- Ble medlem
- 27.03.2007
- Innlegg
- 21.759
- Antall liker
- 35.040
- Sted
- Nede i fjæresteinene
- Torget vurderinger
- 2
Fra Wikipedia:
A digital delay line is a discrete element in digital filter theory, which allows a signal to be delayed by a number of samples. If the delay is an integer multiple of samples, digital delay lines are often implemented as circular buffers. This means that integer delays can be computed very efficiently.
The delay by one sample is notated
and delays of
samples is notated as
motivated by the role the z-transform plays in describing digital filter structures.
Kjedelig? Kanskje litt mer interessant når jeg tar med dette:
It would be a good idea to explain why the digital delay line is commonly used in vinyl cutting these days:
When a master lacquer is cut, the engineer must do the entire LP side at once, without stopping. If (when) a mistake is made with levels, EQ, etc, the lacquer is discarded, and the engineer starts over with a new blank. This gets expensive.
It is necessary for the engineer to monitor the program before it is cut, so that changes in level and EQ can be anticipated and adjusted for in time. However, the cutting stylus itself cannot be used for monitoring, as this signal is too late in the chain. (sound has already been recorded on the lacquer before it can be played back. Too late for the engineer to make any changes.)
Therefore, it is necessary to have some kind of "early playback" so that the engineer can make changes in time. In the past, custom analog mastering decks had a "preview head" mounted in the tape path, usually on the left side of the deck plate, near the supply reel. The tape path was modified with extra rollers and guides so that the tape would pass over the preview head (one second or so) before it got to the "normal" playback head for cutting. Quite a complex system to allow the engineer to monitor the signal before making the cut.
Keep in mind that a "normal" pro half-track deck may cost between 10 and 15 grand. Now add the cost of the custom mods and the preview head. Add in the popularity of 30 ips mastering, which complicates the tape path further, in order to get enough delay time between the preview and playback heads. Add in the rise of digital technology, and it wasn't long before some bright soul found an easier way to delay the signal, before sending it to the cutting stylus.
I would guess that the use of a digital delay line in cutting vinyl was common by the mid-1990s, as vinyl became a small-market niche product, and boutique labels no longer had access to custom mastering decks and other tools of the major-label process.
M.a.o. har signalet til nesten all vinyl de siste 25- 30 årene vært gjennom en AD/DA loop på tur mellom analog master og rillegravering.
