18 Sound - Suono professionale di Reggio Emilia
  • 2xJ
    NO PRISONERS !!!
    VestBredden
    Eighteen Sound - Professional loudspeakers
    Det er virkelig på tide at dette eminente merke får en egen vennetråd!!
    Italienske drivere av det jeg vil kalle høy kvalitet, dem har skikkelige produksjonslokaler, og setter kvalitetskontroll meget høyt.
    Litt av hva dem sier om seg selv:
    I slutten av 2017 så ble dem kjøpt opp av B&C, samarbeidet mange ganger tidligere oxo !!
    Sammen vil dem bli sterke og komme med mange flotte drivere !!!!!!
    About 18 Sound
    Eighteen Sound is a leading designer and manufacturer of high quality professional audio loudspeakers, developing state-of-the-art transducer technologies and using the most advanced production techniques, located in Reggio Emilia, Italy.
    The Eighteen Sound R&D and engineering teams’ mix a forward-thinking design approach and highest technical accuracy with the skills and attention of an experienced production team, resulting in the exceptional products created at the home offices and manufacturing center.
    Relocated in 2013, this facility is comprised of two cone transducer and one HF compression driver Production Lines, with proprietarily designed robotic and state-of-the-art computer networked segments, interlaced with hands-on, constant inspection and detailing. The final end-of-the-line Quality Control is an exercise in ‘white gloves’ inspection, in tandem with piece by piece automated testing and documentation, allowing for each unit to have an end of line, retrievable set of data. With individual bar code signatures on each driver, our database can provide you with ‘birth certificate’ datasets of your unit.
    We are constantly developing innovative and reliable components for many major pro-audio speaker brands, and we distribute our products worldwide through our extensive Distribution Network.
    Developing innovative and reliable components for many major pro-audio speaker brands, and we distribute our products worldwide through our extensive Distribution Network.
    Quality
    Repeatability and fulfillment of design in every production unit are crucial to our customers, and as such they represent our ultimate goals and our daily responsibility.
    To achieve this mission, each production line is equipped with proprietary robotic equipment that precisely performs the most delicate tasks such as accurately moving and tempering parts or adhesives application in exact amounts, while highly skilled assembly technicians handle the essential human interface segments that define the perfect collaboration representing the hallmark of Eighteen Sound products.
    Quality Control is instituted at every stage of the manufacturing process, whether by automation and software, or close visual and tactile review.
    In the first stage of manufacturing, the raw materials are sourced only from providers with impeccable credential and documentation. Throughout the production process, each stage is equipped with automation and QC workstations to ensure accuracy and validation of test criteria and design.
    Her er en "driver skole" ifra 18Sound....
    [video]https://www.youtube.com/channel/UCByYvtUBzTidCD9CjtBWKnQ[/video]
    Har og har hatt flere drivere derifra, og jeg har virkelig lyst til og teste mer.
    Håper mange vil dele kunnskap og info om drivere fra dette merket.
    BEF.
    Asker
    Har gjort noen prosjekter med 18sound og det spiller helt nydelig. Det er PA med hifi over seg :)
    2xJ
    NO PRISONERS !!!
    VestBredden
    BEF Hvilke drivere har du vært mest fornøyd med ? (Og gjerne hvilke drivere du har hatt...)
    2xJ
    NO PRISONERS !!!
    VestBredden
    Jeg har handlet hos svenskene denne gangen fordi prisen var MEGET bra !!!! Ikke minst så har service vært veldig bra, jeg er storfornøyd og kommer til og handle mer der når det er tid for det !!
    For 12NMB1000 så skal thomann.de ha 299 euro når jeg bestilte tidlig i desember var prisen 309 euro...., men svenskene skulle ha 185 euro + frakt
    https://dat.se/
    Svenske svarer etter min mening veldig raskt på mail. Nettsiden dems er vel ikke av det mest moderne jeg har sett, og mye står det utsolgt på, om man finner et produkt på hjemmesiden til 18S, så er det bare og fyre av en melding til svenskene og spørre om dem tar det inn. Som sagt god service!!
    2xJ
    NO PRISONERS !!!
    VestBredden
    The next-gen titanium diaphragm is produced in house and has been developed to assure unmatched transient response. The diaphragm assembly is made by joining the former directly to the titanium dome on its upper bend edge. In comparison with a usual straight former joint, the driver's design assures extended frequency energy transfer for improved response linearity and unparallel reliability. This feature facilitates proper motion control of the dome in real working conditions. A proprietary treated Nomex former is used as Nomex shows a 30% higher value of tensile elongation at a working operative temperature (200°C) when compared to Kapton. Moreover, this proprietary former material is also suitable for use in higher moisture content environments.
    The ND32ST neodymium magnet assembly has been designed to obtain 21KGauss in the gap for major benefits in transient response. The motor structure, throughout the precisely coherent proprietary designed metal alloy phase plug with 4 circumferential slots and copper ring on the pole piece, reduces inductance effect and distortion.
    The diaphragm kit self-centering design allows high precision mounting and at the same time makes very easy the servicing procedure.
    Virker spennende nok til at den står på ønskelista!
    EditPiaf: Veiledende er ca 227 euro....... stk
