Vinamp bra eller dårlig?
Winamp er vel nylig blitt oppdatert litt? Regner med det fungerer helt ok.
Tråd flyttet foresten
MrSpock
Det var tider, rundt år 2000 - med Winamp & Napster :cool:
Harry Stoteles
It whips the llama’s ass!
Verdens underligste slagord.
Dr_BASS
Rælingen
Winamp fungerer strålende i dag også men sørg for å bruk riktig versjon
5.66 eller hva den heter
Eirik84
Drammen
Bare vær obs på at du må ha ASIO/WASAPI-plugin for å omgå volumkontroll/resampling i windows dersom du bryr deg om at signalet inn i DAC er bitperfect eller ikke :)
PeriodeLytter
Det er noen instillinger man kan gjøre for å bedre Windows. Det spesielt limiteren som er skadelig da den introduserer masse forvregning når den slår inn.
Summary Recommendations:
  • Install Equalizer APO and use it to disable original APOs and set EAPO's preamp gain at ~ -4 dB to avoid upsample overs, filtering induced peaks, and the Windows CAudioLimiter
  • Set Windows audio to 24 bits so that it's added dither doesn't compromise dynamic range
  • Set Windows sample rate to the same rate as the native file, or to 96 kHz if you play back high resolution material
  • Turn off Windows system sounds and enhancements
  • Install "remote desktop" for "Spotify Connect"-like added convenience, for all your digital sources
  • Take the money saved and buy more music, better speakers and a few bottles of wine
If set up correctly, Windows can provide clean, faultless audio and (free) high performance equalization which provides enormous pleasure and fidelity improvement that I think any open minded audio fan could get behind. All with the performance and convenience beyond external costly hardware solutions.
--https://www.audiosciencereview.com/forum/index.php?threads/ending-the-windows-audio-quality-debate.19438/
