Inbytt högtalare tillverkad av Reidar Persson.
Uppgraderad till nyare version med berylium diskant och nya mellanregister av Reidar själv. Kvitto på uppgradering finns.
80+ kg tunga.
Länk till hemsida:
www.hificonsultpn.se
Specifications:
Three-way, floor standing, full range bass-reflex design. The cabinet is a 50 mm HD sandwich construction with viscoelastic layer.
1" Scan Speak, Ringradiator
5" Scan Speak, Mid
10" Scan Speak, Bass
Sensitivity: 2,83V 86dB/ m
Nominal impedance: 4 ohm
Frequency response:
28 Hz - 40 kHz
- High frequency response: Full level above 40 kHz
- Echo free: 200 Hz - 20 kHz ± 1 db
- Low frequency response: -3 db 28 Hz
Crossover:
Hand-built point-to-point wired crossover specified at 0,5% tolerance
Crossover slopes: 24 db/octave. acoustical
Crossover frequencies: 350hz, 3500hz
Components:
0,5% tolerance matched propylene capacitors
0,5% tolerance Custom Air cored inductors
Temperature stable resistors
Internal wiring: Custom made
Connection: Rhodium Binding post from Cardas
Dimensions:
Height: 112,0 cm
Width: 43,6 cm
Depth: 54,5 cm
Weight: 85 kg each
Shipping dimensions: 69x58x129cm,
Volume 0,515 m3
80+ kg tunga.
Länk till hemsida:
Respons Grand Dimension - Hificonsultpn.se
Inbytt högtalare tillverkad av Reidar Persson. Uppgraderad till senaste versionen med berylium diskant och nytt mellanregister. 80+ kg tunga.
Specifications:
5" Scan Speak, Mid
Frequency response:
28 Hz - 40 kHz
Crossover:
Components:
Dimensions:
Height: 112,0 cm
Width: 43,6 cm
Depth: 54,5 cm
Weight: 85 kg each
Volume 0,515 m3
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
