Side 26 av 26 FørsteFørste ... 16242526
Resultater 501 til 520 av 520
Abonnér på denne tråden
  1. #501
    Hifi Freak
    Jan 2010
    Tagget i
    0 Innlegg
    Hei, har snoket litt på disse ampene, men finner lite info om strømforsyningen, er det bare en billig switchmode strømforsyning som følger med?
    Sennheiser HD 600
    Teddy Pardo HPN
    Teddy Pardo TeddyDAC-VC
    PurePower+ 2000
  2. #502
    sorgenfri
    Guest
    Friends, As usual we have been quite busy! We are just finishing up our Project Ember Current Supercharger. This is an add on option (solder in) which boosts the tube heater current capability of Ember to well past 1A allowing hard to drive tubes such as the 6n6p, 6n30p or other tubes to be powered with ease. Sunrise and Starlight owners, your amplifiers already support 1A of heater current so this is not for you.
    Why you would want it:
    - Decreases tube warm up time, especially with high current demand tubes
    - Tubes that were questionable or on the limit of Embers 500 (600mA maximum) current limit can now be powered with ease
    - Overall drastically increases the number of tubes that can be rolled into Ember
    Why you would not want or need it:
    - If your choice tubes draw less than 600mA and you are able to power and use your current tube choices then no need for this mod
    The Ember Supercharger setup includes:
    - Supercharger module pre-built and tested with PCB and all components. Built to Ember standards with black mask / gold wash 2oz copper PCB to match the look of your Ember. To note, the Ember SC is all SMD to keep it compact.
    - New top cover with custom SC serial number - old serial number becomes invalid
    Price for the Ember Supercharger Option:
    - If ordered with a new build or new kit $44.99 + shipping
    - If ordered Separate (after purchasing an Ember) $49.99 + shipping (This is a DIY option. You must de-solder the original DC-DC and solder in the SC)
    - We will install the supercharger on non kit versions of Ember for FREE (you pay for shipping both ways)
    Please email us or simply reply to this email to get on the pre-order list!
    INSANE DEAL FOR EXISTING CUSTOMERS:
    I have a Project Sunrise III factory build which was used for some prototyping and testing. It is 95% a built Sunrise III with a few tweaks. She looks, sounds and feels brand new. Since she is used and has been tweaked, I cannot sell her as new. Price for her is $180 shipped ($85.98 off regular website price)
    FIRST COME FIRST SERVE And yes, she comes with a tube, power supply, chassis and full 3 year warranty!
    Regards,
    Jeremy Helms
    WWW.GARAGE1217.COM
  3. #503
    Mar 2010
    Tagget i
    0 Innlegg
    Er det noen som har kjøpt og montert "Current Supercharger" på sin Ember?
    Jeg fant ikke denne på "Garage1217 sine sider, men jeg vil tro det holder med et e-brev til Jeremy om man vil bestille. Selv venter jeg nok litt for å se om behovet for andre rør melder seg.
  4. #504
    Hifi Freak Minutten's Avatar
    Dec 2007
    Tagget i
    3 Innlegg
    Har brukt en Polaris nå i noen uker og "tror" jeg foretrekker denne fremfor Sunrise på min AT T70. Den er minde varm i lyden, men også mindre ullen samenlignet med Sunrise.
    Siste redigert av Minutten; 04.10.2014 kl. 22:53. Årsak: Typo
    Minutten anbefaler Jazzplater fra perioden 1955-1965:
    https://www.hifisentralen.no/forumet...tml#post517940
    Minutten anbefaler jazzplater:
    https://www.hifisentralen.no/forumet...tml#post562007
  5. #505
    Hifi-interessert
    Jul 2014
    Tagget i
    0 Innlegg
    Hei og hopp! Jeg har sittet og vurdert en Project Ember en stund - men så har jeg også vurdert en Schiit Asgard eller Valhalla. (Jeg har HD650) Er det noen som kan gi meg en anbefaling evnt vurdering mellom de tre?
    Takk =)
  6. #506
    sorgenfri
    Guest
    Jeg, har Psii og harhatt asgard. Jeg har HD555, men har ikke hørt HD650.
    -Har du hørt på rør Amper tidligere? Rør er mer styr, men deiligere lyd.. Transistor er kjappere, og tørrere - mindre styr ---> It`s up 2 YOU!
