Må si jeg er imponert over respons fra supporten deres iallefall:
Thank you for contacting Bluesound. We are very pleased to here you are as thrilled with the Bluesound Node as we are.
Thank you for your feedback regarding product enhancements; The Bluesound firmware, BluOS is an exciting breakthrough in music streaming. We are very excited about it's possibilities and look forward to making it the best it can be. We hope you will see this with product enhancements as they are released down the road.
We are currently testing the latest version of the BluOS firmware here in our lab. One thing we are excited about are some changes we have recently made to the volume slider. We have found it to be sluggish and unbalanced. We have redesigned the inner workings of it to act more like a mixing board fader and have been very pleased with it. It will be in our next product update to the Node and Vault.
Please download this file:
https://lenbrook.sharefile.com/d/se9aa7c06ef34515b
• Unzip the file N100_USB_Stick_1.0.36.zip
• Copy the file N100.img to the root directory of a USB stick
• Disconnect the AC Power cord from your device
• Insert the USB device into the back panel of the device
• While pressing the Mute button on the device, reconnect the AC Power cord and continuing to press the Mute button for 5 seconds after the LED has turned Red
• The device will then start copying the image file and update the firmware, to confirm this is happening, the mute button LED will begin blinking an alternating pattern of green and red
Please do not use this file on anything but a Node (A Powernode or Vault requires a different img file)
Once completed and your Node has returned to service turn the volume on the N100 all the way down. In your iPad open safari and enter the following command
http://NodeName.local:11000/VolumeRamp?name=log
where NodeName is your player name (the player IP address can be substituted for NoeName.local)
Safari should simply reply with the word 'log'
Once completed return to the App and try using the volume slider and let me know what you think.
If you have any questions or concerns, please feel free to reply to this thread.
Tony Williamson
Bluesound Product Support Manager
Tony Williamson
