CES 2009 Las Vegas
R
Roysen
Hei,
Har noen sett CES bilder og beskrivelser av den nye Spectral Audio Master Reference digital kilden?
Roysen
wizard
Sovereign på plass i Usa, men bare med den lille Glory forsterkeren.
Men den er ikke dårlig, denne forsterkeren gjengir musikken på en fantastisk måte.
Aaron
R
Roysen
Wizard,
Vet du om noen rapporter fra CES som gir tilbakemeldinger om lyden fra det rommet med Sovereign og Neeper Acoustics?
Roysen
wizard
Roysen skrev:
Wizard,
Roysen
This is Kim Neeper Rasmussen and his only speaker model (so far), the Perfection One, designed and built in Denmark. Kim used to work for Gamut but left to start his own company and design his own speaker. "I'm a crazy perfectionist", he told us. "I can find flaws in anything, but I think I've gotten pretty close (to perfection) with this speaker." He told us when he left Gamut he sold everything to start his new company in quest of his perfect speaker. It took him almost three years to design it, a year just on the crossover.
Earlier in our report, we told you that resonance is more and more being recognized as a chief culprit in achieving good sound. Kim agrees. That's why his speaker biggest achievement is the cabinet which has no parallel surfaces inside or out. "It's totally asymmetrical", he stated. In addition, the front baffle is machined out of solid aluminum as are the bases and rear ports. "There are 60 aluminum parts", Kim added.
The cone's magnets are oversize. He uses the magnet from the larger Scanspeak woofer on his 5 1/2 inchers which he heavily modified. The unique pattern in the cabinet's finish is pressed into the wood when it's damp under high pressure.
Is the Perfection One "perfect"? The clarity, speed, soundstage and musical timbres were outstanding, even in the less than friendly room. The speaker retails for $20,000 and is one of the better sounds we heard. Hard work pays off sometimes.
wizard
Wadia 971 Reference Transport
Pris blir imellom $15000-20000
LydMekk
Hører fra flere at finansspøkelset har tatt CES. Minimalt med utstillere.
Cedia er vel heller den messen som er "størst" av disse to. September, er det ikke.
R
Roysen
Wizard,
Hvor fant du de bildene av Wadia 971? Har du mer info om den?
Roysen
Jan_I
HMMM... hvorfor får jeg assosiasjoner til Madonna av denne ? :) :)
kaap
Mo i Rana
Syns den TV'n i bakgrunnen så litt svæææær ut.............. :p
wizard
Roysen skrev:
Wizard,
Roysen
http://www.dagogo.com/Events/2009CES/Coverage-I.html
Wadia showcased the prototype 971 Reference Transport in its Venetian Exhibit, a transport featuring the Esoteric VMK-5 Full Disc Clamping SACD/CD transport mechanism, 24-bit Resolution Enhancement technology, ClockLink™ , etc.. The projected MSRP is between $15k and $20k. For the CES attendees who visited he Wadia Exhibit on Thursday, they wouldn't have seen the 971 prototype, for it arrived in the late morning of Friday the 9th.
Year after year, the Wadia Exhibit represented the best in digital audio; this year, the stakes are several notches higher: While the 931 Controller remained unchanged for the time being, the 921 Decoding Computer monoblocks have been upgraded to the 922 status with improvements to component quality. The new retail of the 931/922 Reference Series 9 is $36,000. The result, along with the Pass Labs XA100.5 monoblock amplifiers driving the Dynaudio Sapphire Anniversary loudspeakers, was the best high-end digital audio system as complemented by some of the best solid-state amplification and loudspeaker designs.
wizard
Wadia's latest 151 Digital Amp (left) and 121 Decoding Computer (right). Specifications and price to be announced. For 151, less than $1,000 121 $1,000 without headphone, $1500 with headphone stage.
Jens
Roysen skrev:
Wizard,
Roysen
Jeg syntes det spilte ok, men heller ikke mer.
Typisk "transistorlyd" som låt "teknisk riktig", men manglet "sjel".
Ikke "my cup og tea" ::)
Jens
Tja, så galt var det nå ikke.
Riktignok få utstillere (og besøkende) på Alexis Park, men på Venezien var det ikke så verst (og mye flere besøkende også).
Jens
Jeg syntes forøvrig at Avantgarde rommet hvor de spilte med Nano og egen elektronikk samt Monaco platespiller spillte riktig så godt.
Duo Omega rommet hvor de spilte med Audio Aero likte jeg derimot slettes ikke.
Smak og behag...........
Jens
Det som irriterte undertegnede aller mest på denne messen var imidlertid valget av musikk som ble spilt.
I de aller fleste rom spilte man enkel rolig jazz med maks 2-3 instrumenter som i mine ører sier lite om den totale kvaliteten på utstyret som brukes.
Etter en tid lærte jeg meg at når noen spurte hvilken musikk vi ønsket å høre så var det beste svaret "noe som vi ikke sovner av........." ;D
Mest imponerende lyd:
De knøttsmå høyttalerne demonstrert av Stig Inge Bjørge :)
Mest skuffende lyd:
Store Wilson høyttalere foret av et lass med Lamm forsterkere.
Mer udynamisk lyd skal man jamen lete leeeenge etter :(
R
Roysen
Fremdeles ingen info om den nye Spectral Audio Master Reference digital kilden? Jeg håper på en nettverksspiller laget av Spectral og Reference Recordings guru Dr. Keith Johnson.
Forøvrig er jeg svært skuffet over at det kan virke som Wadia ikke har valgt den største VRDS-Neo i den nye Wadia 971. Jeg skal gi de "a piece of my mind".
Roysen
el_mariachi
Noen som har observert noen bilder av Seas sin stand på CES?
soa
Jens skrev:
Mest skuffende lyd:
Etter å ha lest Audionord-rapporten det er linket til litt lenger opp, kan jeg konstatere at Leif H og co sine inntrykk fra dette oppsettet er de rake motsetninger av dine... ::) smak og behag her altså (men Audionord er kanskje programforpliktet til å skryte av Wilson)
