Digitale avspillere Hørt i kveld, beste DAC i verden?
lovemusikk
Min DAC i signatur spiller ringer rundt den som er innebygget i forsterkeren min. Min DAC (se signatur) blir sammenlignet med Hegel og Bel Canto leser jeg på nettet. Mye for pengene alså.
I direkte samenligning hjemme hos meg i kveld, er følgende DAC utrolig mye bedre enn min egen DAC. :)
Nemlig HRT Music Streamer HD. http://www.hifisentralen.no/forumet/bransjenyheter/66565-hrt-music-streamer-hd.html
Test Stereophile: Google Oversetter
Her er noe fra Hifi+
'm not going to beat around the bush. Correctly fettled, this is the best
DAC you can buy at this time. Not the best DAC for less than £500 or
the best USB-powered DAC. It's not even the best DAC for something
like the double the price. I've tried a lot of DACs, some costing a lot more
than the HRT Music Streamer HD and -while they might be different, they are not better.
It's an USB-powered Asynchronous input DAC, which can work up to 24 bit, 192kHz precision in Class 2.0 USB Audio. It only has a single USB Type B input. but can output a balanced or a single-ended output, although it works in fully differential mode. It has vanishingly low levels of everything bad (noise floor, THD+N, jitter) and high levels of everything good (signal to noise ratio, flatness of frequency response). It doesn't upsample your music for you, re-convert its sample rate to another more internally-friendly one, it has at most two LEDs (neither of which are ever blue) glowing at once. The nearest concession to interactivity is the front-mounted toggle-switch that flips from Class 1.0 to Class 2.0 USB connectivity (as ev~r~ Mac people are fine with Class 2.0, but PC and Linux users ... it's driver time). It can -and should -be periodically updated with the latest firmware. And that's it. It weighs less than a trio of audio phile cones and costs less than many audiophile USB cables.
It's distanced from the audiophilezeitgeist in this respect. It's not in the least bit cable fussy -the giveaway USB in the box is more than good enough, and its output voltage and impedance make the use of fancy interconnect cables less of a priority, more of a present. If you want to make an audiophile song and dance about it, put a paperweight on the top to damp it down (sorry, losing my audiophile cred here -put a rare piece of hardwood that costs five times more than the DAC on top of it to re-un-tungulate the positively negative ions and ward off dark energy). It doesn't care. It just makes music happen.
'7t's not in the least bit cable fussy -the giveaway USB in the box is more than good enough, and its output voltage and impedance make the use of fancy interconnect cables less ofa priority, more ofa present... It doesn't care. It just makes music happen."
~20 1~'UE97
And boy does it make it happen. With the DAC correctly fettled (again), about 20 seconds into listening to the first piece of music, I lost interest in reviewing and just went into 'music lover' mode. And stayed there. Following that excellent 'Searching for Sugar Man' documentary, I acquired the two Rodriguez albums (Cold Fact and Coming From Reality) and I played them end to end. Then I played the equally rare Lou Bond, which drew me to Donny Hathaway, inexorably from there to two Roberta Flack albums in a row, then (naturally) to the Fugees, and on, and on. The next day was almost the same, broken only by shopping trips and a pressing desire to put something on page. The thing is, I don't know what to put on page here. It just does sound, and does it exceptionally well. You aren't aware of
the detail resolution, the articulation, the imagery, soundstaging, solidity, dynamiCS (micro-, macro-or any other kind of '0', including Bilko) . They are just there, and being done so well it's only in those moments when you drag yourself away from the player to do some comparing that you get just how good it is at making itself invisible.
