roov
NuForce DDA-100 Solgt
Denne annonsen er utgått.
Integrert forsterker
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Hordaland
Pris
Kr 2.500
Annonse beskrivelse
Annonse nummer: 178068
Moderne, heldigital integrert forsterker med dac. Stilren og praktisk. Strålende dac og meget vellydende forsterker. 4 digitale innganger (USB, SP/DIF og 2 toslink) og 1 digital utgang (toslink). Fjernkontroll.
Mulighet for prøvelytting. Kan sendes i original emballasje.
Tester:
http://www.lydogbilde.no/test/hi-fi/nuforce-dda-100-2
https://www.soundstagehifi.com/index.php/equipment-reviews/536-nuforce-dda-100-direct-digital-integrated-amplifier
https://www.digitaltrends.com/amplifier-reviews/nuforce-dda-100-review/
https://witchdoctor.co.nz/index.php/2013/12/nuforce-dda-100-integrated-amplifierdac-review/
Spesifikasjoner:
Audio
- Amplifier Output Details
75 Watt - 4 Ohm - 2 channels (main)
50 Watt - 8 Ohm - 2 channels (main)
Power Device
- Nominal Voltage AC 120/230 V
Audio System
- Type amplifier
- Subcategory audio components
- Functions amplifier, audio digital to analog converter
- Sound Output Mode stereo
Header
- Brand NuForce
- Product Line NuForce
- Model DDA-100
- Packaged Quantity 1
Miscellaneous
- Color silver
- Color Category silver
- Output Power / Channel 50 Watt, 75 Watt
Output Impedance / Channel 4 Ohm, 8 Ohm
Channel Type main
Channel Qty 2
Inputs & Outputs
- Coaxial Digital Input Yes
- Optical Digital Input Yes
- Optical Digital Output Yes
Remote Control
- Type Standard
Audio Specifications
- Type Amplifier
- Frequency Response 20 - 20000 Hz
- Signal-To-Noise Ratio 95 dB
- Total Harmonic Distortion 0.07%
Power
- Voltage Required AC 120/230 V
Connections
- Type SPDIF input, SPDIF output, USB 2.0, speakers output
- Qty 2
- Connector Type 4 pin USB Type B, RCA, TOSLINK, banana/spade x 2
- Connector Location rear
Dimensions & Weight
- Width 9 in
- Depth 8.5 in
- Height 2 in
- Weight 2.65 lbs
Dimensions & Weight (Shipping)
- Shipping Weight 5.1 lbs
General
- Manufacturer Optoma
roov
Fersking
Torget karakterer
Vurderinger (23)
Andre annonser av roov
