Når kommer de forsterkerene for salg, er det noen som vet noe om de?
Her er data på utstyret.
The following products are under development / production and will be lounged within Q2 2012.
Integrated amplifier Aeris
2X100W into 8 Ohm, 2X150W into 4 Ohm, will drive loads down to 0.5 Ohm 3 analogue inputs (1 balanced and 2 RCA)
1 USB input
1 Coax / Toshlink spdif input
1 spdif output
USB and spdif inputs are up sampled to 24bit 192 KHz 1 adjustable sub output
1 headphone output (1/4 “jack)
Fully remote, individual volume setting for each input.
Size: W 43cm (17”), H 12cm, D 32cm Weight app. 16Kg
Preamplifier Apertus
3 analogue inputs (balanced and RCA)
4 digital input ( 1 USB and 3 Toshlink / Coax) Up sampling from 16 bit to 24bit 192Khz
1 dig output (spdif)
Balanced and single main output
Dual power supply
Fully remote, individual volume setting for each input. Size: W 43cm (17”), H 12cm, D 32cm Weight app. 8Kg
Poweramplifier Aperire
2X100W into 8 Ohm, 2X150W into 4 Ohm, will drive loads down to 0.5 Ohm Balanced and single input.
Link output. Link more power amplifiers together for bi-amping.
Mono amplifier Amplus
230W into 8 Ohm, 420W into 4 Ohm, will drive loads down to 0.5 Ohm Balanced and single input.
Size: W 30cm (12”), H 22cm, D 42cm Weight app. 20Kg
A-DACII: USB/ S/spdif DAC with balanced output and separate power. A-DACIII same as V6 but with 24bit 96KHz USB input.
1 USB input
1 spdif output
Dual power supply
20.9 KB Visninger: 1.864
21.5 KB Visninger: 1.884
