Axiom - Archon - Arché. Tonearm, Pickup og Headshell fra Acoustical Systems
AXIOM - Tonearm
Analog tonearms in particular have always drawn my prime interest among all components of the audio-chain.
In the past 20+ years I have designed a good range of not-so-ordinary high-end analog front-end audio components.
Starting with the 440lbs bi-radial air-bearing and air-suspended APOLYT-turntable - continuing with the UNI-Protractor triangular alignment instrument, the UNI-P2S and the arché headshell.
However, what was always on my mind, was the all-out-assault on the analog tonearm design - actually the tonearm I always wanted for myself.
A dynamically full balanced pivot tonearm which finally takes into account all geometrical aspects, all the various inherent forces and combines all solutions in a most consequent way.
Thus the very best performance possible for any given cartridge is enabled.
This tonearm design is now accomplished.
It is manifested in the AXIOM
(ancient greek: 'that, which commends itself as evident', the premise of reasoning in logic)
USA - the AXIOM meets the Blackbird
archon©
Cartridge
the archon© time-aligned moving coil phono cartridge is a new design.
Featuring an unique designed uni-body made from a solid block of Timet 1100 - an ultra-strength Titan-alloy. Internal liquid dampening at certain areas provides an unique energy transfer ability to conserve and bring to your ears even the finest and smallest details in sound. Thus enriching the sonic picture with rarely heard inner harmonics and ambiance nuances.
the archon© provides a sonic picture which is live-like and tantalizing in its openness, vital detailed and rich in its harmonic structure. A very natural, colorful sound - with an outstanding reproduction of human voices and the most realistic timbre. Opening a soundstage which is wide and recreating excellent the recording venue - with organic placement and wide inner dynamics.
the archon© in its walnut / leather dedicated presentation box.
the archon© is a very-easy-to-mate-with partner for all modern tonearms and an easy match for phono stages.
the archon© is an individual numbered limited edition low-output moving coil cartridge assembled and fine-tuned by hand and designed in Bavaria / Germany.
arché - Headshell
Allow us to introduce to you the arché-headshell - the true audiophile headshell design which sets an all new standard in versatility and sound quality. This new audiophile headshell will allow you to hear the sound really engraved in your records.
 It's unique technical features and solutions are all for only one purpose:
- to bring to your ears and senses the utmost musical experience in the best possible sonics.
 Experience what a headshell can really do for the sound of an analog front-end.
When you listen for maybe the first time to a perfect SRA-aligned audiophile cartridge in a headshell which does preserve all the tiny details and transfers every nuance of energy extracted from the stylus to really reach the phono stage and opens up the full musical spell which was recorded.
The arché headshell is the best link you will find between your cartridge and your tonearm.
Your cartridge will love the arché - because it will bring out the very best in it and allows it to shine in a way like never before - and so will you.
Arché spesialløsninger:
EXTRA +2 mm insert - now available
To accommodate small body cartridges - which usually have very little clearance for the body in most headshells (Dynavector DV17 for instance) - we have designed an extra insert which offers a 2mm increased clearing for each cartridge.
This is again a plug-and-play solution which is identical in function and only 0.5 gr additional weight to the standard insert.
arché with T4P-cartridges
Further please note that the arché works perfect with T4P cartridges too.
Pictures shows Ortofon T4P-adapter mounted in arché.
the AXIOM - Tonearm - 3 finisher
the AXIOM - satin rhodium 16.800 EUR - 143.400,- NOK
the AXIOM - satin ruthenium 17.500 EUR - 149.400,- NOK
the AXIOM - satin 24 karat gull 18.500 EUR - 158.175,- NOK
the archon - pickup
2.580 EUR - 23.220,- NOK
arché - Headshell 3 finisher
arché - Black 4455,- NOK
arché - Satin rhodium 6120,- NOK
arché - 18 karat Gull 7920,- NOK
tom@endpointaudio.no
47832922
svartkeiko
9395 KALDFARNES
Dette er sikkert noe av det beste som går an å få fatt på.Utsøkt maskinering av komponenter.
Endpoint Audio
Endpoint Audio sine annonser
Nyhet fra Canor - Canor Virtus A3, alt i ett forsterker.
  • 2
Canor har endelig lansert sin nye alt i ett enhet. Klasse A/AB, 6 digitale innganger, 4 analoge innganger, 1 phono MM/MC inngang. I tillegg har den hodetelefonutganger i fronten - balansert og...
Black weeks hos Endpoint Audio - 15-20%
Jeg kjører tilbud på en rekke merker ut november. Horns - 20%. EMT og Thales - 15%. Canor 15%. Norma - 20%. Ring eller send mail for tilbud om det er noe du ønsker...
Lagertømming av Lumin. - 40%
Jeg har noen få Lumin U2 mini igjen på lager, og selger ut disse med ca. 40% avslag. Nå 18000,- https://perfect-sense.se/varumarken/lumin
Høstkampanje på Canor Produkter hos Endpoint
  • 2
Jeg kjører igang en høstkampanje på alle Canorprodukter. -20% på alle enhetene. Canor Audio har utviklet og produsert Hi-Fi-elektronikk i over 25 år med spesielt fokus på rørbaserte løsninger. I...
J. Sikora Reference - 1 av 4 A+ rankede i Stereophile
J. Sikoras toppspiller er også den "billigste" A+ spilleren Stereophile har ranket - Prisen er 48.000 USD (389.000,- i norge) + arm. Michael Fremer hos Stereophile har testet J.Sikora Reference...
EMT 928 II - Stereophile Klasse A Platespiller, Høst 2024
Igjen, og fremdeles så får EMT's 928 II en Klasse A ranking i Stereophile. "EMT 928 II: $9995 without tonearm, $14,995 with EMT 909-HI tonearm, $17,995 with tonearm and EMT JSD Pure Black...
