Edge NL Reference Monoblock Amplifier
endrea
Each side of the pyramidal NL Reference monoblocks starts out as a thick piece of aluminum.
Here we see one finished side resting against an unfinished slab of high-grade aluminum.
The milling machine that does the complicated machining of the aluminum sides.
The Leadwell MCV-760AP CNC Vertical Machining Center is a 3 Axis machine with a 10,000 rpm spindle,
24 position tool changer, and positioning accurate to
+/- .0002 inch
(+/- .0001 inch repeatability)
A look at one side that is partially completed. Note the array of tools on the spindle (similar to routing bits) at the top of the picture.
It is only during the final pass that the extraneous material of the rectangular slab is removed as the slab is cut into the actual pyramid shape.
The doors are closed and the milling process has resumed.
It is a noisy process no audiophile should suffer through for long without ear protection!
Water is sprayed during milling in order to keep everything at a reasonable temperature.
A close-up shot of the action
Another close-up shot of the action.
Yet another refinement pass has completed.
The coolant (water), still present, is unusually calm after each stage in the milling process. The impression is one of 'art in transition' from one state to another.
Each aspect of the milling process is designed in excruciating detail.
For example, notice the patterns inside the 'balanced/RCA' connection area.
A finished side, ready to be sent to a different facility for finishing and assembly.
There are a number of finishing options available:
One is powder coating (which leaves a soft, lustrous finish that is smooth and glorious to the touch and slightly shiny).
Another is a more industrial looking 'anodized finish', similar to the finish of the amps in the rest of the Edge lineup.
A partially assembled Edge NL Reference monoblock amplifier.
The cleanliness and care that went into the design is readily apparent.
Notice the very large transformer assembly (the black box), which contains vibration dampening and electro-magnetic/radio frequency shielding technology.
Notice also the large number and size of the capacitors (the black cylinders).
The NL Reference monoblocks have no air vents, in the traditional sense. The design, utilizes very thick aluminum, which is not only an excellent material for shielding against harmful incoming and outgoing electro-magnetic/radio frequency contamination, but serves as a massive heatsink as well.
A close-up of some of the connections on the back of one of the amplifiers.
Notice the 20-amp IEC standard plug socket.
Even though the amps do very well with your ordinary house current, feed them the good stuff (like a dedicated, 30 amp line straight from the electrical service in your house), and they will reward you with improved dynamics.
The amps, now almost completely assembled.
Still missing are the top 'crowns'. The decorative LEDs in the crown and in the Edge logo on the front can be specified to be in either red, green, or blue.
These amps were finished using a powder coating and have blue LEDs (not visible in this picture).
room
Kulturhovedstaden
Det er et heftig kabinett, både og se på og reint produksjonsmessig utført. Har fulgt litt med på disse chip foose bilseriene på discovery og er blitt fortalt at originale foose felger lagd i en slik 3 axis maskin kan komme opp i
200k.
Det er en dyr maskin og eie, bruke og ikke minst de aliminiumsblokkene har nok også en stiv pris.
Flotte bilder du har funnet Endre og morsom lesning.
De koster da også 1,4 store har jeg skjønt, hmmm..
N
nb
Det blir jo definitivt litt elsk eller hat på et slikt kabinett rent estetisk, ikke helt min kopp te, men smaken er jo som baken også her. Noe annet er jo at prisen på monoblokkene sikkert kunne vært redusert svært mye om de hadde valgt et mer tradisjonelt kabinett.
Ellers trodde jeg at Die-hard audiofile ikke var så opptatt av annet enn hvordan ting låter ;) (sorry, måtte bare)
Heftig, Endre. Bilder fra inni den sorte boksen hadde vært morro det og. Klarer du det?
DIY_dude
OSLO
Rått! Skulle gjerne hatt en sånn maskin (og 200kg aluminium) da jeg lagde mine egne monoblokker. ;D
KW
Helt enig her.
Ikke noe jeg ville hatt (for utseende sin skyld)
Da er de Endre har nå (Edge-amp) mange ganger finere imo.
