Bruker ikke Transparent sine dyrere kabler ledere av UP-OCC Copper? Ultra-Pure, Ohno Continuous Casting Copper. Og ikke billigste type eller ofc.
I så tilfelle blir det feil med den DIY oppskriften som henviser til bruk av billigste type copper material.
Nå koster dog ikke occ copper like betydelige penger som ett sluttprodukt fra transparent men det er endel dyrere enn vanlig ofc copper, samt en skal passe seg for endel "fake" kabler som oppgir occ men inneholder ofc eller ledere av mer "uren" copper.
"Oxygen Free Copper (OFC) has undesirable effects that lead many to use more expensive materials such as silver for their conductive strands. As developed for A/V cable use, the OCC process utilizes a heated mold for casting and extruding, with cooling taking place in a separate process. The result is a larger crystal size and increased purity that approaches the 6N, 99.9998%! Looking at it another way, traditional copper has oxygen impurities of 200 to 500 parts per million (PPM), while traditional OFC copper reduces that to less than 10 PPM. With the OCC process, the figure is cut in half to less than 5 PPM of oxygen, and less than 0.25 PPM of hydrogen (compared to 0.5 PPM for OFC)."