Of course there will be those who listen to the HRT and will prefer the sound of anyone of dozens of top-end DACs currently available. That's not the point. The point of this is, this is a DAC that stands proud in such company without sounding in any way out of place. If its closest rival from a musical standing is in excess of £2,000 and it really wouldn't sound far out of sorts being compared to a Bricasti or dCS, you know we are on to something good. The 'correctly fettled' part is key, though . Used straight from your computer's USB host controller, this is a perfectly serviceable, perfectly blah OAC. It will not offend, but neither will it set the world alight. It's a bit 'meh!' This is because it draws 480mA from a line that tops out at 500mA. Put it through a powered hub (even a cheap powered hub) and you begin to see the glint in its eye. Put it through something like the AQVOX isolated linear power supply for USB and five seconds into the next track, you have achieved computer audio nirvana. My worry is that, people being people, they will ignore the need for that extra juice box and never hear what their computer is capable of. My hope is that Kevin Halverson of HRT reads this and makes something similarly sized and mains powered to 'upgrade' the HO. While the jump up in performance can be achieved elsewhere, there are always those who think using something other than a HRT product to power another HRT product is either 'unsafe' or 'disloyal'. In which case, HRT needs to complete the job with an isolating power supply. Let's be truly honest here. Part of being an audiophile is brand snobbery. There will be those who will never look at the HO because it's not made by their pet brand. There will be those who won't touch it becp.use it's not got a 20A power socket and an inch-thick alloy front panel. And there will be those who don't get it because they simply wouldn't dream of spending less than four, five or even six figures on their digital source. Such is life. But if we are being truly honest, try and look past that, and think of this in the sort of systems it deserves to go in, in performance terms alone. Suddenly, you ~21 ISSUE97 realise you aren't looking at a cheap OAC with high-end pretentions; it's the real deal.
Den vart og enda litt bedre med egen strømforsyning på usb kabelen. Den het: Aqvox usb ps
Noen flere med erfaring på denne DACen??
nma
Tar dette med en neve salt så lenge den ikke har vært gjennom orso-testen.
lovemusikk
Orso testen???? Mener du at Orso må teste og si om det er sant? haha.. :p
Uansett jeg vart målløs :)
Voff
Den kan da umulig være bra til den prisen ;)
lovemusikk
Nei sei det du ;)
Men jeg kjem til å kjøpe uten å mukke. Forskjellene var betydelig mot min egen DAC, som igjen spiller ringer rundt Hegel.
sirop
Denne DACen kom vel også veldig bra ut i en Lyd&Bilde test for litt siden?
Synd den bare har usb-inngang og ikke coax og optisk.
OMF
Hvis du søker litt her på sentralen så finner du masse informasjon - dette er vel en av de mest omdiskuterte produktene på sentralen!
OMF
endrea
Dette er feil.
HRT MS HD er en ny DAC(192 khz) som ikke har vært omtalt nevneverdig på sentralen.
Den DAC'en du henviser til er HRT MS PRO(96khz).
OMF
lovemusikk
^ Hvilken Hegel?
Hegel H100 det er jo en simpel forsterker.
Hva Lyd og svindel skriver får være opp til de. F.eks de gir jo Hegel 6 hver gang, men så bra er ikke det merket. osv..
Ja synd det bare er usb. Men må kjøpe en slik uansett, for dette var bra.
Dette er feil.
OMF
Helt riktig. Viktig å skille her. Dette er en ny DAC og prisen er 4500,- evnt pluss ekstra strømforsyning til usb, som og fikk den enda litt bedre.
stingrayV
Skodje
Jeg har så vidt lånt øre til denne i helgen som var. Det ble ikke noen storstilt test, men mitt umiddelbare inntrykk var at den var finkornet og behagelig for øret, og at frekvensgangen virket nogenlunde lineær.
Vi hadde den tilkoblet med aqvox strømforsyning (totalpris blir da 5700,- om jeg hørte riktig).
Absolutt en god usb dac.
Ser frem til å teste denne ordentlig når eieren kommer tilbake fra sjøen om en måneds tid
stingrayV
Skodje
da kan vi ja ta en sammenligning med Metrum sin NOS dac...
Det høres ut som en meget god plan, og skulle jeg rekke å få bytta sjøl kan vi kanskje sette dem opp mot bryston bda-2 som skal opp for utprøving mot høsten. :)
Dette er nok den beste i HELE verden, hva gjelder dac.. Hehe... God er den, kompis har kjøpt den.. Men best i verden.. Ta en bolle love.. :)
Bjørn ("Orso")
Kan hende den er best i verden for lovemusikk HCS. Man trenger ikke å ta alt helt bokstavelig vettu. Ta deg et kaldt glass med cola!
lovemusikk
Les du hva jeg skrev? Beste DAC?
?=spørsmåltegn.
Hva er best mener du då?
Du veit? Les du hva jeg skrev? Beste DAC?
?=spørsmåltegn.
Hva er din beste då?
Distinctive
Sikkert mange som mener at de selv sitter på den beste, så her er det bare å rope i skogen (avstemming?)
Mener du best uavhengig av matching kriterie?
Det er en egen tråd på HFS som lister opp medlemmers DAC.
Virgo
Har hørt den, men hos meg syntes jeg Benchmark Dac 1 var en god del bedre
lovemusikk
Flott.