Den mye omtalte cdspiller (samt integrerte ditto) fra Edge derimot er heller ikke min kopp te.
Greske hjørnesøyler ;D egner seg bedre der de hører hjemme.
Kan i samme slengen si at jeg heller ikke liker disse helblanke sakene fra Jeff Roland og Burmester heller, men som sagt det dreier seg om smak............
Mvh.KW
A
Afterglow
Enig med KW der, ikke noe jeg ville ha hatt i stua.
Nei, er man ute etter noe med høy WAF og samtidig god lyd så står disse boksene høyt hos meg:
Forforsterkeren Conrad Johnson CT5 (som ifølge Stereophile på tangerte (og på enkelte områder overgikk) lydkvaliteten til den dobbelt så dyre ACT2, noe som førte til at CJ måtte oppgradere denne til Series 2...).
Monoblokkene Conrad Johnson LP 140M
FMG
rama
biskopen av holmlia
oslo
edge kan lage fancy (om ikke akkurat pene) kabinetter.
det skal ingen ta fra dem.
I
ijustpop
Forforsterkeren Conrad Johnson CT5 (som ifølge Stereophile på tangerte (og på enkelte områder overgikk) lydkvaliteten til den dobbelt så dyre ART2, noe som førte til at CJ måtte oppgradere denne til ART2 mk.2...).
FMG
ACT2 og ACT2 Series 2. ART er en annen legendarisk CJ preamp. To bokser og laget i et begrenset antall.
A
Afterglow
FMG
ACT2 Series 2 selvsagt, ikke ART.... For et par år siden hadde jeg jo baby-ART'en Premier 16LS stående i stua... ::) Slik går det når man skriver på tom mage, før frokost... ::)
endrea
Den sorte bokens er trafoen på 4000 Watt.
KW
Oiii!
Da skal det neppe skorte på kontroll noen gang, kanskje uansett høyttalere.
Joacim som har overlatt butikken sin til LyricTor i Sandvika, har fortalt meg at han en gang lagde en forsterker med sinnsykt stor trafo, som han måtte få spesiallagd (tror det var her i Norge den ble lagd)
Husker ikke om det var monoblokker eller ikke.
Han skal jo konstruere nye forsterkere fremover nå.
Får håpe det ikke gjør noe om jeg her og nå legger inn et bilde av en av de første med håndlaget kabbinett i tre.
Edit: Kan jo legge til at heller ikke dette er min kopp med te på forsterkeri.
Treverk på høyttalere ja, andre hifikomponenter sjelden, selv om dette på sin måte ikke er så verst.
Mvh.KW
L
lark
200k.
Ingen tvil om hvor produksjonskostnadene tar veien og hva kundene betaler for på denne forsterkeren.
endrea
Trafoen er delt i to. Hver sinushalvdel har sin "egen" trafo på 2000 watt.
Dual Chassis Monoblock design
Four 2000 VA Toroidal transformers (two per chassis)
Each transformer operates at 96% efficiency. Regulation equals 4%
Laser Source Front Panel Illumination (one per chassis).
True balanced circuit.
Dual toroid transformer-quad filar wound high nickel content core w/electrostatic shield power supply.
Potted transformers in magnetic stainless steel can.
Dual bridge rectification. Laser biased, all "n" channel bipolar output stage.
Mine egne NL Signature 1.1 har også en egen trafo til hver halvdel av sinusen.
endrea
Bra at du vet det :eek:
lark skrev:
200k.
soundscape
Nordre Follo
Heftige forsterkere, og det er vel slik at man ønsker å oppgradere innenfor samme merke hvis man har noe man synes spiller bra.
Har selv ingen erfaring med Edge forsterkere, men hadde nok siktet inn på andre ting - særlig til den prisen.
nma
Ble egentlig litt skuffet over hvor tynne panelene virket jeg.
I tilleg ble jeg skuffet over innholdet: En "svart boks" og et ganske stort print som var festet på den ene sideplaten. Er det seriøst ikke mer?
