Nettilfter til PC (i PCI spor eller SATA kabler)
OMF
Hei!
Ser det er noen som selger strømfilter til å plassere feks på harddisker og i PCI slot inni PCen!
Noen som har efaring med dette...?
Sånn rent intuitivt så er det kanskje ikke så dumt...det var ikke spesiellt dyrt heller.....
OMF
Gurba
Hva er det disse filtrene skal gjøre?
OMF
[h=1]Elfidelity PCI/PCE-E Power Filtering Card --- Effective Performance Enhancement of Your PC [/h]More and more audiophiles use PC as their signal source in their audio system. Valab also highly rely on PC as signal source, recording and sound measurement. Using PC as in audio system have one major problem, PC use switching power supply as their power source. While switching power is quite noisy and sound very harsh! Out board sound/recording card using high quality independent power supply is a good solution. While in all case, we still need some on board device, like hard disc, and music signal still need to be processed on motherboard of PC.
We find this amazing tool from ApeXi audio, it is a delicate and elegant capacitor tank board with 7 different type of capacitors build-in. This card can effectively absorb power noise and supply transient current for your PC. So you can obviously aware sound and video improvement.
And you PC will be more stable. It is a low cost but effective investment for your PC.
[h=2]Features of This Power Filter Card :[/h]1. 7 different type of capacitors build-in, for wide range noise absorbing.
2. Compatible for both PCI and PCI-E slots, please see last figure to see how to adapt PCI or PCI-E slots.
3. All parts this card are high grade components, with great performance and durability.
OMF
aam01
Sandvika
Strømfilter på HDD og SSD kan vel ha noe for seg, men det andre filteret skjønte jeg ikke. Hva skal det kobles mellom?
OMF
Skal vel plugges i et ledig PCi spor!
OMF
aam01
Sandvika
aam01
Sandvika
OMF
For å ha en virkning må det kobles mellom noe. Jeg kan ikke se at det kan ha noen betydning hvis det bare står og opptar et spor.
OMF
OMF
Nå er ikke jeg spesiellt kjent med hva de ulike pinnene på et slikt PCi kort er - men vil vel tro at du har bade jord og DC spenning! Og da vil jo et nettfilter kunne gjøre jobben!
OMF
