillestrøm....
ottone
Nesten klassiker
Ikke kødd med dyre musikkinstrumenter !
Ta kontakt med nærmeste anerkjente pianoforhandler, de kjenner til spesialister i flytte/transport-bransjen som virkelig kan dette. Du vil bli overrasket hvor raskt, trygt og effektivt de er i stand til å flytte et flygel.
Spiralis
Ikke minst når det gjelder ansvar og forsikring ville jeg ha overlatt dette til et SERIØST flyttebyrå. Et flygel er vel blandt de dyreste møbler man har i heimen skulle jeg tro? Vill ha irritert meg grenseløst om det ble ødelagt fordi jeg ville spare "småkroner". Småkroner i denne sammenhengen sett i forhold til flygelets verdi.
hel-elt
Hadde en nabo som flyttet for en tid tilbake, mye slit, men flygelet fikk han forhandleren til å ta. En mann! med de rette redskapene gjorde jobben!
Etterpå kom stemmeren og gjorde jobben ferdig.
N
nb
Bruk proffer, ikke en gang vurder å gjøre dette selv. Verdien på instrumentet er en ting, men det er heller ikke kult å ha hanket inn venner og bekjente og en av de får et flygel over seg i en trapp. Bruk et ordentlig firma som vet hva de driver med og som ikke minst har papirene i orden for forsikring av instrumentet og eventuelle skader på eiendommen det skal flyttes til og fra. De sjappene som forhandler flygler her i landet bør vite hvem som er egnet til en slik jobb.
Da kan du med god samvittiget drikke øl mens du ser på andre svetter.
Gubra
Enig med nb og ottone, det eneste fornuftige er å få fagfolk til å gjøre jobben!
Musikkmannen
I kjelleren
Litt teknikk og godt utstyr, kan gjøre jobben alene, men liker å ha med en kolega. Ta god tid så går det nok bra skal du se..
Musikkmannen
I kjelleren
Det mest ekstreme jeg har sett er en maskin som går opp trapper osv helt selv..