Jeg som så for meg menneskehetens største funksjon-over-form triumf.. men det var visst det motsatte.
rama
biskopen av holmlia
oslo
jeg ble positivt overrasket, jeg.
motoren
Flekkefjord
hvordan i he,,,,,,,, kan en forsvare prisen på disse aluplatene,det er vist ikke bare cd spilleren som Edge setter en blod pris på å selger til lettlurte audiofile.
hva er så spesielt med disse ampene,kanskje bortsett fra en stor trafo??
bare lurer :-\
Anonym
Forventet å i det minste se en videoutgang i det store kabinettet......
Ole_Martin
Utifra den teksten er det snakk om standard ringkjerner. Men forstår ikke helt hva som menes med "Hver sinushalvdel har sin "egen" trafo på 2000 watt." ? Kan du forklare ?
KW
bare lurer :-\
Vel...., det er jo allerede i tråden antydet hvor dyrt slik arbeid med datastyrt fresing i aluminium KAN være.
Har bl.a sett tilsvarende på bikerprogrammer (motorsykkelfelger)
Når en da samtidig vet at deleprisen på hifikomponenter til sluttforbruker ofte får fra 10 gangern og oppover, så blir det fort penger av det.
En helt annen diskusjon er jo hvorvidt det er verdt det for potensielle kunder, det får jo bli opp til hver og en.
Lydmessig vil det ikke være det, her koster nok pynten svært mye for kunden, men det er det jo enkelte andre ting som gjør også.
Mye luksusgjenstander som er ufornuftig ekstremdyrt, samtidig så er det mange som har mer enn nok penger.
Jeg bruker etter egen målestokk mye penger på hifi, men har kun en gang eid klokke til litt over 1k, den jeg har nå kostet meg 800.-
Bryr meg døyten om urverk, kun at den går og at jeg liker utseende ;)
Hørte nylig om en fra Barain/Dubai eller et av de andre (emiratene?) der nede, som har kjøpt 9 av ti topleilighetene på Tjuvholmen og visstnok ønsker/prøver å få kjøpt den siste, for da får han hele takterassen aleine.
Kjekt å ha et krypinn i Oslo/Norge da en kanskje er her noen få ganger i året.
Koster jo en del å gjøre de om til en (eller kanskje noen) større leiligheter også+ alt det andre jeg hørte som skulle utføres.
Han har visst en eller flere flotte racerbåter også, tror Røkke kjennern og har konkurert mot`n.
Det er et marked for ekstremdyre produkter i verden i dag, noen vet å utnytte det.
Mvh.KW
endrea
Hver halvdel av sinusen har sitt eget forsterker-kretsløp med sin egen trafo.
Det samme gjelder for mine NL Signature 1.1 mono-blokker.
Ole_Martin
OK; balansert forsterker altså; lurte på om du mente at trafoen også kun ble matet av en halvdel av sinusen..
motoren
Flekkefjord
jeg vil beregne ca 20 timer fresing ala 1000kr timen +ca4000 kr i alminium,og dette er i norge.
vil påstå at dette ikke drar prisen veldig mye opp på dette produktet.
Tølper
Jeg har et cnc maskinert sykkeldrev som er langt mer avansert enn arbeidet på denne forsterkeren, i sannsynligvis bedre aluminium (7075) - det kostet ikke rare formuen (noe over 300kr i statene). Bare nevnet det.
Annen vinkel
endrea
Du er veldig heldig!
Annen vinkel
Tølper
Egentlig ikke, det er veldig populært og tilgjengelig for alle så fremt de har 300kr å avse, laget i USA er det også. Mener ingenting om nevnte forsterker, bare ekslusiviteten ved cnc-maskinering og kostnadene knyttet til det.
Forsterkerne kan være så gode som bare det for alt jeg vet.
Hadde jeg ikke skumlest hadde jeg jo forstått hva som var inni den sorte boksen. :p
Hvor har Edge gjemt forsterkerkretsløpene? Under lyttene?