    Jeg ville gått for RØR:-)
  7. #507
    Hifi-interessert
    Jul 2014
    Tagget i
    0 Innlegg
    Aldri hørt på rør før, men ser for meg at et er midt i blinken for min smak. Hva legger du i at det er mer styr? Takk for svar forresten
  8. #508
    sorgenfri
    Guest
    Sitat Sitat fra Skymarshal Se Innlegg
    I ordet styr legger jeg: Orginalrøret er sikkert ikke bra-->googler meg frem til det som har fått mest skryt-->finner ut at halvparten KAN være falske rør-->kjøper et som er svindyrt-->etc etc etc.. det er egentlig ikke styr i det hele tatt om du tar det rolig:-)
    Jeg er ikke den typen:-)
  9. #509
    Hifi Freak ardilla's Avatar
    Dec 2009
    OSLO
    Tagget i
    1 Innlegg
    Album
    Rør er ikke styr hvis man ikke gjør det til styr ,)
  10. #510
    Hifi-entusiast
    Oct 2009
    Sør-Helgeland
    Tagget i
    0 Innlegg
    Jeg har hatt Ember. Syntes lyden hadde et aggressivt skjær, uansett hvilken hodetelefon/rør/innstilling jeg anvendte. Var i hvert fall ikke, hva jeg trodde en rør-forsterker ville høres ut som (Ember var min rør-debut). Her er min nåværende rør-hybrid, Zigis Rock'n Glass, betydelig vennligere i lyden, samtidig som det er rikelig med drive. Jeg har hørt HD650 på Rock'n Glass, og til tross for at HD650 ikke er min kopp te generelt, så hørtes det ganske bra ut. Ut av Project-forsterkerne er det nok Horizon (anbefalt for 120-600 ohm hodetelefon) du skal gå for, hvis den skal brukes med HD650. Det er mitt inntrykk, at Sunrise/Horizon har mer rør-aktig lyd enn Ember. Alle tre er dog rør-hybrider, ikke rene rør-forsterkere. Hva som kler HD650 bedst, har jeg ellers for begrenset erfaring til å kunne uttale meg om.
  11. #511
    Morpheus
    Guest
    Sitat Sitat fra ketilb Se Innlegg
    Nå har ikke jeg hørt Ember, men etter det jeg har lest på headfi.org og ut i fra det konstruktørene sier så skal lyd-signaturen være rimelig tett på Sunrise/Horizon.
    Jeg finner det litt merkelig at du ikke har skrevet dine inntrykk av Ember i denne tråden... Du har heller ikke skrevet noe om Ember hos Hoved-Fi. Du har derimot skrevet en del om Rock'n Glass under pseudonymet kvik: Hoved-fi • Vis emne - Zigis Rock’n Glass (rør-hybrid headamp/preamp)
    Det kommer frem her at du og konstruktøren har hatt en rimelig tett dialog... Det kommer også frem at du fikk Rock'n Glass FØR du mottok Ember... Det ser også ut at du har brukt en dac til 1200 kroner som kilde...
    Jeg hadde ikke giddet å skrive noe om det hadde det ikke vært for at du skriver dette i Project tråden... For meg ser det ut som du har en viss agenda.. Jeg hadde ihvertfall blitt skeptisk til å anskaffe meg en forsterker som folk mener har et "aggresivt skjær" uansett hodetelefoner...
    Jeg har hatt både T70 og HD 650. T70 er kan være rimelig "skarp" i kantene, og trenger "mørk/varm" elektronikk for å yte sitt beste slik mine ører oppfatter lyd..! HD 650 kjøpte jeg da en av konstruktørene av Project ampene brukte dem som personlig referanse.
    Til HD 650 ville jeg også valgt Horizon eller kansje den nye solid state ampen de har laget...
    Jeg har fått meg en "man-cave" til jul (eget lytterom). Jeg venter bare på at det blir lagt inn strøm som kommer like over nyttår. Så mitt fokus de siste 6 mnd har vært på tradisjonell hifi, men headfi kommer alltid til å være en viktig del av mitt repertoar for å nyte musikk!!
  12. #512
    Hifi-interessert
    Jul 2014
    Tagget i
    0 Innlegg
    Si jeg vurderer å oppgradere til hifiman 560 elns i den gaten, vil Horizon være nok til å kalles engang, ihvertfall i henhold til power? Eller kan man likesågodt gå for asgard 2 med engang og være ferdig?
  13. #513
    Morpheus
    Guest
    Først må jeg si at jeg ikke har hørt noen Schiit produkter. Jeg har lest at de har modifisert Asgard fra den første versjonen. Mener den hadde visse problemer med mye varmeutvikling. Jeg skal ikke diskreditere Schiit. Deres mjolnir amp har jo fått skamros, også fra brukere her inne.
