Eksotisk delefilter
Hornlyd
Musikkglad
Det høres fint ut. Men er dette bare flotte nye ord på å forklare et korrekt konstruert 24 dB filter (akkustisk)?
Det er litt andre greier i reklamen her som går på diffraksjoner, indre demping og demping av bassporten. Jeg registrerer at «Stealth» er et pop ord også for Sonus Faber når de legger litt dempemateriale rundt inni bassporten for å redusere turbulens.
At Gryphon har gjort det mulig å variere med bassport foran og bak er intet mindre enn genialt. Den skal de ha 👍
Og er det en fordel at diskanten ikke har reversert polaritet mtp impulsresponsen?
  • The Progressive Rounded Slope technology creates roll-off slopes that start with a very soft roll-off, ensuring perfect overlap and blending between the drivers. The slopes then become progressively steeper, effectively removing the out of band distortion from the drivers.
  • The crossover also aligns the phase response of the two drivers at all frequencies (measured from the listening position) thereby reproducing a life- like soundstage in width, height, and depth.
  • Both drivers are connected in positive polarity and their impulse responses are aligned perfectly. This means that musical timing is reproduced without any smearing or shifts – retaining the original musicality found in the recording.
