Flotte Monitor Audio Silver 2 i valnøtt finnish kjøpt på SWSG 08/2017, har alt av original emballasje, kvittering og manual. 8" bassmellomtone, biwiring. Kan følge med B&W stativer i sort som kan sandfylles, har også org. emballasje til disse.
Veil.nypris høyttalere var 8495,- kjøpt på tilbud for 4990,- Nypris stativ er 1398,- JEG SELGER ALT FOR KR.3200,- INKL.FRAKT.
Improved C-CAM (Ceramic-Coated Aluminium/Magnesium) Gold Dome tweeter design with damped rear chamber and innovative dome venting technique for improved clarity and wider operating bandwidth.
8? bass driver with concave ?dished? C-CAM cone profile.
RST (Rigid Surface Technology) cone profile, for improved diaphragm rigidity and reduced distortion.
Improved cast polymer bass chassis design for better rigidity and reduced reflections.
HiVe II port technology delivers smoother airflow for better transient response and tighter bass.
Single bolt through driver systems for increased overall bracing, rigidity and driver/baffle de-coupling.
Pureflow Silver plated OFC copper internal cabling.
High quality crossovers with premium grade polypropylene film capacitors.
Available in selected premium quality wood veneers or high gloss finishes.
Rigid 20mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity and low cabinet colouration.
Invisible magnetic grille fixing provides clean visual styling when the grille is off.
https://www.monitoraudio.com/en/support/past-products/silver-5g/silver-2/