Kanskje under lyttene? Kabinettet brukes som kjøling så transistorene er montert direkte der.
Men, det er mulig mer skal inn i kabinettene? - kommer ikke klart fram.
Synes de ser imponerende ut. Ikke alle stuer de passer utseende messig da ;)
Får ikke disse heller inn i Montanareolen, nei.
KW
Til priser om aluminiumfresing.
Så langt jeg har skjønt om dette, så må det vel først lages et dataprogram (for lay out)
for det er vel datastyrt fresing.
Så kommer da denne jobben pluss selve fresingen opp mot antall eksemplarer som skal produseres da kommer mann frem til en stykkpris (som jeg forøvrig ikke aner hva kan være)
Referer til uttalelesen om bilfelg tidligere i tråden, hvor kanskje en person/kunde skal ha et sett eller noen få (for å ha noe unikt) o.s.v.
Disse delene til tråsykkel vil jeg anta er laget i et helt annet antall, enn det som vil være aktuelt for Edge tårna.
Så vet vi jo alle at det er rimelig høye påslag for produkter i hifibransjen ;) 10.... 20 x o.s.v.
De har sikkert former for kalkyler som stort sett følges fra produkt til produkt.
Tenk bare på at for et forsterker sett til ca. 1,4 mill. så utgjør bare momsen 280k ::) :eek:
Jeg sier ikke at det er noe fornuft her, men prøver bare å tenke meg frem til at der er en forklaring noe på vei til slike svimlende summer.
Kanskje tar de i tillegg sjansen på en høyere kalkyle enn normalt av grunner som nevnt tidligere i tråden(e) og som jeg ikke er uenig i.
Edit; Kom til å tenke på en ting til.
Nå kan vel også aluminium støpes?
Tror neppe aluminumsfelger flest til biler er frest ut, men dette vet jeg lite om.
Er de nevnte sykkeldelene frest eller støpt?
Kabinettene til Piega er extrudert, sikkert ikke direkte billig det heller og antallet spiller inn på stykkprisen som alt annet.
OMF
Hei!
Det er vel ingen tvil om at dette er bra forsterkere - selv om designet ikke tiltaler meg. Måten de har plassert kretskortet med lyttene tyder vel heller ikke på at det er spesiellt god plassutnyttelse i disse.
Hva angår fresing så er jo selvsagt dette ikke noen komplisert oppgave - man produserer tegninger i et eller annet DAC program så gjør en slik fres resten av jobben. Vet ikke hvor mange slike maskiner vi har i Bergen - men hvis vi snakker om mye støre maskiner som håndterer stykker på flere tonn mener jeg vi har 5 stk - på de store maskinene kligger vel timeprisen på rundt 1000,-/time. Toleransene som kreves for å produserer hifiprodukter er enorme i forhold til hva slike maskiner vanligvis brukes til - motordeler, akslinger, lagerhus.
Ellers er jo dette åpenbart et et prestigeprodukt med tilhørende skyhøy pris. Jeg hadde nok personlig valgt biamping med 2 par av lillebroren, og brukt den bunken med penger man får til overs til andre ting som kan gi mer godlyd!
OMF
Mva:
x*1,25=1,4mill
Dvs: 1,4mill - 1,4mill/1,25 = 280k
N
nb
Pengvim skrev:
Blir det ikke 350k?
Nei, du må regne 25% av prisen før moms. 25% av et stort tall (1.4 mill) er mer enn 25% av et mindre tall (1.12 mill)
1.12 mill * 1.25 = 1.4 mill
KW
Pengvim skrev:
Blir det ikke 350k?
Du må dele med 5 ikke 4 ;)
Pris uten moms= 1,120
1,120x125=1,4
Edit; Det er veldig lett å beregne hva en vare koster uten moms ( i Norge med 25 % moms), det er bare å dividere fullprisen (med moms) med 5, da har du momsen direkte.
Mvh.KW
