Endpoint Audio er nå distributør for Westminster Lab i Norge/Sverige og Danmark!
NYHET! Vi er meget fornøyde over å kunne introdusere WESTMINSTER LAB i det skandinaviske markedet hvor vi dekker Norge/Sverige/Danmark
Westminster Lab er forsterker og kabelprodusent, og var med på å konstruere blant annet Lumin’s AMP.
Dette er seriøse håndlagede entusiastprodukter.
REI er en Klasse A forsterker på 100/200/400W ved 8/4/2 Ohm.
Prisen for paret er 310.000,-
Kablene benytter seg av solid core, noe jeg også personlig foretrekker fordi jeg opplever de som langt renere i lyden enn multicore.
Mer info om kablene kommer.
https://www.westminsterlab.com
Info fra produsent:
Not The Typical Class A
The Rei employs a WestminsterLab proprietary iBias and CCS systems, what it means in terms of electronically. The Rei will warm up much faster than other typical Class A amplifier, and the iBias technology constantly varies the bias depending on the current and also the loading of the amplifier. And the result sonically, is you get the best of the Class A without the typical draw backs. Is truly unique.
Built Like No Others
Stability and rigidity of the whole amplifier is one of the key criteria to a outstanding amplifier. This is because under a stable environment, signals and power can go through a more stable, undisturbed flow. For that, the chassis must be very stable and rigid with very low resonance and vibration.
Rei’s concept of mechanical structure is completely different from UNUM, instead of just having one unibody like UNUM, the main load bearing chassis of the Rei amplifier is constructed with two very rigid CNC machined aerospace grade 6063 aluminium components.
Why two? Because we can separate the mechanical vibration between power supply components and the “amplifier” electronics. From our test, we realised the power supply has a micro-mechanical vibration at the power supply frequency and its harmonics, which is very different from other electronic components within the amplifier. And this unique construction media this phenomenon to the minimum.
The exposed exterior panels of an amplifiers absorbs a lot of micro-vibration within the audio-band from the speakers. Hence these external panels of Rei are designed to have resonance as furthest away from the audio-band as possible and anchored to the power supply chassis, away from the delicate and sensitive audio electronics.
SPECIFICATION
Rei - Class A Amplifier
Power
100 watts @ 8Ω
200 watts @ 4Ω
400 watts @ 2Ω
Power ( Bridged )
400 watts @ 8Ω
800 watts @ 4Ω
Frequency Response
5 Hz to 40 kHz, ±0.1 dB
2Hz to 52 kHz, -1 dB
Distortion
(100 watts @ 8Ω)
<0.1% @ 1 kHz
Signal-to-Noise Ratio
104 dB, A-weighted
Input
1 balanced XLR input
Output
1 balanced XLR output
Input Impedance
200 kΩ
Output Impedance
0.018Ω
Dimensions
W232 x H112 x D320 mm
Weight
16KG
TAS
Norge
Grattis, spennende tekk och pent design...hvilket prisnivå ligger de på?
Det er vel ikke ren klasse A sånn sett. Varierende bias som følge av strømtrekk slik jeg leser det.
Hvor lang tid bruker de for å oppnå optimal driftstemperatur?
The Shy
Langesund
Det er vel et A/B kretsløp som er i A opp til en satt grense. 100 Watt i klasse A krever mer kjøling enn denne er satt opp med
Med dagens teknologi er det ingen ting å bekymre seg over. A/B forsterkere finnes i det øverste siktet.
Føler at dagen etter påslag er alt helt stabilt i forhold til mine forsterkere.
Endpoint Audio
Tønsberg
Jeg har ikke alle svar enda, men jeg har videresendt spørsmål og regner med å få litt utdypende svar fra Angus Leung.
Den er forøvrig oppgitt til 100W klasse A.
Endpoint Audio
Tønsberg
Info fra Angus:
The Class A is rated at 100Watt at 8Ohm. Is a pure bred traditional class A setup. Though we have a special bias technology to intelligently control the heat-up time and also stabilise the bias at an optimal setting.
The Amp input section fully utilised the balance signal. We only recommend XLR connection for the Rei, though an adaptor can be used with no harm, but the performance is not as good as with a true fully balanced signal.
In terms of the cooling, we use finite element simulation software to design all the mechanical element of this amplifier. The REI runs great at wide range of room temperature and environment. Just in case, we did put a overheat protection in it.
Endpoint Audio
Endpoint Audio sine annonser
Black Friday tilbud hos Endpoint.
Vi kjører Black Friday tilbud, og ønsker å fremheve spesielt varer fra Canor! -15 % på Performance og Premium Line, samt hele 20 % på Reference Line. Tilbudet gjelder fra i dag og frem til 14...
Canor A3 integrert alt-i-ett forsterker imponerer!
  • 1
Canor har siden lanseringen fått en rekke gode tester som samsvarer veldig godt med mine egne opplevelser - fantastisk lyd i en liten pakke for deg som ønsker et enklere oppsett uten en masse...
Lockwood Loudspeakers - Endpoint Audio
  • 12
Endpoint Audio presenterer: Lockwood Loudspeakers – Et legendarisk britisk merke gjenfødt for ekte audiophile. For halvannet år siden – i mai 2024 – sto vi klare til å lansere Lockwood...
J.Sikora Aspire.
J.Sikora Aspire.
  • 2
Nyhet: J. Sikora Aspire – Den nye inngangsporten til high-end vinyllyd! Vi har spennende nyheter fra den polske high-end produsenten J. Sikora. Selskapet, grunnlagt av Janusz Sikora, har...
Lampizator Aphrodite - Lampizators nye flaggskip.
  • 5
Lampizator fortsetter å pushe grenser og jobber hele tiden med å sette en ny standard for industrien. Lampizator leverer DAC’er fra 65.000,- og oppover. Av alt jeg har hatt så er det lite som...
Canor Virtus A3
Canor Virtus A3
  • 1
Canors nye kreasjon Virtus A3 begynner å få flotte tester i hifi verdenen. LP International har tatt A3 under lupen og sett på hva som befinner seg under lokket. Dette er en alt i ett forsterker...
