Rega DAC-R selges.
Ser fin ut og fungerer som den skal. Fjernkontroll og strømkabel følger med. Kan pakkes godt i uoriginal emballasje og sendes.
Topptest i Stereophile!
Stereophile berømmer blant annet DAC-R's unike kombinasjon av musikalitet og detaljrikdom. "If you have $1195 to spend and prefer your digital music with a slight bit of warmth, but without losing any of a recording's details, the Rega DAC-R is a DAC for your short list—especially since you can tune those filters."
Tester:
audiophile.no
Brukermanual:
Spesifikasjoner:
DAC 2x Wolfson WM8742
Frequency Response (100KΩload) Filter 1 selected
Low data rate 44.1/48kHz = 10Hz -0.05dB to (44.1K) 20.02kHz (48K) 21.7kHz -0.03dB
Medium data rate 88.2/96kHz = 10Hz -0.05dB to (88.1K) 28.7kHz (96K) 31.2kHz -3dB
High data rate 176.4/192kHz = 10Hz -0.05dB to (176.4K) 44.1kHz (192K) 47.7kHz -3dB
Maximum output level = 2.175V into 100KΩload
Bit resolution (all inputs) 16 to 24bit
Supported data rates = 32, 44.1, 48, 88.2, 96, 176.4, 192kHz
Total Harmonic Distortion all inputs (24bit 96kHz) = 0.006% @ 1kHz
Signal to Noise Ratio -105dB (relative to maximum output level with a 100Hz to 22kHz bandwidth)
Digital inputs
USB Asynchronous Isolated (24bit 44.1/48/88.2/96/176.4/192kHz)
Input 1 Optical/Toslink (24bit 32/44.1/48/88.2/96/176.4/192kHz)
Input 2 Optical /Toslink (24bit 32/44.1/48/88.2/96/176.4/192kHz)
Input 3 Isolated 75ΩCo-axial (24bit 32/44.1/48/88.2/96/176.4/192kHz)
Input 4 Isolated 75ΩCo-axial (24bit32/44.1/48/88.2/96/176.4/192kHz)
Digital SPDIF outputs (via receiver & PLL)
Optical/Toslink
Power 230v/115v/7.6W
Dimensions in cm W 21.5 x D 32 x H 8
Remote NEC system (6E91)
Weight 4.0 Kg
Tester:
DAC-R – ny USB-DAC fra Rega
Rega lanserer en ny USB-DAC. Navnet er Rega DAC-R. Selv om Rega kanskje er aller mest kjent for sine platespillere, har de også opparbeidet et godt renomme innen digitalteknikk. CD-spillere har stått på menyen i årtier, og den nye DACen er et supplement i denne digital...
Brukermanual:
Spesifikasjoner:
Digital inputs
Optical/Toslink
Weight 4.0 Kg
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
