P
Yamamoto Hs-3 headshell Solgt
Platespiller tilbehør
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Buskerud
Pris
Kr 990
Kjøpt av
Havfruen
Annonse beskrivelse
Annonse nummer: 257048
HS-3 Head shell made from boxwood material
Yamamoto Sound Craft HS-3is made of rare and excellent materials.Boxwood (yellow)This is a head shell using. It takes full advantage of the clear sound quality of boxwood, and achieves high rigidity despite its lightweight design. Improve the resolution of analog playback with deep, clear sound.
Excellent acoustic properties of rare boxwood wood
  • Boxwood properties: Boxwood is a very high quality wood that is also used for combs and seals, and its specific gravity is approximately 0.75, which is slightly heavier than cherry wood. The wood grain is very fine and homogeneous, and the wood is strong and elastic.
  • High rigidity and light weight: Due to this excellent property, it is lightweight with a weight of 8.2g. The tone arm's operating sensitivity is high, so we recommend using it as a light vibration system.
  • Sound purity: Since the wood itself does not produce a unique resonance sound, there is almost no ringing when the fingers are pressed, which is a problem with metal shells, and the purity of the sound is maintained.
Attention to detail
  • Appearance: The slightly yellowish appearance gives it the unique dignity of boxwood.
  • Finger rest: The finger rest is made of gold-plated brass.
  • Weight adjustment: If it is difficult to balance the weight, you can easily adjust it by using the weight adjustment washer WA-1 (sold separately).
Spec
materialBody: Boxwood (clear eco-paint finish) Finger rest: Brass (non-magnetic gold-plated finish)
External dimensions18(W)x 50(L)x 18(H)
own weight8.2g
shell leadStandard type
accessoriesStandard type 4-color shell lead included 3 types of brass gold-plated mounting screws included
Review
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
plinius
Torget karakterer
Vurderinger (56)
