Tannoy Prestige ST-200 SuperTweeters selges. I mint condition, som nye. Tannoys etablerte diskanter for oppgradering av dine høyttalere for et løft i diskantområdet, justerbart delefilter innebygget, 14,16,18000 Hz. Fem følsomhetsjusteringer, 89-95 dB. Tilkobles direkte til forsterker på samme terminal som høyttalere eller via høyttalerterminalene. 2 pcs.
Original koffert medfølger. Orginal box. Samt Tannoy Woodwax og bananplugger.
Brukt med Kimber Kable 4AG kabel i rent sølv med Tannoy Westminster (solgt)
ST200 SuperTweeter™ are available in solid oiled American Walnut and are exceptionally fine SuperTweeters with regards to adjustment optimization, appearance, style, construction and performance. The ST200 Prestige model is provided with a calibrated location gauge, to allow accurate front to back positioning for all Prestige loudspeaker designs past and present. A SuperTweeter™ is a small high frequency drive unit, mounted in a special casing, designed to sit on top of, and drawing its input signal from, existing speakers. Tannoy SuperTweeter™ will transform any sound system, creating the effect of a quantum leap upgrade in the sound quality of speakers, electronic components and cables. All models are stand-alone units with vertical axis adjustment to ensure optimum combined acoustic output with the main speaker. Each has two sets of controls allowing both operating frequency and output level to be optimized for any type of speaker. SuperLink™ cables are signal links specifically designed to connect Tannoy SuperTweeters™ to any speaker input terminals where high-grade speaker cables, such as Van den Hul, are in use. Using pure silver conductors, high-grade PTFE insulation and gold plated connectors, they provide ultimate signal purity and definition at high sonic frequencies and output levels.
Recommended amplifier power Up to 250 Watts
Continuous power handling 135 Watts RMS (DIN IEC 268)
Peak output power 550 Watts Peak
Maximum Sensitivity 95dB (2.83v @ 1m)
Nominal impedance 8 Ohms
Frequency response To 54kHz, usable output (-18dB) to 100kHz
Driver Type 25mm (1") 25 micron titanium dome, 24 carat vapor deposited gold finish with neodymium magnet
Crossover Frequency 14kHz, 16kHz or 18kHz adjustable
Crossover Type 3rd order compensated high pass
Crossover Level 89dB, 90.5dB, 92dB, 93.5dB, 95dB adjustable
Dimmension 150mm (6in) diameter
Weight 6.5kg
Finish Oiled Solid Walnut with 24 Karat Gold Detail
Mer info: http://www.usspeaker.com/Tannoy Supertweeter-1.htm
Røykfritt hjem.
Nypris var 22 000 kr.
Weight 6.5kg
Røykfritt hjem.
- Originalemballasje
- Ja
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
