C
Cyber
Jeg ser denne USB-kabelen omtales positivt rundt om og jeg er veldig interessert i kabelteori for jeg sliter med å skjønne alt, alltid.
På Musicdirect står det følgende:
"Cardas USB is the Clear Choice For a Great Sounding USB Cable!
Finally entering the USB cable fray, George Cardas has unleashed his entry, the Cardas Clear USB. Clear USB is a stunning sounding cable, with traditional Cardas warmth and the astonishing resolution and power of the new Clear series.
Using Cardas copper and patented Golden Ratio stranding, the Clear USB is built to the highest standards in the industry. Hand terminated in the USA at Cardas Audio's facility in Bandon Oregon, Clear USB is not a mass-market cable and definitely doesn't sound like one. With greater air, definition, bottom octave power and control and of course, the glorious Cardas midrange presence that is the hallmark of Cardas designs.
We think the Cardas Clear USB is a great cable, and we back it with our 30-Day Guarantee. Try one in your system for 30 days, if you don't like it, we'll take it back! "
Min utheving;
Hvordan kan en kabel som bærer et digitalt signal tilføre varme? Det er for meg vanskelig å forstå og også hvorfor denne skulle låte annerledes, jeg forfekter ikke andres opplevelser - jeg bare kan ikke skjønne hva man gjør for at et digitalt signal låter annerledes fra usbporten til dacen når det går gjennom to forskjellige kabler.
Min utheving;
