Alternativer til Tidal/Spotify
xerxes
Holmestrand
Litt forvirrende prising på qobuz-billetten:
Nettsida sier fra 139, og 159 per måned.
Da jeg åpnet app så er det 30 dager fri, deretter 229/måned?
t-roten
Emigrant…
Thornhill, Stirling
Hvis du kjøper via App på Apple, legger Apple på prisen da de må bruke Apple sin betalingstjeneste. Kjøp alltid via nettstedet først. Så logge inn i App
xerxes
Holmestrand
Jeg bruker en Wiim Mini på anlegget ved romaskina, der har jeg absolutt ingen skrupler med AirPlay. 🤗
Eller Wiim Home-appen.
Yes, the WiiM Mini supports Qobuz for high-res streaming (24/192kHz) within the WiiM Home app, but it does not support Qobuz Connect due to hardware limitations, meaning you can't cast directly from the native Qobuz app. To use it, add your Qobuz account in the WiiM app and set the quality there; otherwise, use AirPlay or Bluetooth for casting from the Qobuz app, as noted in the Qobuz-WiiM forum.
How to Stream Qobuz on WiiM Mini:
  1. Use the WiiM Home App (Recommended for Hi-Res):
    • Open the WiiM Home app on your mobile device.
    • Navigate to the "Browse" section, find Qobuz, and log in with your credentials.
    • Set your desired streaming quality (up to 24-bit/192kHz) in the Qobuz settings within the WiiM app.
  2. Use AirPlay or Bluetooth (from Qobuz App):
    • Open the Qobuz app on your phone/tablet.
    • Use the AirPlay icon (iOS) or the Bluetooth/Cast icon to send the audio to your WiiM Mini.
Key Limitation:
  • No Qobuz Connect: The WiiM Mini lacks the processing power for Qobuz Connect, so the option won't appear in the Qobuz app for direct casting like it does on newer WiiM models (Pro, Plus, Ultra).
