APL HI-Fi kommer til Horten-messa!
SAL
Hei!
APL Hi-Fi kommer til Horten-Messa i år!
Jeg har hatt kontakt med Alex hos APL i mange år nå og har som sikkert noen vet også selv noen APL produkter. Jeg fikk Alex til å bli med på messa i år, "Frisørsalongen" er bestilt og Alex kommer opp med full Pakke:
APL Hi-Fi will be attending the Horten Hi-Fi Show this October 26th and 27th.
This will be "The World Premiere" of the entire APL-ILLUMI-FI audio system, first in Norway!
The audio system will consist of the following:
1. Gravitas NB-Master Reference Speaker System. It features a sealed sub-bass enclosure with one active and one passive Scan-Speak Revelator drivers. Paper-cone Revelator mid-bass units. Silk dome Revelator tweeters and Ribbon super-tweeters.
2. DTR-Master digital transport prototype with our proprietary PCM-to-DSD converter. The transport also has "Pure DSD" stream coming from SACDs and DVD-R with recorded DSF files on it.
3. DCT-Master computer audio transport prototype, capable of streaming DSD and PCM-to-DSD converted data to the DSD-Master via USB. It has Windows 8 (x64) with Intel quad-core processor without integrated graphics, 32GB RAM, 128GB SSD for the Windows operation system, and two mirroring 3TB HDDs for audio files only. USB-2.0, USB-3.0 and any memory card or external drive can be connected. e-Sata connection also available. Control through any hand-held device or keyboard. Internet connection is wired only through RJ-45 LAN connector.
4. DSD-Master D/A converter with two S/PDIF inputs and one AES/EBU balanced, accepting up to 192kHz/24bit, that is further converted to DSD by our proprietary PCM-to-DSD converter with DSD64, DSD128 and DSD256, user selectable. Special triple-balanced DSD-only input for connecting the DTR-M transport, proprietary asynchronous DSD-only USB interface accepting DSD64 and DSD128. The DSD-M also features our own proprietary "Pure DSD" double-differential D/A converter. No off-the-shelf DACs. The balanced tube output stage with custom OFC audio output transformers made by Lundahl is also intact.
5. PHS-Master phonostage prototype and my highly upgraded Technics SL-1210M5G with Dynavector XV-1s cartridge. The phono stage is MC-only with Lundahl OFC transformers and JFET/MOSFET input, followed by MUSES01 OpAmps and high-current MOSFET output stage, all working in "Class A". RIAA EQ is a split-type; half passive, half active.
6. HAS-Master 3-piece hybrid amplification system with 6SN7, 2A3 or 300B tubes and IGBT high-current power converters. It has three RCA inputs and one XLR. The built-in attenuator unit is very unique, featuring Opto-controlled devices and non-magnetic resistors.
7. Custom Power cables and Power Splitting Device.
8. Audio Racks by Music Tools, Italy.
Hope to see you there! We will have some great fun! Make sure to bring some of your favorite tunes for audition. CDs, SACDs and any other memory card or USB device containing any audio format will work. :)
Best wishes,
Alex
I mine øyne blir dette stort!
Her blir det noe for en hver smak når det gjelder kilde på øverste hylle, bakket opp av ekstremt bra komponenter!
For dere med gode kunskaper når det gjelder elektronikk skulle det være mulig å få "bryne" seg litt på Alex også vil jeg tro?
Mvh.
SAL
Crusty
Horten
Heia Horten! Er der alle de kuleste folka bor... ;)
Espen L
Skien
Dette ser jeg frem til, bra at du har fått til dette SAL
Skal bli gøy å høre en full "rigg" med APL produkter
Mvh: Espen L
SAL
Takk for hyggelig respons gutter!:cool:
Ser virkelig frem til dette, skal bli veldig hyggelig å endelig få hilse på Alex!
Mvh.
SAL
8x12_TOM
Artig at det kommer "tung" hifi på messen i år også. Vet ikke hvor mye Alex vet om rommet, men det er nok litt i hareste laget med linoleum på gulv, betong i taket og speil på veggene. Har vært med på rigging av det rommet flere ganger, så det er helt klart mulig å få til godlyd, men det er nok lurt med noe akustiske tilltak
Bare et tips, vi vil jo få mest mulig ut av disse krem komponetene.
