Høyttalere Erfaring med Klipsch Icon serie?
sirop
Noen som har erfaring med Klipsch Icon serien?
Har vært nysjerrig på denne serien en stund.
eddie1
Banned
Meget bra serie som er noe undervurdert men de er vel litt mer "hifi" aktige enn RF, altså litt snillere med litt mindre villskap men spiller meget pent...
Harleyy
Se side 92 i dette magasinet: http://audiofidelity.no/comlete_mags/Fidelity44.pdf (side 80 i .pdf-dokumentet)
Håkon Rognlien
Kan ikke si dette gir noen son helst pekepin på nye Icon da endringene er mange :)
Icon V ReviewIcon Improvements
Fatiguing at higher volumes with musicAccurate, non-fatiguing sound provides hours of listening pleasure
Baskets are stamped (rather than cast) which is a little disappointing at this price pointListeners will discover re-engineered drivers
The crossover is mounted directly to the plastic dual binding post housing and has average quality partsCombined with a new crossover system
Midrange a bit thinFills medium to large rooms with powerful, lifelike performances
The outriggers at the bottom of the speaker look like they are indented into cabinet but they aren't. They are held in place by two screws and have a round plastic foot. This seems to be an odd choice.New logos and feet
Men hvis man plusser på dette og legger til at de har en med 2x8" bass så begynner vi å snakke :)
