High-end multikanal fra MF. Dette egentlig 5 stk A3.2 kanaler i samme kabinett. Meget støysvak !
Selges eller byttes i «Low-power« amp.
Power output (0.5% distortion) 112 watts per channel into 8 Ohms
160 watts per channel into 4 Ohms
THD 20Hz - 20KHz < 0.01% at 1KHz at 1W
Typically 0.005% at 1KHz at full power
Frequency response 10Hz - 20KHz +0.2dB
Frequency response 10Hz - 100KHz _3.0dB
Channel separation >-85dB 20Hz-20kHz
Input sensitivity 1000mV
Input impedance 31KOhm
S/N ratio > -100dB ‘A’ weighted (Ref 1W)
> -120dB ‘A’ weighted (full output)
Power consumption 1200W Max
Dimensions Amplifier 440 x 95 x 400mm (W x H x D)
Height includes feet, depth includes terminals
Power requirements 100/115/230V AC 50/60Hz
(Factory preset)
Weight 16 kg (un-boxed)
Standard accessories IEC type mains lead
(Factory preset)
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