Reaksjoner: SAL
SAL
Takk Thor!
Må inn litt av hvert vil jeg tro!:)
Mvh.
SAL
Synd jeg ikke fikk tid til å tilbringe noe særlig tid på dette rommet; var innom en rask sving men da var det mye folk der, og Skorgan bæljet ut som best hun kunne.. Hva er det med middelaldrene menn og syngedamer..:rolleyes:
Har hørt en del på APL riggen til HATO og må si at APL nok er noe av det mest transparente og ærlige jeg har hørt av pre/DAC.
Reaksjoner: SAL
SAL
Kanskje vi husker disse damene fra ungdommen?:cool:
Neste gang du er i Porsgrunn er du velkommen til en lytt her samt en titt i garagen om det skulle friste! Ingen kø......... :rolleyes:
Mvh.
SAL
Takker for invitt! Da tar jeg med min 1991 Caravelle Coach - previously owned by Otto Jespersen! :cool: Kanskje noe av effekten smitter over... BTW, litt OT men vet du hvor jeg kan få tak i motorer til el.vinduene?
SAL
Coach treff, helig!
Skal sjekke motorer til vinduene, BigBlock?:cool:
Mvh.
SAL
Kunne tenke meg en Yenko aluminium, sånn passe tidstypisk retro maskin...
Alternativt, kanskje en Ford 427 S.O.H.C. for å irritere originalfantastene... Dare to be different! Brutal og vakker samtidig.
SAL
Hyllevare, hadde en slik i min forrige 64 Corvette coupe, org.495 ZL1 merket SYDE! Skal lete........
Mvh.
SAL
SAL
Siden du er inne på 427 SOCH, det nærmeste jeg kommer der er en maching-number 70 429 BOSS Mustang. Vi donerer den motoren til din Coach.8)
Mvh.
SAL
Guit
Sunndalsøra
Det er akkurat slik en motor skal se ut:) Er noe mindre motor i forden min. mvh. Guit
Reaksjoner: SAL
John_Harald
Sørumsand
Var innom rommet fem ganger i løpet av lørdag og søndag. Fikk totalt sett lang tid i ss og apl var det jeg gledet meg mest til på messen. Ble skikkelig skuffet, det samme ble de to som var med meg. Håper det låter bedre hjemme hos dere andre som har apl komponenter.
John_Harald
Sørumsand
Ser på filmen at den ene fyren går ut etter den andre, p.g.a. dårlig lyd?
Syns det er rart at ingen har kommentert innlegget mitt. Uansett hørte jeg mange positive ting med lyden som pirret oppmerksomheten litt. Dette må da låte bedre hjemme hos dere?
kwil
Hva var det dere opplevde dårlig med dette?
Skrev om min opplevelse i en annen tråd. Var ikke sprekt dette i mine ører. Andre har motsatt følelse noterer jeg meg.
Spilte ganske lavt da jeg var der. "hifi" plong musikk og ganske mye folk inne. Dessverre også for totalfølelsen. Romling fra rommet nedenfor.
John_Harald
Sørumsand
Holografien og bass + oppførselen til utstillerene oppfattet jeg som ikke så bra.
januscp
Det er nærliggende å anta at mange er lei av å høre den samme såkalte "referanse" musikken omattatt og omattatt... Det var ihvertfall derfor jeg ikke ble sittende lengre. Mye folk ut og inn, og plassering av lytteposisjon helt intil bakvegg gjorde heller ikke noe for å heve opplevelsen til de store høyder. Men dersom man så litt forbi dette, så var det utstyr av høy klasse, og fin oppløsning, balanse og musikalitet. Med det rette rommet vil dette sikkert være noe av det aller beste utstyret der ute...
Espen L
Skien
Et merkelig resonemang synes jeg! spilte lavt sa du? kunne du ikke bare be han spille høyere da? Når jeg satt der (og jeg var der flere ganger) så spurte han gang på gang om lydstyrken var ok + at han spurte stadig om det var noen som hadde med seg egen musikk de ønsker å høre på. romling fra andre rom, det er noe man må lære seg og høre forbi når man er på messer vetdu :) Mye folk inne skriver du? javel det er vel bare positivt at det mye folk innom som ønsker å være på messe og lytte. Vil man være alene og virkelig teste anlegg så er mitt råd få det hjem i egen stue!
