Ortofon Verto step-up. Denne har to valgbare settinger for last. Se under.
Technical data Configuration A:
Recommended cartridge impedance 5-50 Ohm
Gain 24dB at 1kHz
Frequency response 10 Hz - 100 kHz ± 1 dB
Technical data Configuration B:
Recommended cartridge impedance < 10 Ohm
Gain 30dB at 1kHz
Frequency response 10 Hz - 80 kHz ± 1 dB
Gain and frequency responce at recommended load 47 kOhm / 200 pF
Dimensions 75 X 125 X 170 mm
Recommended load 47 Kohm // 200 pF
Selges med komplett eske og original dokumentasjon. Helt strøken kondisjon. Bilde hentet fra nett.
Gain 24dB at 1kHz
Gain 30dB at 1kHz
- Originalemballasje
- Ja
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
