Lansering av Electrocompaniet EC 5 forforsterker på High End society show i Munchen!
ELECTROCOMPANIET EC 5: A DECADE OF INNOVATION UNLEASHED
The ultimate expression of preamplifier purity has arrived.
After ten years of painstaking development, Electrocompaniet unveils its revolutionary EC 5 preamplifier at the High-End Show in Munich in May 2025 —a masterpiece that redefines signal integrity through groundbreaking proprietary technology while honoring the brand's classic design aesthetic with meaningful new upgrades.
At its heart lies Electrocompaniet's game-changing volume control system: pure electronic construction with no mechanical components or relays to compromise your audio. This engineering marvel maintains a constant signal path length regardless of volume setting, delivering unprecedented transparency across more than 900 adjustment steps with 0.1dB resolution.
The fully discrete, dual-mono design operates in pure Class A throughout, powered by independent power supplies for each channel with multiple stages of noise filtering. Two dedicated 80VA toroidal transformers and 15,000μF of storage capacitance per channel ensure uncompromised performance under any condition.
With astonishing specifications including a 0.5Hz-450kHz frequency response and vanishingly low 0.0002% THD+N, the EC 5 represents the pinnacle of analog preamplification, where the electronics disappear, leaving only the music.
The triumphant return of the volume wheel, now seamlessly integrated into the acrylic front panel, provides both tactile satisfaction and precise control. Behind the elegant 7-inch color display lies a component engineered to be the perfect command center for the acclaimed AW300M and AW800M power amplifiers.
The wait is over.
The legend continues.
Video:
skorob
Brumunddal
Gledes!!! EC mangler en skikkelig highend preamp! 4.8 er fin, men ikke på lik linje som powerampene dems. Spennende!
Bjørn.H
Hva blir veiledende pris på denne?
X-Cell
King of the North!
Morsomt design. Spennende :)
Reaksjoner: KMR
Bjørn.H
Det tror jeg at jeg har..!
Jabba_Jabba
Porsgrunn
Blir spennende å sjekke den opp i München. Prisen står foreløpig som TBA, så kommer den ikke før High End så blir den presentert da. Så at i samme rommet kommer Ø Audio til å presentere Varg bassystem som en nyhet i tillegg til Verdande for resten av verden
Motorhome
Sunndalsøra
Hadde EC pre 4.6 en tid. Den hadde for mye støy. De har sikkert lært :) Men prisene steig kraftig når Tau eller hva det nå hette tok over etter Abrahamsen.
larkrla
Jeg lurer på om det kommer nye integrerte og stereo effekttrinn etter hvert?
Reaksjoner: KMR
torem
Hvis du må spørre har du ikke råd?
For å følge opp mitt eget innlegg så er ikke prisen klar enda. Det er strengt talt en prototyp som vises i München nå. Men en pris mellom 100k til 200k kan jeg tippe her.
torem
Inn: 4 XLR og 2 RCA.
Ut: 2 XLR, 1 RCA og rec out.
Funksjon: Volumkontroll 🙂.
larkrla
Hadde trodd på flere funksjoner, men på den annen side er vel dette toppen av hierarkiet. Kanskje det kommer en preamp i en annen serie senere som er mindre kompromissløs, men med flere funksjoner?
electrocompaniet
electrocompaniet sine annonser
Fin video fra T-Time Vinyl Plant i Stavanger.
Lurer du på hvordan Norges eneste kommersielle LP-platetrykkeri startet, og hvordan det fungerer å lage LP-Plater? Trykkeriet har produsert plater for Aurora, Daniel Lanois, Thomas Dybdahl, Anette...
Soundstage Network på besøk hos Electrocompaniet!
  • 1
Electrocompaniet hadde besøk av Soundstage Ntwork på fabrikken i November for å lag video om vår nye forforsterker EC 5. Her er resultatet:
Fantastisk show i Warszawa for Electrocompaniet!
  • 2
Electrocompaniet hadde gleden av å stille ut et komplett Electrocompaniet oppsettpå PGE Narodowy fotball stadion i Warszawa, med AW800M monblokker, den nye EC5 forforsterkeren, ECM1-MKII streamer...
Hektisk helg for Electrocompaniet!
Denne helgen er vi både på Warsawa Audio Video Show og på New York AUdio Show og viser frem vår nye EC5 forforsterker! I Warsawa finner du EC i rom ROME/RZYM i andre etasje på stadion PGE...
Electrocompaniet søker elektronikk tekniker!
  • 1
Electrocompaniet søker elektronikk tekniker til vårt verksted på Tau. Vil du jobbe med HiFI i verdensklasse? Klikk på linken for å søke! https://secure.webtemp.no/WebtempC.../stillingsingle.aspx...
Ny topp-review for Electrocompaniet!
"Its voicing is admirable and will be loved by those who want accurate instrumental and vocal timbre sounding present in real spaces and compatible with a wide range of loudspeakers. In this, the...