Personlig så synes jeg dette var et av de bedre lydene på messen og synes det er merkelig at man her ikke hører at, dette systemet i et bedre rom med mindre mennesker og med egen musikk hører at dette har kvaliteter? men vi hører ulikt og det er jo noe av det som fasinerer vår hobby.
Mvh: Espen
For min del var det opplevelsen av dårlig dynamikk (man hører det fint ved lavere volum også), flatt lydbilde, lite engasjerende lyd. - Følte faktisk at noe var feil der da forventningene egentlig var ganske store. Jeg var der omtrent midt på dagen Lørdagen og jeg regner med at det spilte bedre ut på Søndagen (forhåpentligvis, og det gjør ofte det på messer grunnet mer innspilling, noe mer tuning fra aktører mm.). Skrev noe om det en annen plass. Jo og må medgi at subjektive følelser slo grunnet tanken på prisnivået dette anlegget hadde. Dette med rom, strømkvalitet, bråk og ståk er likt for 90% av de andre aktørene også. For oss som har litt trening i lytting er det relativt enkelt å lytte forbi dette.
K
Kaare G. Opsahl
Jeg har hørt APL elektronikk i flere ganger og VET at det er bra saker. Messelyden var ikke vellykket i mine ører. Med de kremkomponentene er det skuffende å høre at lyden ikke slipper høytalerene. Men slapp av fans. Jeg vet det kan bedre.
sett på sakene i god tid. Lei rommet et par dager ekstra. Blir for dumt når ting låter bra etter klokken 15 på søndag.
Audiophile-Arve
Høyrde APL-anlegget ved fleire høve, og var aller mest imponert over det som skjedde nattestid... men då fekk eg sitte aldeles presist på godplassen. Sweetspot var litt mellom dei to plassane heilt til høgre.
Beste kvalitet var den veldig opne mellomtonen, og evna til å få utklinging.
Elles sette eg pris på demonstrasjonen av skilnad vinyl/digital. Mindre skilnad enn eg trudde, når vi snakkar om slike prisklassar. Men eg lurer på kva meir det er å hente på platespelarsida, for det finnest meir optimale matchar til DV sin toppmodell enn SL1200-armen, vil eg tru?
Kenol
Det sprekeste i det rommet var dama. :p
Hvordan synes Alex selv det låt?
Gjallarhorn Audio
Heggedal, Asker
Selv var jeg blant de som hørte på APL-anlegget natt til søndag, og det i flere timer. Det så ut som de andre som var der også likte det de hørte da folk ble sittende lenge og det var formelig kamp om sweet spot.
Mulig oppsettet slik det stod på messa krevde rolige forhold for virkelig å kunne bli verdsatt for den homogenitet, balanse og sømløshet det for meg fremviste. Kanskje noen oppfatter den vellykkede delingen mellom de ulike høyttalerelementene som mangel på dynamikk i den forstand at det er færre frekvenser som stikker seg ut? Hva vet jeg? Musikknytelse er uansett en subjektiv opplevelse og jeg har vært i rom på messa med så lys og hard diskant at jeg har skygget banen. Dette samtidig med at det har sittet en rekke personer i rommet og gitt fot. Våre ører er akustiske mottakere formet som horn, og det er ikke et som er likt.
Prisen på dette anlegget var for meg totalt ukjent da hele forhistorien rundt APL på HFS hadde gått meg hus forbi - bare så det er sagt.
SAL
Hei!
De fleste var enige om både dama og lyden! Fikk faktisk veldig mange tilbakemeldinger om at dette var beste lyd på messa:), MEN som alle vet skal noen ha moren istenden for datteren, ikke noe nytt her.
Når det gjelder noen av kommentarene i denne tråden synes de snakker for seg selv, selvskudd i foten er vondt:cool:(for sikkerhets skyld, denne setning MÅ leses med humor!)
