Flott rørbasert dac og hodetelefonforsterker. Noen små riper på toppen. Se bilder. Ellers ser den fin ut og fungerer som den skal.
Rør: Electro-Harmonix 6922.
Det er oppgradert kondensatorer i utgangstrinnet.
Nypris 7.000,-
Tester:
Brukermanual:
Spesifikasjoner:
- USB input: supports 24-bit audio at sample rates up to 96kHz
- All other inputs: accept 24-bit audio at sample rates up to 192kHz
- Output level: 2.0V
- Tube: Electro-Harmonix 6922 tube
- Frequency response: 2Hz~20KHz +/-0.2dB
- DAC Chipset: TI PCM 1796 192kHz/24-bit/192kHz and TI SRC 4192 asynchronous sample rate converter
- High precision active crystal oscillator master clock
- User selectable 96kHz or 192kHz upsampling
- Asynchronous re-clocking and anti jitter control system
- Oversampling: 8x digital filter
- Inputs: Four digital inputs including coax (S/PDIF RCA), TosLink optical, XLR (AES/EBU), or USB
- Outputs: Stereo gold plated outputs; single ended (RCA) and balanced (XLR)
- Headphone output with adjustable analog volume control
- Headphone output level: 4V max
- Headphone output resistance: 0.3 ohm
- Dimensions: 8.5 x 13.5 x 3.75 (WxDxH in inches)
Nypris 7.000,-
Tester:
Music Hall dac25.3 DAC and Headphone Amplifier Review | Ultra High-End Audio and Home Theater Review
A year or so ago, Sam Tellig reviewed the Music Hall dac25.2, the predecessor to the dac25.3 I have in house for review. What did Sam use...
www.ultrahighendreview.com
Music Hall dac25.3 Inspiring a refreshing case of downgraditis. Review By Clarke Robinson
Music Hall dac25.3 Inspiring a refreshing case of downgraditis. Review By Clarke Robinson - Enjoy the Music.com Review Magazine
www.enjoythemusic.com
Brukermanual:
music hall audio—turntables electronics and accessories - music hall audio
musichallaudio.com
Spesifikasjoner:
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