    Jeg ser at HE 560 har en impedans på 50. Det betyr at du må ha en rimelig fleksibel forsterker om du vil bruke HD 650 som har en impedans på 300. Går du for en Project forsterker er det enten Ember eller Polaris som er alternativene. Spørsmålet er om du vil ha rør eller ikke. Asgard er ikke rørbasert så kanskje Polaris ville passet best om du ikke vil prøve rør. Jeg ser litt lengre oppe i tråden at Minutten muligens foretrekker Polaris fremfor Sunrise 2.
    Når jeg ser litt på effekt så oppgir Schiit og Project forskjellig måleenhet. Når man regner litt om så er Project forsterkerne betydelig kraftigere ved 300 ohm. Nå er ikke kraftigere effekt nødvendigvis synonymt med at det låter bedre, men det hjelper ofte på dynamikken. Du kan selv se på forsterkernes spesifikasjoner og ta en titt her: http://www.markimicrowave.com/menus/...%20voltage.pdf
    Jeg tror du sitter med 2 (3) gode alternativer så det er ikke et valg mellom himmel og helvete Lykke til!
  14. #514
    Hifi-entusiast
    Oct 2009
    Sør-Helgeland
    Tagget i
    0 Innlegg
    Sitat Sitat fra Morpheus Se Innlegg
    Morpheus, jeg har betalt full pris for mine enheter fra Zigis, og jeg hverken har fått, får eller forventer å få særbehandling. Enhetene hans (inkl hybriden) er stadig til vurdering, og jeg forventer å uttrykke min mening like ærligt der, som jeg gjorde herover med Ember. Eneste grunn til at jeg nevnte forsterkeren hans var, at det bare er de to rør-hybrider, som jeg har erfaring med. For meg tar det noe tid, før inntrykkene bunnfeller seg. Sånn var det også med Ember, hvor umiddelbar begejstring til slutt avløstes af denne fornemmelse av for aggressiv lyd. Derfor ble den solgt, og den var sendt avgårde, før avløseren ankom. Fordi Zigis forsterker ikke har utvist denne tendens til hardhet, bekreftet det overfor meg, at det jeg hørte fra Ember ikke blott var innbildning. Utover QNKTC anvendte jeg med Ember også min Naim CDX2 som kilde, direkte og via SuperNait'en. På/i ørene hadde jeg Beyerdynamic T1 og Spiral Ear 3-way Reference. Jeg prøvde tre forskjellige rør, og de fleste av de innstillingsmulighetene Ember har. Nok er dette en vennetråd, men det er også et sted, hvor det søkes råd og informasjon om Project-forsterkerne. Poenget fra min side var ikke å peke på en annen forsterker som bedre, men å dele min erfaring med Ember, og plassere det i sammenheng. Hele sammenhengen kom så ikke med i første innlegg, men det har jeg så forhåbentlig rådet bot på nå. Jeg har forøvrig også kommentert Ember i tour-tråden på hoved-fi, liksom jeg har kommentert det meste annet utstyr jeg har hatt, der eller her på hifisentralen.
  15. #515
    Morpheus
    Guest
    @ketilb:
    Jeg savnet både nyanser og bakgrunnsinformasjon fra ditt tidligere innlegg. Det var grunnen til min reaksjon. Jeg har full forståelse for at du kritiserer et produkt du faktisk har eid! Dette er heller ingen vennetråd så kritikk er ønskelig. Men for å kritisere et produkt er det veldig ryddig å skrive noe om hvor lenge man har hatt produktet, hvilke andre komponenter det ble brukt sammen med, om man har prøvd andre rør, og hvordan det opplevdes ect....
    Jeg ser du skrev på hoved-fi:
    Jeg opfattede Embers som transparent og sammenhængende, men altid med et snert af (for mig uønsket) aggresivitet i lyden
    . Det hadde vært mer ryddig om du tok det med her... Jeg søkte på Ember men fant ingenting om den på hoved-fi. Jeg fant noe på Sunrise når jeg søkte. Du har heller ikke kommentert Ember i denne tråden. Videre skriver du:
    Så er den hentet på posthuset. Solidt indpakket, både forstærker og rør - det kan vi lide Bare tre dages transporttid fra Riga, til sammenligning har Ember foreløbigt brugt 10 dage til Syd-Norge, uden at være ankommet endnu
    Slik jeg leser det kom altså Rock'n Glass først... Trekker det frem siden du skriver
    Jeg tror deg på at du har betalt full pris for produktene dine samt at du ikke har et forretningsmessig forhold til produsenten. Det har ikke jeg heller til Garage 1217. Jeg har kun et produkt derfra som jeg gav full pris for (psii) tilbake til 2012.
    Personlig bruker jeg HA10SE Headphone Amplifier - Custom HiFi Cables Ltd. sammen med DC2 Power Supply - Custom HiFi Cables Ltd. som min foretrukne preferanse. Men at Project ampene er "killers" til prisen er det ingen tvil om!