Når det gjelder hvordan Alex synes det låt på messa sendte jeg ham denne mail sent i går kveld:
Good morning Alex!
There are some discusion concerning the sound we had at Horten HiFi show and ofcourse there are some disagreement!
But there is one guy who is wondering what you think about the sound we had, any comments you want me to forward?
Best
Stein
Hello Stein,
Speaking from experience with audio shows I attended in Las Vegas, I must say that it is close to impossible obtaining even 60% of the real audio system performance. Such events like in Horten are intended mostly for showing the actual equipment, meet different people, have a drink and have fun. :)
Of course there were many downsides to the sound in our room - certain bass frequencies were attenuated, certain were amplified by the room. Soundstage was not 3D holographic as it should be. Due to arrangement, the sweet spot was very narrow. There wasn't enough "air" and liveliness.
But it takes only few seconds for the experienced listener to hear and appreciate the unmatched naturalness and ease of the sound flow, combined with almost perfect tonal balance (from cello to voices and violin) that the APL-ILLUMI-Fi reference system offers. In the correct setup and environment, one can enjoy the same tonal balance and naturalness, combined with a huge holographic sound presentation where the speakers completely disappear, even from offset position. This life-like and fatigue-free sound never makes the listener's ears tired, and makes him/her forget about the audio system, allowing them to really enjoy the music. Isn't this all about, after all? :)
For those who are really serious and would like to audition the APL Hi-Fi components in their own house, we can ofcourse arrange such demo. Maybe they can visit you first and listen to the system there?
Best,
Alex
Mvh.
SAL
SAL
Kan også legge til at prisen på systemet som ble benyttet er ca. 680 pluss moms.
Dette er selvfølgelig uten vinyl og PC-løsning.(Men med analog-in og USB)
Mvh.
SAL
januscp
Det er min fot, og jeg skyter når jeg vil, og hvis jeg skulle bomme har jeg alltids ei kule til..... (DumDum Boys):cool:
Den som ikke klarte å høre forbi alle feilene med rommet, og høre at dette anlegget nok var det aller beste på messa bør ta seg en tur til legen for mekanisk fjerning av ørevoksen, skylling og smøring av ørene kommer på toppen.:p
Alex sier meget treffende: Due to arrangement, the sweet spot was very narrow. There wasn't enough "air" and liveliness. Det krevde ikke særlig kunnskap for å høre det samme, og har man hørt APL hjemme hos SAL fra før, så vet man at dette er tilfelle.
Alex sier videre: In the correct setup and environment, one can enjoy the same tonal balance and naturalness, combined with a huge holographic sound presentation where the speakers completely disappear, even from offset position. This life-like and fatigue-free sound never makes the listener's ears tired, and makes him/her forget about the audio system, allowing them to really enjoy the music
Det er ingen grunn til å tvile på at dette er sant, lyden av APL er lett å like, samt at den ikke er trettende på noen som helst måte. Ikke at det er så unikt, men det er et minste krav til et high end anlegg.
Det som kanskje er mest verd å merke seg er dette: But it takes only few seconds for the experienced listener to hear and appreciate the unmatched naturalness and ease of the sound flow, combined with almost perfect tonal balance (from cello to voices and violin) Rent bortsett fra ordet "unmatched", så tok det meg nøyaktig brøkdelen av et sekund for å oppfatte akkurat dette. Det i mine ører var kun en utstiller til som hadde dette spesielle "naturalness and ease of the sound flow, combined with almost perfect tonal balance". Dette sier litt om hvor vanskelig det er å få til, men APL gjør det.
Selv har jeg ikke noe APL i huset, men det hadde ikke vært plagsomt å bytte det jeg har mot det som står på messa - bare så du ikke får noen ideer Stein Arne; Platespiller'n min blir stående...;)
Coach treff, helig!
Mvh.
SAL
Bumpers....
SAL
nlykke
Jeg besøkte dette rommet lørdag, natt til søndag, og søndag. Hadde aldri hørt merket før, men lest noe om det her på sentralen.
Jeg fikk et meget godt inntrykk, og koste meg faktisk med mye av presantasjonen. Det var ikke vanskelig og sette pris på den mellomtonen i dette anlegget!
Mvh Petter.