Liker at noen som har hørt den kan sammenligne mot andre.
Da får vi/jeg litt mer overblikk på hva som er bra av DACer der ute.
Virgo
Jeg er dessverre ikke så veldig flink å skrive hvorfor jeg syntes Benchmarken var bedre, men i mitt rom, da jeg går utifra at forskjellige produkter som alle er i en viss klasse, vil virke forskjellig, kanskje grunnet bedre matching med resten av komponenter, vatr Benchmark en god del bedre. Mer presis, hadde et fastere lydbilde, samt en god del mer fokus på mikrodetaljer. Jeg følte instrumenter og stemmer var mer åpnet og mer levende tilstede. Det hørtes bare mer korrekt ut...
Men Benchmarken er jo kjent for å være en særdeles god dac, og til bruktpriser som til tider florerer her, tror jeg ingen egentlig kan måle seg. Men det er min mening;)
lovemusikk
Flott.
Men tviler sterkt på at den er bedre. Kommer og ofte an på hva som er koblet til, men og hva anlegget kan gi ut av godlyd.
Snakker på generell basis nå.
Hvorfor tviler jeg?
Med bakgrunn av egen DAC som er veldig god, som spiller ringer rundt H100 sin DAC, og med tanke på hva andre skriver som faktisk har den samme, men også har dyre merker, så er min et funn. Nesten på høyde med Bel Canto 2.5 skriver en her inne på sentralen.
Når da HRT Music Streamer HD er mye bedre enn min egen så tviler jeg på at Benchmark er bedre. Men det er uten å ha hørt det merket.
Rart at Benchmark er såå bra, uten at jeg har hørt den er så bra? Ikkje da, min er lite omtalt og.
Så hva gjorde den HRT HD bedre enn min egen?
- Jo, klarere lyd, selv om min DAC er meget klar.
- Naturlig varme, mye mer enn min egen, som har litt for lite av det.
- Lyden kommer skikkelig ut av høyttalerne noe det ikke gjør nok med min egen DAC.
- Rommet og djupna i lydbildet kommer mye bedre frem enn min .
Enklest er å si den var utrolig mye bedre enn min.
Så bra ble det at jeg vurderer å la høyttalerne få stå, for nå vet jeg potensialet på de, selv med en simpel forsterker som Hegel H100 faktisk er.
lovemusikk
sier du det? hmm.. :) Kunne vert artig å testet den
Norcane
Tomter
Synd du bor så langt unna. Har selv Audiophilleo 2 med pure power batteri. Selv tror jeg den er best i verden;)
edit: trodde det var en konverter. Spennende sak!
lovemusikk
Barnslig er dere!
Best i verden? - skrev jeg.
Ser dere spørsmålstegnet?
Litt voksne kan dere prøve å være.
At du mener du har den beste får stå for din regning.
Norcane
Tomter
Tviler på at den er det men den er svært god:) Litt barnslig er det lov og være noen ganger...
Norcane
Tomter
Alt er relativt. Alt spiller ikke like bra på gitt utstyr heller. Men når det er sagt så tror jeg den HRT spiller veldig bra! Har lest litt om den og har lyst til å prøve selv også. Men det kommer jeg ikke til og gjøre da jeg er ferdig med oppgraderinger på DAC/USB delen:)
Men det virker svært lovende og kunne kjøre balansert rett inn i forforsterkeren:)
lovemusikk
Ja.. ser det mest seriøse bladet i følge meg skriver saftig om den:
than the HRT Music Streamer HD and - while they might be different,
http://audiofreaks.no/onewebmedia/HRT MS HD Hifi + Mar13.pdf
Kjøpte du den eller har du lånt av den lokale hifi-pusheren? Er det andre dacer du har sammenlignet med enn den du refererer til?
nma
Hifi+ er latterlig. Dacen går går fra å være avdanka smør på flesk til best i verden vha en ekstern usb-psu. Hva er det du egentlig vil diskutere lm?
Norcane
Tomter
Han vil vel egentlig kun fortelle om hvor bra han syns denne DACèn var. Og det må jo han få lov til:) Alle USB dacèr forøvrig, de fleste ihvertfall, vil låte ebdre med ekstern strømforsyning..
lovemusikk
Lånte den av en som har en slik.
Testet den ikke mot min innebygde DAC i Hegel, da den stinker. Så kun mot min egen Valab
Ingenting. Sier bare at den overrasket stort ved å være så bra.
