Detter Plixir sin største strømrenser som kan håndtere 3000w og en klasse AB forsterker på 600W i 4 ohm. Meget god kabinettkvalitet og et stilrent design. Bruker spesiallaget Noratel trafo. Egne føtter ifra B-Fly for å redusere vibrasjoner.
Test: https://www.6moons.com/audioreviews2/plixir2/1.html
www.plixirpower.com
It is designed to naturally reduce the incoming AC mains noise while improving the current delivery to your system. Based on a custom single winding balanced power transformer, ground loop current and noise is reduced to negligible level to equipment connected to it, making it suitable for sensitive equipment like turntable and phono stages.
Features
- Eight USA/EU outlets for Hi-fi equipment use. For all types of equipment, including high current power amplifiers to noise sensitive vinyl playback equipment.
- Custom-wound balanced transformers with Noratel XQ (eXtra Quiet) noise attenuation technology
- Single-winding transformer dedicated models for 120 Vac and 230 Vac input/output, and each transformer only has a single winding for their intended application for the best performance possible
Technology and Craft
Our Elite balanced power conditioners features the highest grade power transformer from Noratel, the inventor and premier toroidal power transformer manufacturer. Customised to our exact spec and with proprietary XQ (eXtra Quiet) technology, our Elite balanced power conditioner provides the best noise isolation, power conditioning and optimal systems grounding for your hifi system in a single package.
Other Features
Casing
Extra rigid aluminium vault casing – Thick precision extruded and CNC machined aluminium slabs form the casing for the PLiXiR Elite BAC 3000. The bottom plate is a hefty 8mm thick plate of aluminium that anchors the whole casing.
Vibration
ControlIsolated by Bfly Audio - Bfly Audio Master Pro-Feet Series isolation footers from Germany are installed onto PLiXiR Elite BAC 3000. They isolate the Elite BAC 3000 from the ill effects of self and environmental vibration and contribute to the natural sound of the Elite BAC 3000.
Master-crafted
Build and tested by Master craftsman -- Each BAC is hand-made by a master craftsman. As much as possible, all electrical connections are done by point to point direct soldering with minimal use of connectors and joints that degrades sound.
Specifications
Input 220~240Vac to output 220~240Vac balanced 50hz, 13Amps peak continuous current delivery.
IDLE POWER CONSUMPTION - Less than 1.5% of Max power.
WEIGHT - 40 kg
DIMENSIONS (IN MM) - 380 x 140 x 350(390m with handlers)
CASING FINISH - Black anodized, sandblasted aluminium
Det er rimeligere versjoner av denne også til salgs.
Elite BAC 1500W kr 39990
Elite BAC 1000W kr 26990
Elite ABC 400W kr 14990
Elite BAC 140w kr 7990
Plixir Power - The world’s first fully balanced power delivery system.
Features
Other Features
Casing
Vibration
Master-crafted
Specifications
WEIGHT - 40 kg
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