    Jeg må nyansere litt! Jeg ser du har innlegg i tråden, men ingen som går på egne lytteopplevelser med Ember før innlegg 510.
    Edit: Hm, Ser at du bor i Nord-Norge. Du har solgte Ember til en i Sør-Norge... Okay, da ser jeg sammenhengen... Koblet ikke helt at en innlandspakke skulle ta mer enn 10 dager... Jeg antok at du bodde i Sør-Norge og ventet på begge forsterkerne samtid... Har tydeligvis blitt litt for mye ribbefett her i julen....
    Du skulle laget en egen tråd om Rock'n Glass. Den virker interessant! Rimelig er den også.
    Siste redigert av Morpheus; 29.12.2014 kl. 22:01.
  16. #516
    Hifi-entusiast
    Oct 2009
    Sør-Helgeland
    Tagget i
    0 Innlegg
    Morpheus, du har selvsagt rett i, at mitt første innlegg ble for unyansert. Det kom til verden på min iphone, og her får allt en tendens til å bli one-liners.
    Vedrørende tidslinjen så har du misforstått meg i det siterte. Ember ble sendt fra meg på Sør-Helgeland til kjøper sørpå, og brukte 11 dager på å nå frem. På 10. dagen mottok jeg Rock'n Glass, som blott brukte 3 dager fra Riga.
    Jeg har alltid syntes, at det er vanskelig å beskrive, hvorfor noe rammer min smak, og annet ikke. I tillegg er norsk ikke mitt morsmål (er bare halvt norsk), så mine innlegg her på sentralen sakner ytterligere den rent språklige nyanseringen. Likevel forsøker jeg å bidra, etter beste evne, i fall den viten eller erfaring jeg besitter, kan være til nytte for noen.
  17. #517
    Morpheus
    Guest
    Hei igjen . Der kom fasiten! Jeg er fornøyd med at den stemmer overens med mitt detektiv-arbeid . Greit å få info om hvilke utstyr du brukte. Bra du er fornøyd med Rock'n Glass. Prøvde å google den dac'en din men fant vel ikke noe særlig info. Jeg er på jakt etter en rimelig dac selv.
    Jeg synes norsken din er bra jeg! Kjekt du bidrar på sentralen .
  18. #518
    Hifi-entusiast tommo21's Avatar
    Jul 2003
    Tagget i
    2 Innlegg
    Da har Ember II fått plass på jobben:-)
    Navn:      20150918_130630.jpg
Visninger: 242
Størrelse: 60.4 Kb
    Stueanlegg : Nad C390DD2 m/Bluos og Analog Modul, Pro-Ject 2Xpression SB DC, Ifi iPhono 2, Arcam FMJ CD33, Audiovector QR3,
    TV-Anlegg: Yamaha WXC-50, XTZ A2-300, Dali Oberon 5
    Kontor-Anlegg: Onkyo A9010, Fyne F500, Technics SL-7, Chromecast
    Head-Fi: Beyerdynamic DT1990, Sennheiser HD58X, PSB M4U2, iFI xDSD, Fostex HP-A3
  19. #519
    Dec 2007
    Tagget i
    3 Innlegg
    [QUOTE=Morpheus;1956077]
    I forbindelse med test av et par riaa trinn for noen måneder siden så ble både Polaris og Sunrise brukt, men da fortrakk jeg Sunrise med god margin! Har ikke brukt denne så mye men nå var lyden oppløst og fin, fortsatt med litt mer varme og litt mindre bass en Polaris. Tidligere opplevde jeg Sunrise som litt lukket/ullen, men det var det ikke antyding til nå lenger. (Kan sammenligne det med lp vs cd der Sunrise er lp og Polaris er cd, og jeg fortrekker jo.)
    Har faktisk brukt Sunrise litt i det siste da jeg synest den spiller veldig bra nå. (Bruker BD Tp70)
  20. #520
    Hifi-entusiast rellingsen's Avatar
    Feb 2014
    Rogaland
    Tagget i
    1 Innlegg
    Nå har tråden ligget død i snart 4år!
    Jeg får prøve å blåse liv i gamle glør...
    Er det noen som har en Sunrise eller Ember stående og samler støv? Så er jeg interessert!
    Til hifiman HE-500
    Mvh R.E.
    SL-1210m5g - AT33PTG/ii - Clones PA 1
    CC Audio - Electrocompaniet ECD 2
    Optimal Acoustic Laboratories A10.0 & A30.05
    Klipsch Cornwall II Bob Crites oppjazza
Tags for denne Tråden
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
