Selger en meget pen Technics SL-MA1 platespiller.
Fra Vinylengine.com:
Description
The Technics SL-MA1 is a 2-speed, quartz-controlled, direct-drive turntable with electronically controlled tonearm.
Specifications
Type: fully automatic
Drive method: direct drive
Motor: brushless DC motor
Drive control method: quartz phase-locked
Platter: 325mm aluminium die-cast
Speeds: 33 and 45rpm
Wow and flutter: 0.012% WRMS
Rumble: -81dB
Tonearm: static balance type
Effective length: 230mm
Veldig usikker på hva denne er verdt, men basert på ebay virker 3000 som en fornuftig pris.
Effective mass: 9g (inc cartridge)
Resonant frequency: 10Hz
Stylus pressure range: 1.25g +-0.25g
Dimensions: 453 x 170 x 408mm
Weight: 9kg
Description
Specifications
Rumble: -81dB
Weight: 9kg
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Avtales nærmere
